OASIS RESULT: 1FTSX31P83EB51600 USA: EN 22-JANUARY-2013 / 00:38:01 EST/ APP1
Local Time: 21-JANUARY-2013 / 10:38:07 PM
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2003 F-SERIES
BODY STYLE: F-350 S/CAB PICKUP 4X4
ENGINE: 6.0L OHV Diesel V8
TRANSMISSION: 5 Speed Auto 5R110W - HI/Torque
AXLE CODE: D1
ENGINE CALIBRATION: 3F710N0A
PAINT COLOR: True Blue
PAINT CODE: L2
RADIO: AM/FM CD Changer/Clock
AXLE RATIO: 3.73 Ratio
WHEEL SIZE FRONT TIRE: LT265/75R-16E OWL A-T Tire
GROSS VEHICLE WEIGHT: 9700 LB. GVW
CLAIMS:
Customer Comments CK FOR COOLANT LEAKING
Tech Comments PRESS TEST COOLING SYSTEM,DIAG & REPLACE LOWER RADIATOR HOSE CLAMP
Customer Comments 03B05 INJECTION CONTROL PRESSURE (ICP) SENSOR REPLACEMENT
Tech Comments PERFORM ONB
Customer Comments 03B06 COLD OPERATION CALIBRATION PRODUCT ENHANCEMENT
Tech Comments ONB COMPLETE
Customer Comments CUST STATES THAT RIGHT FRONT FOG LIGHT BULB IS INOPERABLE
Tech Comments BULBS EXTERIOR REPLACE
Customer Comments 03E03 POWERTRAIN CONTROL MODULE & FUEL INJECTOR CONTROL MODULE RE CALIB
Tech Comments PERFORMED RECALIBRATION UPDATE 03E03
Customer Comments CUSTOMER STATES ENGINE MISSFIRES AND HAS FUEL IN OIL CUST WAS TOLD #6 & 7 INJECTERS LEAKING
Tech Comments 23,875 MILES KOEO P0281 CYLINDER #7 INJECTOR FAULT,CONFIRM CONDITION WITH CYLINDER BALANCE TEST,REPLACE #7 INJECTOR,CHANGE ENGINE OIL
Customer Comments CCUSTOMER STATES THAT VEHICLE HAS A MASSIVE POWER LOSS
Tech Comments CHECKED ALL CABLES PLUG WIRES VACCUM LINES AND HOSES FOUND HOSE GOING TO INTER COOLER TO HAVE FALLIN OFF REINSTALLED HOSE ROAD TEWSTED VEHICLE FOR SEVERAL MILKEGES NO LOSS OF POWER VEHICLE RUNNING NORMALLY
Customer Comments PERFORM RECALL 04S15
Tech Comments PERFORM RECALL 04S15 PER FORD SPECIFICATIONS
Customer Comments SOP L F SEAT BELT CK ON COVERAGE 5 50?
Tech Comments SEATBELT ASSEMBLY FRONT REPLACE
Customer Comments REPAIR PER TSB 04 24 21
Tech Comments SAFETY BELT RETRACTION SPEED
Customer Comments 06E17 CONTROL MODULE RECALIBRATION
Tech Comments REPROGRAMMED ALL CONTROL MODULES
Customer Comments 59B01 ROAD TEST
Tech Comments ROAD TEST
Customer Comments CUST STATES REPAIR C D PLAYER SKIPS AND WILL NOT PLAY
Tech Comments RADIO REMOVE REP
Customer Comments
Tech Comments REQUESTING DEALER'S P/A CODE 03646
Customer Comments CUSTOMER STATES THAT THE CHK ENG LIGHT IS ON AND VEHICLE SEEMS TO LACK POWER SEEMS TO RUN A LITTLE ROUGH IN AM
Tech Comments VFY CK ENG ROUGH ON IDLE ON COLD START P132B TSB 06226 REPGRM FICM SSM 19356 RESET KAM MNITOR PID VGT LEARN DOES NOT COMPLETE PNPT KA P132B EGR POS TEST PASS KA 2 AND KA 3 PASS KA4 MAP 14.6 MAP BARO 14.8 KA 5BOOST .71 AT 85 PRCT KA7 NO LKS KA 9 KA10 VANE MOVE FAIL RPL TURBO PER TSB 06 23 2 DISSASSEMBLE FOUND NO COKING RUSTED CAUSE OF CONCERN, REPALCE TURBO PER TSB
Customer Comments ADD ON REPAIR CLUNK NOISE OVER BUMPS
Tech Comments PERFORMED ROADTEST AND VERFIED CONCERN, INSPECTED AND FOUND WORN SWAY BAR BUSHINGS AND SWAY BAR LINKS. REPLACED 2 SWAY LINKS AND 2 FRONT BAR BUSHINGS. ROADTESTED VEHICLE GOOD AT THIS TIME.
Customer Comments NOISE COMING FROM FRONT END SQUEAL DRY RUBBING NOISE
Tech Comments NOISE PERFORMED ROADTEST AND VERFIED CONCERN, OASIS NO TSB,SSM. INSPECTED FRONT END AND FOUND BALL JOINTS WORN. DEVIATION OF BALL JOINTS, LF UPPER .035 , LF LOWER .051 , RF UPPER .030 , RF LOWER .063 . REPLACED BALL JOINTS AND ROADTESTED VEHICLE.
Customer Comments ADD ON REPAIR STEERING STABILZER SHOCK IS LEAKING
Tech Comments PERFORMED INSPECTION AND VERFIED REPAIR. INSPECTED AND FOUND STABILIZER SHOCK LEAKING. NO TSB/SSM. REPLACED SHOCK AND VERFIED REPAIRS
