I'm thinking of purchasing this 2008 F-250 and trying to see if I could get a Oasis report for it please. Also if there is an advise about these truck would greatly appreciated. Thanks again for the help!!:help
Vin#1FTSW21R28EC03289
OASIS RESULT: 1FTSW21R28EC03289 USA: EN 16-JANUARY-2013 / 05:27:24 EST/ APP1
Local Time: 16-JANUARY-2013 / 3:27:30 AM
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2008 F-SERIES
BODY STYLE: F-250 CREW CAB 4X4
ENGINE: 6.4L Diesel V8 Twin Turbo
TRANSMISSION: 5 Speed Auto 5R110W - HI/Torque
AXLE CODE: 3L
ENGINE CALIBRATION: 8F716A0A
PAINT COLOR: Dark Shadow Gray
PAINT CODE: CX
RADIO: With AM/FM CD Player
AXLE RATIO: 3.73 Ratio
WHEEL SIZE: 7.5 X 17" Chrome Steel Wheel
FRONT TIRE: LT265/70/R17E A/T OWL
GROSS VEHICLE WEIGHT: 10,000 LB. GVW
CLAIMS:
Customer Comments FUEL TANK STOPPER 08C07
Tech Comments 5838 RECALL WARRANTY 08C04B INSTALLED FUEL TANK STOPPER BRACKET AS PER RECALL 08C04.
Customer Comments 08B06 6.4L DIESEL COOLING SYSTEM VENTURI TEE INSTALLATION
Tech Comments 5838 RECALL WARRANTY INSPECTED FOR VENTURI KIT, FOUND KIT HAD NOT BEEN INSTALLED. INSTALLED COOLING SYSTEM VENTURI KIT.
Customer Comments REPROGRAM PCM & IC 2008 6.4L DIESEL
Tech Comments 7381 RECALL WARRANTY REPROGRAMMED PCM, TCM AND IC AS PER RECALL.
Customer Comments LEAKING OIL SINCE LAST SERVICE
Tech Comments 8443 ENGINE OIL PLUG LEAKING W INSTALLED ENGINE OIL DYE AND PERFORED DYE LIGHT TEST FOUND THAT THE ENGINE OIL PLUG WAS LEAKING REMOVED AND REPLACED THE ENGINE OIL PLUG AND REFILLED THE ENGINE OIL. STEAM CLEANED AND RETESTED. OK
Customer Comments CK ENG LIGHT ON
Tech Comments PERFORM TSB 11 06 15. REPL EGRT SENSOR. 46438 LINE 4 WAS REVERSED ON APPEAL. WRONG TSB APPLIED FOR.
Customer Comments MISC CHECK ENG LIGHT WAS ON
Tech Comments PERFORM TSB 09 19 10.
