Standard Claims List For Model Year 2001
1FTNW21F81EA06409 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 03-AUG-2000 04-SEP-2000 153116 USA 9 7S22 1801XX F5OZ 14526 AA A88 28 16254
AWS Claim Key: 1480230 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05238 - * Name: OLATHE FORD LINCOLN Ph: 913-7820881 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2001 Doc #:04445352
Cust Comments: TRAILER TOW PLUGS INOP CUST HAD THE TRAILER CHECK AND LIGHT WORKED
Tech Comments: CHECK OUT CIRCIUT FOUND THREE BLOWN FUSES IN JUNCTION BOX RR FUSES OERFORM PINPOINT TEST AB STEPS 1 2 CHECK WIRING REPLACED FUSE TO TRAILER TOW BACKUP AND PARK REPL LEFT AND RIGHT STOP FUSES RETEST
1FTNW21F81EA06409 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 03-AUG-2000 04-SEP-2000 153116 USA 9 5A88 000615 * NPF * L86 82 16254
AWS Claim Key: 1480231 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 05238 - * Name: OLATHE FORD LINCOLN Ph: 913-7820881 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2001 Doc #:04445354
Cust Comments: WHILE AT A STOP AND SHIFTING FROM EITHER PARK TO DRIVE OR REVERSE AND BEFORE MOVING THERE IS A CLUNK FM THE DRIVE LINE
Tech Comments: TEST DROVE INSPECT UJOINTS ENGINE AND TRANS MOUNTS FOR LOOSENESS NO PROBLEM FOUND
1FTNW21F81EA06409 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 03-AUG-2000 04-SEP-2000 153116 USA 11 7W11 011002 1C3Z 14D696 AA A85 42 18067
AWS Claim Key: 2286994 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 05238 - * Name: OLATHE FORD LINCOLN Ph: 913-7820881 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:06-JUL-2001 Doc #:05140851
Cust Comments: SOP DRIVERS SEAT HEATER INSTALLED
Tech Comments: 42 REPLACED DRIVERS SIDE HEATER ELEMENT
1FTNW21F81EA06409 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 03-AUG-2000 04-SEP-2000 153116 USA 13 * * * * * * * 24093
AWS Claim Key: 3402412 Trx Code: 01S24 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 05238 - * Name: OLATHE FORD LINCOLN Ph: 913-7820881 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:30-AUG-2001 Doc #:05787453
Cust Comments: 01S24 WIPER MOTOR GEAR COVER
Tech Comments: 08 REPL. WIPER MOTOR COVER PER RECALL
1FTNW21F81EA06409 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 03-AUG-2000 04-SEP-2000 153116 USA 92 * * * * * * * 105349
AWS Claim Key: 22210311 Trx Code: 07S57 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 12805 - * Name: ROB SIGHT FORD LINCOLN Ph: 816-9411200 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:29-FEB-2008 Doc #:233706C
Cust Comments: CAMSHAFT POSITION SENSOR INSPECTION REPLACEMENT
Tech Comments: 105349 07S57B..0.30 INSPECT CRANK SENSOR BLACK,REPLACED CRANK SENSOR UP DATE ASY
1FTNW21F81EA06409 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 03-AUG-2000 04-SEP-2000 153116 USA 108 1G02 030008 F81Z 8501 FA L87 D8 111369
AWS Claim Key: 22755753 Trx Code: 0968D Labor Hrs: 1.9
Dlr Cd-Sub Cd: 05238 - * Name: OLATHE FORD LINCOLN Ph: 913-7820881 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:25-JUN-2009 Doc #:06252751
Cust Comments: ADVISE ON COOLANT LEAK AND STRONG COOLANT SMELL
Tech Comments: PRESSURE TEST COOLING SYSTEM ,LEAKING COOLANT AT WATER PUMP,DISASSEMBLE AND REPLACED WATER PUMP AND T STAT ORINGS RECHECK
1FTNW21F81EA06409 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 03-AUG-2000 04-SEP-2000 153116 USA 112 5A07 050201 E5TZ 4033 A L88 42 133185
AWS Claim Key: 22896528 Trx Code: 0968D Labor Hrs: 0.6
Dlr Cd-Sub Cd: 05158 - * Name: METRO FORD, INC. Ph: 816-2549800 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:12-NOV-2009 Doc #:243919D
Cust Comments: CK FOR A FLUID LEAK AT THE REAR DIFF..
Tech Comments: REPLACE REAR AXLE COVER FOR RUSTED AND LEAKING 4033A 0.6
1FTNW21F81EA06409 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 03-AUG-2000 04-SEP-2000 153116 USA 112 * * * * * * * 133185
AWS Claim Key: 22856394 Trx Code: 09S09 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 05158 - * Name: METRO FORD, INC. Ph: 816-2549800 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:12-NOV-2009 Doc #:243919C
Cust Comments: RECALL 09S09 SPEED CONTROL
Tech Comments: INSTALL HARNESS PER RECALL FOR CRUISE SWITCH. 09S09B 0.2
