2003 ford f-250
1ftnw21p03ec36148
Thanks!:thanks:
OASIS RESULT:
1FTNW21P03EC36148
07/25/2006
17:18:12
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/06/2003 BUILD DATE
02/20/2003 SALE MILEAGE
00016
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
02/23/2006
DEALER: Clevenger Ford
WARRANTY CLAIM NUMBER: 018015 ODOMETER: 084057M
LABOR OP
CONDITION CODE
CONDITION DESC
000 06E17B
605 RECAL. CONTROL MODULE
02/23/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
605 ONE TIME TEST DR.
END OF OASIS REPORT FOR 1FTNW21P03EC36148
Standard Claims List For Model Year 2003
1FTNW21P03EC36148 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 20-FEB-2003 06-MAR-2003 172430 USA 1 1H03 030008 3C3Z 9F452 AB D42 42 128
AWS Claim Key: 900170 Trx Code: 1 Labor Hrs: 3.9
Dlr Cd-Sub Cd: 07845 - * Name: CLEVENGER FORD Ph: 559-7846000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-APR-2003 Doc #:08924551
Cust Comments: AT TIMES THERE IS NO POWER, LOADS UP
Tech Comments: 010 ROAD TESTED WITH EGR VALE COMMANDED OPEN TO CLEAR OUT EGR. STILL STICKS OPEN AND TIMES. ORDERED AND REPLACED EGR VALVE. CLEARED CODES, ROAD TESTED AND RETESTED OK
1FTNW21P03EC36148 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 20-FEB-2003 06-MAR-2003 172430 USA 5 2G05 * * * * * * 7259
AWS Claim Key: 1795049 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07845 - * Name: CLEVENGER FORD Ph: 559-7846000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-JUL-2003 Doc #:09206650
Cust Comments: PROGRAM 03B06 COLD OP. CALIBRATION
Tech Comments: REPROGRAMMED PCM
1FTNW21P03EC36148 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 20-FEB-2003 06-MAR-2003 172430 USA 5 * * * * * * * 7259
AWS Claim Key: 1795050 Trx Code: 57B98 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 07845 - * Name: CLEVENGER FORD Ph: 559-7846000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-JUL-2003 Doc #:09206651
Cust Comments: PROGRAM 57B98 LOF
Tech Comments: 281 CHANGE OIL & FILTER
1FTNW21P03EC36148 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 20-FEB-2003 06-MAR-2003 172430 USA 8 2G05 031405 * RECAL * D42 42 17883
AWS Claim Key: 3148812 Trx Code: E84 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 07845 - * Name: CLEVENGER FORD Ph: 559-7846000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-OCT-2003 Doc #:09501551
Cust Comments: CK ENGINE LIGHT ON AT TIMES, DOESNT SEEM TO RUN RIGHT COMPARED TO OTHER TRUCK OWNWD BY CUSTOMER
Tech Comments: 281 PERFORMED DIESEL DIAG SHEET, VISUAL INSPECTION. PPT TO INTAKE AIR TEMP SENSOR 2 CIRCUIT. REFLASHED PCM AND RETESTED OK
1FTNW21P03EC36148 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 20-FEB-2003 06-MAR-2003 172430 USA 8 3A11 070100 * 7000 * P51 07 17883
AWS Claim Key: 3148813 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07845 - * Name: CLEVENGER FORD Ph: 559-7846000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-OCT-2003 Doc #:09501552
Cust Comments: HARD TO ENGAUGE REVERSE, HAS TO PLAT WITH GEAR SELECTOR
Tech Comments: 281 LOWER CABLE MOUNTR NOT SNAPPED IN. REPOSITIONED BRACKET AND SNAPPED CABLE INTO PLACE.
1FTNW21P03EC36148 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 20-FEB-2003 06-MAR-2003 172430 USA 8 3Y88 000615 * NPF * P82 82 17883
AWS Claim Key: 3148814 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 07845 - * Name: CLEVENGER FORD Ph: 559-7846000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-OCT-2003 Doc #:09501553
Cust Comments: 4X4 LOW INOP
Tech Comments: SEAT CONNECTOR ON 4X4 PROPERLY
1FTNW21P03EC36148 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 20-FEB-2003 06-MAR-2003 172430 USA 9 7S22 180106 3C3Z 14A068 AA D21 42 18929
AWS Claim Key: 3372181 Trx Code: E83 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 07845 - * Name: CLEVENGER FORD Ph: 559-7846000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:13-NOV-2003 Doc #:09541651
Cust Comments: DIES WHEN SHIFTS OUT OF PARK & WHEN TURNS ON HEADLAMPS
Tech Comments: EEC TEST,CODE: P0404,P0683,P2614,P2617 CHECKED OASIS,CALLED HOTLINE. . FOUND LOW POWER AT FUSE 2.22. TRACED CIRCUIT TO DIODE FOR PCM POWER RELAY PART OF FUSE BOX. ORDERED & REPLACED FUSE BOX RETESTED,OK.
1FTNW21P03EC36148 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 20-FEB-2003 06-MAR-2003 172430 USA 20 * * * * * * * 49213
AWS Claim Key: 7845537 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07845 - * Name: CLEVENGER FORD Ph: 559-7846000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-SEP-2004 Doc #:00337550
Cust Comments: RECALL 04S15 BATTERY TO ENGINE BLOCK GROUND
Tech Comments: 010 REPLACED BOLT AS PER RECALL
AWS Claim Key: 7845538 Trx Code: 03E03 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07845 - * Name: CLEVENGER FORD Ph: 559-7846000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-SEP-2004 Doc #:00337551
Cust Comments: RECALL 03E03 PCM & FIC RECALIBRATE
Tech Comments: 010 RECALIBRATE PCM & FIC PER RECALL
1FTNW21P03EC36148 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 20-FEB-2003 06-MAR-2003 172430 USA 28 2E06 030008 3C3Z 9C891 AA E29 X2 71300
AWS Claim Key: 11324650 Trx Code: E72 Labor Hrs: 13.3
Dlr Cd-Sub Cd: 07845 - * Name: CLEVENGER FORD Ph: 559-7846000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-JUN-2005 Doc #:01040851
Cust Comments: CK ENGINE LIGHT ON, CK HISTORY, NO RESPONSE TO THROTTLE AT TIMES
Tech Comments: 281 PERFORMED DIESEL ENGINE DIAG. PPT. FOUND IATZ CARBONEDF UP. REPLACED SENSOR. RETESTED, PASS. PERFORMED VGT DIAG, PASS. REPLACED EBP DUE TO OUT OF RANGE. ROAD TESTED CELL ON . REMOVED SENSOR. CONTAMINATED AGAIN. CALLED TECH LINE. SWITCHED PCM, NO CHANGE. PULLED ON WIRE LOOM, AITZ SPIKING. FOUND DAMAGED WIRES CAUSED BY SENSOR LEAKING. REMOVED INTAKE MANIFOLD AND CLEANED. REPLACE
1FTNW21P03EC36148 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 20-FEB-2003 06-MAR-2003 172430 USA 28 1D01 03XXXX 3C3Z 6701 AA L65 D8 71300
AWS Claim Key: 11324651 Trx Code: E72 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 07845 - * Name: CLEVENGER FORD Ph: 559-7846000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-JUN-2005 Doc #:01040853
Cust Comments: CL OIL LEAK AT RERAR MAIN
Tech Comments: 281 PERFORMED DYE TEST. REPLACED LEAKING REAR MAIN SEAL
1FTNW21P03EC36148 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 20-FEB-2003 06-MAR-2003 172430 USA 37 * * * * * * * 84057
AWS Claim Key: 13233166 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07845 - * Name: CLEVENGER FORD Ph: 559-7846000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2006 Doc #:01801550
Cust Comments: RECALL 06E17 CONTROL MODULE RECALIBRATION
Tech Comments: 605 RECAL. CONTROL MODULE
AWS Claim Key: 13242924 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07845 - * Name: CLEVENGER FORD Ph: 559-7846000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2006 Doc #:01801551
Cust Comments: PROGRAM 59B01 ONE TIME TEST DR.
Tech Comments: 605 ONE TIME TEST DR.
