OASIS RESULT:
1FTSW21P25EA83441
07/25/2006
17:23:21
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
5F710N0A
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/01/2004 BUILD DATE
09/29/2004 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-14-06
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
BEFORE REPLACING FS-10 A/C COMPRESSOR (19703), PLEASE SEE TSB 06-04-09
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
CUDL - THIS VEHICLE HAS AN OPEN CUDL CONTACT
05B32
DE-GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
EXTENDED COVERAGES
0701 - USA 2005 NEW 60/75,000 PREMIUMCARE W/ROADSIDE ASSIST
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: TIMOTHY PORTER
OPTIONS:
EXPIRATION DATE: 12/01/2009
DISTANCE: 75,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 48996
ESP CONTRACT START DATE: 12/01/2004
REPAIR HISTORY
02/03/2006
DEALER: Fairview Ford Sales, Inc.
WARRANTY CLAIM NUMBER: 085435 ODOMETER: 019987M
LABOR OP
CONDITION CODE
CONDITION DESC
9433 GASKET SET-MANIFOLD 000 42 DOES NOT OPERATE PROPERLY
REQUEST REFUND FOR EXPENCES INCURRED OUT OF STATE
01/09/2006
DEALER: St. George Ford Lincoln Mercur
WARRANTY CLAIM NUMBER: 400398 ODOMETER: 019843M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9433AA GASKET SET-MANIFOLD 001 6005E 42 DOES NOT OPERATE PROPERLY
3C3Z 6A831AA GSKT-OIL FLTR ELEM S 001 6005E2
5C3Z 9G804B O-RING KIT 001 6005E3
OSP 001 6005E4
W301727 001 6005F20
W705589S 003 6005F8
3C3Z 6766BA CAP ASY OIL FILLER 001 6005F22
OSP 001 6005F12
000 6007D
000 9424A
000 9424AZN
000 MT9A543
9433 DIAG START AND RUNABILITY AND OIL LEAK R/R INTAKE AND REPL HIGH PRESS OIL TUBE BLOWN AN D SESNORS
01/09/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15M
01/09/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
01/06/2006
DEALER: Jorgensen Ford Mercury, Inc.
WARRANTY CLAIM NUMBER: 009853 ODOMETER: 019843M
LABOR OP
CONDITION CODE
CONDITION DESC
9C854 BLK-FUL DSTR 000 6005E D8 FAILED GASKET/SEAL
000 6005E2
000 6005E3
000 6005E4
000 6005E6
000 6005E7
000 6005E8
000 6584AT
VERIFIED CUSTOMER CONCERN-PRECHECKS ALL OK-WDS ,PASS CODES, MONITOR PIDS LOW ICP-CRANKING-107.5 PSI -RI LEFT ND RIGHT VALVE COVERS-AIR TEST HP OIL SYSTE M -CAN HEAR AIR LEAKING-REMOVE LEFT AND RIGHT OIL LOGS-CHECK STAND PIPE O RI NGS ALL OK-CHECK INJECTORS O RINGS ALL OK-REASEMBLE OIL LOGS AND STAND PIPE- OIL LEAKING FROM HP PUMP AT 9C854 CONNECTION - NO PARTS IN STOCK-CUSTOMER TA
END OF OASIS REPORT FOR 1FTSW21P25EA83441
Standard Claims List For Model Year 2005
1FTSW21P25EA83441 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 29-SEP-2004 01-DEC-2004 171156 USA 1 5N01 110301 5C3Z 3E651 CA C50 D1 1731
AWS Claim Key: 234888 Trx Code: 2 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 07852 - * Name: FAIRVIEW FORD SALES, INC. Ph: 909-8849261 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:23-DEC-2004 Doc #:06846351
Cust Comments: SOP STEERING DAMPNER SHOCK LEAKING
Tech Comments: STEERING DAMPNER LEAKING CHECKED OUT AND REPLACED THE STEERING DAMPNER LEAKING
1FTSW21P25EA83441 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 29-SEP-2004 01-DEC-2004 171156 USA 4 1H03 030008 3C3Z 9J460 AA D42 42 5661
AWS Claim Key: 510171 Trx Code: S07 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 01864 - * Name: POWER FORD VALENCIA Ph: 661-2556600 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:11-MAR-2005 Doc #:06807001
Cust Comments: CUSTOMER STATES WHEN VEHICLE IS UNDER LOAD TOWING CAN FEEL THE VEHICLE SURGE TURBO PRESSURE GAGE WILL FLUTTER UNTILL IT
Tech Comments: EBP ERRATIC VGT SLOW TO REACT PERF TESTS KOEO KOER BUZZ PASS ICP TESTS PASS BOOST 24PSI PID MONITOR ROAD TEST REPL VGT SOLINOID AND EBP SENSOR
1FTSW21P25EA83441 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 29-SEP-2004 01-DEC-2004 171156 USA 4 2H01 030008 4C3Z 6K682 AARM D10 41 5949
AWS Claim Key: 536460 Trx Code: S07 Labor Hrs: 3.8
Dlr Cd-Sub Cd: 01864 - * Name: POWER FORD VALENCIA Ph: 661-2556600 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-MAR-2005 Doc #:06844301
Cust Comments: CLIENT STATES POWER CUTS OUT,ENGINE MISS UNDER LOAD SEE HISTORY
Tech Comments: VGT STICKING INTERMITTANT PERF TESTS KOEO KOER PASS ICP TESTS PASS BOOST 24PSI PID MONITOR ROAD TEST REPL TURBO RE TEST
1FTSW21P25EA83441 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 29-SEP-2004 01-DEC-2004 171156 USA 5 1D01 03XXXX 3C3Z 6701 AA L65 42 8216
AWS Claim Key: 815012 Trx Code: 2 Labor Hrs: 6.2
Dlr Cd-Sub Cd: 07852 - * Name: FAIRVIEW FORD SALES, INC. Ph: 909-8849261 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:26-APR-2005 Doc #:07367151
Cust Comments: CUSTOMER STATES ENGINE OIL LEAK
Tech Comments: REPLACED REAR COVER PERFORMED OIL DYE AND VISUAL INSPECTION FOUND OIL LEAK AT REAR COVER SEAL REPLACED REAR COVER MTIME AND REAR MAIN SEAL ROAD TEST
1FTSW21P25EA83441 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 29-SEP-2004 01-DEC-2004 171156 USA 5 6Y20 000001 * MISC * A9* 82 8217
AWS Claim Key: 785915 Trx Code: P01 Labor Hrs: 0
Dlr Cd-Sub Cd: 07852 - * Name: FAIRVIEW FORD SALES, INC. Ph: 909-8849261 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-APR-2005 Doc #:07371351
Cust Comments: REQUEST PAYMENT REFUND FOR CONCERNS OK PER SZM
Tech Comments: PAYMENT REFUND REFUND PAYMENT$677.69
1FTSW21P25EA83441 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 29-SEP-2004 01-DEC-2004 171156 USA 14 5S11 100103 * 9C854 * D02 D8 19843
AWS Claim Key: 3061694 Trx Code: E84 Labor Hrs: 4.4
Dlr Cd-Sub Cd: 02842 - * Name: JORGENSEN FORD MERCURY, INC. Ph: 435-8968436 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:06-JAN-2006 Doc #:00985301
Cust Comments: ENGINE STALLED WHILE DRIVING AT HIGHWAYA SPEEDS BATT LIGHT CAME ON
Tech Comments: VERIFIED CUSTOMER CONCERN PRECHECKS ALL OK WDS ,PASS CODES, MONITOR PIDS LOW ICP CRANKING 107.5 PSI RI LEFT ND RIGHT VALVE COVERS AIR TEST HP OIL SYSTEM CAN HEAR AIR LEAKING REMOVE LEFT AND RIGHT OIL LOGS CHECK STAND PIPE O RINGS ALL OK CHECK INJECTORS O RINGS ALL OK REASEMBLE OIL LOGS AND STAND PIPE OIL LEAKING FROM HP PUMP AT 9C854 CONNECTION NO PARTS IN STOCK CUSTOMER TAKING VEHICLE TO CALI
1FTSW21P25EA83441 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 29-SEP-2004 01-DEC-2004 171156 USA 14 1D02 03XXXX 3C3Z 9433 AA D02 42 19843
AWS Claim Key: 3116608 Trx Code: S07 Labor Hrs: 8
Dlr Cd-Sub Cd: 07969 - * Name: ST. GEORGE FORD LINCOLN MERCURY Ph: 435-6743200 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:09-JAN-2006 Doc #:40039801
Cust Comments: CK CRANKS BUT NO START
Tech Comments: 9433 DIAG START AND RUNABILITY AND OIL LEAK R/R INTAKE AND REPL HIGH PRESS OIL TUBE BLOWN AND SESNORS
1FTSW21P25EA83441 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 29-SEP-2004 01-DEC-2004 171156 USA 14 * * * * * * * 19843
AWS Claim Key: 3116609 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 07969 - * Name: ST. GEORGE FORD LINCOLN MERCURY Ph: 435-6743200 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:09-JAN-2006 Doc #:40039803
Cust Comments: EXHAUST PRESS SENSOR REPLACEMENT
AWS Claim Key: 3116610 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07969 - * Name: ST. GEORGE FORD LINCOLN MERCURY Ph: 435-6743200 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:09-JAN-2006 Doc #:40039804
Cust Comments: ROADTEST FOR 05S34 AND/OR 05E15
1FTSW21P25EA83441 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 29-SEP-2004 01-DEC-2004 171156 USA 15 1D02 0301XX * 9433 * D50 42 19987
AWS Claim Key: 3465156 Trx Code: S07 Labor Hrs: 0
Dlr Cd-Sub Cd: 07852 - * Name: FAIRVIEW FORD SALES, INC. Ph: 909-8849261 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2006 Doc #:08543551
Cust Comments: GOODWILL REFUND FOR EMERGENCY REPAIR EXPENCES
Tech Comments: REQUEST REFUND FOR EXPENCES INCURRED OUT OF STATE
