Can someone please run an Oasis report for this truck: 1FTWW31P26ED20843
Thanks
Ryan
Ford OEM Parts Supplier
OASIS RESULT:
1FTWW31P26ED20843
USA
EN
05/03/2010
08:54:24
FCXWS446
© Copyright 2002-2010 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
PAINT COLOR
OXFORD WHITE WB C/C-W/B RADIO
AM/FM STRO/CD CHANGER/CLK GROSS VEHICLE WEIGHT
11,400 LB. GVW
AXLE RATIO
3.73 FINAL DRIVE RATIO WHEEL SIZE
8X18" FORGED POLISHED ALU WHL FRONT TIRE
LT 275/70R18E A/T OWL
WARNING MESSAGES
ARN MESSAGES
INSTALL 6A642-CA KIT WHEN REPLACING EGR COOLER UNDER 09-08-03
TO ENSURE OPTIMUM COOLING SYSTEM PREFORMANCE, REFER TO 09-08-05
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/28/2006 BUILD DATE
03/10/2006 SALE MILEAGE
00016 New Vehicle Base Warranty
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
03/29/2010
DEALER: Downs Ford Lincoln-Mercury
WARRANTY CLAIM NUMBER: 045961 ODOMETER: 080778M
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 9278AA SENDER-OIL PRES 001 9278A D1 POROSITY
XO 15W40QSD 003 MTENGWASH
CK AS NEC FOUND OIL PRESS SENDER LEAKS, R&R NEC HARDWARE AND REPL SENDER, MT IME WASHED DOWN ENG AND UNDER CARRIAGE
03/04/2010
WARRANTY CLAIM NUMBER: 044395 ODOMETER: 080395M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 6C640B CONNECTION A/C DUCT 001 090803A D8 FAILED GASKET/SEAL
6C3Z 6051AA GASKET CYL HEAD 002 090803D
3C3Z 9433AA GASKET SET-MANIFOLD 001 090803F
W300013 004 6005PA
W300050 004 6007D
3C3Z 6731AA ELEMENT ASY OIL FILT 001 MTEXHFASTEN
XO 15W40QSD 015 MTWSHENG
VC 7B 003
VC 9 002
OSP 001
6051 GASKET CYL HEAD 000
CK FOR OIL LEAK, VERIFIED MTIME WASHED DOWN ENG ADDED DYE AND ROAD TEST CK F OUND LEAKAGE FROM HOTSIDE CAC TUBE, CK AND TEST COOLING SYSTEM PER TSB 09080 3,TEST EGR COOLER AND OIL COOLER ON VEH,FOUND OK,ROAD TEST AND MONITORED COO LING SYSTEM TEMPS FOUND FAILED HEAD GASKETS, R&R NECHARDWARE & HEADS,CK HEAD & BLOCK SURFACES FOUND OK,INST NEW GASKETS, FLUHED COOLING SYSTEM, CHANGED
02/22/2010
WARRANTY CLAIM NUMBER: 043795 ODOMETER: 080070M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6C683AB FLTER-ENG OIL 001 090803A 55 PLUGGED/RESTRICTED
4C3Z 9P456AF COOLER - EGR 001 090803B
3C3Z 6A642CA COOLER CRANKCASE OI 001 090803F
3C3Z 6731AA ELEMENT ASY OIL FILT 001 MT9C968
XO 15W40QSD 015 MT092403A
VC 7B 003
VC 9 002
6A642 COOLER CRANKCASE OI 000
CK COOLING SYSTEM FOUND COOLANT VENTING FROM DEGAS TANK, CK AND DIAG COOLIN G SYSTEM PER TSB 09-8-3, EGR COOLER FAILS ON VEH TESTING, R&R NEC HARDWARE A ND EGR COOLER TEST OUT OF VEH, VERIFIED LEAKAGE, INST NEW EGR COOLER AND INS T UPDATED OIL COOLER KIT, MTIME FOUND HIPRESS OIL SCREEN TORN, R&R IPR AND F LUSHED OIL PASSAGE AND INST NEW SCREEN, CHANGED OIL AND FILTER & FLUSHED COO
| On-line 1878
END OF OASIS REPORT FOR 1FTWW31P26ED20843
Standard Claims List For Model Year 2006
1FTWW31P26ED20843 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 10-MAR-2006 28-APR-2006 113451 USA 14 2H02 030008 * 6F089 * E29 42 13524
AWS Claim Key: 3772866 Trx Code: S07 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 09176 - * Name: HERITAGE FORD Ph: 802-8658100 St:VT Ctry Cd: USA Reg Cd: NA Repr Date:29-MAY-2007 Doc #:435798A
Cust Comments: CHECK ENGINE AMBER WARNING INDICATOR (MIL) ON
Tech Comments: 13524 062302B TEST DROVE VERIFEID CUSTOMER CONCERN. PERFORM VISUAL INSPEC ALL OK. PERFORM NORMAL DIESEL DG RETRIEVED CODE PO299 RAN OASIS FOUND TSB 06 23 2. PERFORM TSB ROAD TESTED ALL OK, RELEASED TO CUSTOMER.
1FTWW31P26ED20843 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 10-MAR-2006 28-APR-2006 113451 USA 14 7H11 120303 6C3Z 19C836 A C02 42 13524
AWS Claim Key: 3772867 Trx Code: E83 Labor Hrs: 3.6
Dlr Cd-Sub Cd: 09176 - * Name: HERITAGE FORD Ph: 802-8658100 St:VT Ctry Cd: USA Reg Cd: NA Repr Date:29-MAY-2007 Doc #:435798B
Cust Comments: A C NOT COLD ENOUGH BLOWS WARM AIR AFTER 5 MINUTES,DISPLAY INOP ONCE
Tech Comments: 13524 TESTED A C VERIFIED CUSTOMER CONCERN. PERFORM NORMAL A C DG FOUND ORFICE CLOGGEDAND RECIVER D RIER COMING APART, NEEDS ORFICE AND RECIEVED DR IER AND FLUSH. NO PARTS IN STOCK. ORDERED AND RECEIVED RECEIVER DRIER AND ORFICE. FLUSHED SYSTEM UNTILL CLEANED OF FORIEGN MATERIAL. REASSEMBLED. RECHARGED. RETESTED CONCERN REPAIRED. MT ABNORMAL FLUSHING
1FTWW31P26ED20843 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 10-MAR-2006 28-APR-2006 113451 USA 14 6N04 010802 5C3Z 16720 NA B66 81 13524
AWS Claim Key: 4154467 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 09176 - * Name: HERITAGE FORD Ph: 802-8658100 St:VT Ctry Cd: USA Reg Cd: NA Repr Date:31-MAY-2007 Doc #:435915A
Cust Comments: OTHER EXTERIOR TRIM TROUBLES PAINT PEELING LH & RH FENDER EMBLEMS
Tech Comments: REPLACED BOTH FRONT FENDER EMBLEMS
1FTWW31P26ED20843 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 10-MAR-2006 28-APR-2006 113451 USA 47 1B03 030204 * 6A642 * L87 55 80070
AWS Claim Key: 8968650 Trx Code: E72 Labor Hrs: 11.1
Dlr Cd-Sub Cd: 20681 - * Name: DOWNS FORD LINCOLN-MERCURY Ph: 732-3492240 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:22-FEB-2010 Doc #:04379551
Cust Comments: C S USING COOLANT, COMING OUT OF DEGAS BOTTLE
Tech Comments: CK COOLING SYSTEM FOUND COOLANT VENTING FROM DEGAS TANK, CK AND DIAG COOLING SYSTEM PER TSB 09 8 3, EGR COOLER FAILS ON VEH TESTING, R&R NEC HARDWARE AND EGR COOLER TEST OUT OF VEH, VERIFIED LEAKAGE, INST NEW EGR COOLER AND INST UPDATED OIL COOLER KIT, MTIME FOUND HIPRESS OIL SCREEN TORN, R&R IPR AND FLUSHED OIL PASSAGE AND INST NEW SCREEN, CHANGED OIL AND FILTER & FLUSHED COOLING SYSTEM, REPROG
1FTWW31P26ED20843 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 10-MAR-2006 28-APR-2006 113451 USA 47 1A02 030102 * 6051 * L87 D8 80395
AWS Claim Key: 9037707 Trx Code: E72 Labor Hrs: 21.2
Dlr Cd-Sub Cd: 20681 - * Name: DOWNS FORD LINCOLN-MERCURY Ph: 732-3492240 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:04-MAR-2010 Doc #:04439552
Cust Comments: C S THERE IS COOLANT IS PUSHING OUT THROUGH THE DEGAS BOTTLE CAP (HEAT DOES NOT COME OUT UNTIL THE VEHICLE IS DRIVEN), ALSO CK FOR OIL LEAKS
Tech Comments: CK FOR OIL LEAK, VERIFIED MTIME WASHED DOWN ENG ADDED DYE AND ROAD TEST CK FOUND LEAKAGE FROM HOTSIDE CAC TUBE, CK AND TEST COOLING SYSTEM PER TSB 090803,TEST EGR COOLER AND OIL COOLER ON VEH,FOUND OK,ROAD TEST AND MONITORED COOLING SYSTEM TEMPS FOUND FAILED HEAD GASKETS, R&R NECHARDWARE & HEADS,CK HEAD & BLOCK SURFACES FOUND OK,INST NEW GASKETS, FLUHED COOLING SYSTEM, CHANGED OIL AND FILTER,REPL
1FTWW31P26ED20843 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 10-MAR-2006 28-APR-2006 113451 USA 48 2G02 130101 F81Z 9278 AA L65 D1 80778
AWS Claim Key: 9068051 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 20681 - * Name: DOWNS FORD LINCOLN-MERCURY Ph: 732-3492240 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:29-MAR-2010 Doc #:04596151
Cust Comments: C S THERE IS AN ENGINE OIL LEAK TOWED TO SHOP **PT**
Tech Comments: CK AS NEC FOUND OIL PRESS SENDER LEAKS, R&R NEC HARDWARE AND REPL SENDER, MTIME WASHED DOWN ENG AND UNDER CARRIAGE
Thanks!
Ryan
Not to be a pain, but could you run one more?
1FTWW31R68ED02768
Thanks
Ryan
OASIS RESULT:
1FTWW31R68ED02768
USA
EN
05/03/2010
16:14:25
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2008 F-SERIES BODY STYLE
6.4L TC DIESEL V8
TRANSMISSION
TORQSHIFT AXLE CODE
8F716A0A
PAINT COLOR
AM/FM STR/CD/CLK/NAVIG SYSTEM GROSS VEHICLE WEIGHT
11,400 LB. GVW
AXLE RATIO
8X20" PREM FORGED POL ALUM WHL FRONT TIRE
LT275/65R 20E A/T OWL
WARNING MESSAGES
ARN MESSAGES
WARRANTY START DATE
12/20/2007 BUILD DATE
12/11/2007 SALE MILEAGE
00012 New Vehicle Base Warranty
EXTENDED COVERAGES
NO RECENT REPAIR HISTORY ON VEHICLE
| On-line 1878
END OF OASIS REPORT FOR 1FTWW31R68ED02768
Standard Claims List For Model Year 2008
1FTWW31R68ED02768 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 11-DEC-2007 20-DEC-2007 113465 USA 7 2E02 * * * * * * 9270
AWS Claim Key: 1135003 Trx Code: 08B03 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 20636 - * Name: SCHULTZ FORD LINCOLN MERCURY, INC. Ph: 845-6243600 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:07-JUL-2008 Doc #:24452002
Cust Comments: CUSTOMER STATES PERFORM RECALL 08B03
Tech Comments: PERFORM REVCALL 08B03...RS... 1
1FTWW31R68ED02768 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 11-DEC-2007 20-DEC-2007 113465 USA 11 1F01 * * * * * * 15430
AWS Claim Key: 1858917 Trx Code: 08B06 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 20636 - * Name: SCHULTZ FORD LINCOLN MERCURY, INC. Ph: 845-6243600 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:27-OCT-2008 Doc #:24836403
Cust Comments: CUSTOMER STATES PERFORM RECALL 08B06 ADD ON RS.
Tech Comments: PERFORM RECALL 08B06...RS...
1FTWW31R68ED02768 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 11-DEC-2007 20-DEC-2007 113465 USA 14 2G01 * * * * * * 19819
AWS Claim Key: 2448948 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 20636 - * Name: SCHULTZ FORD LINCOLN MERCURY, INC. Ph: 845-6243600 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:13-JAN-2009 Doc #:25087702
Cust Comments: CUSTOMER STATES PERFORM CAMPAIGN 08B07 REPROGRAM
Tech Comments: PERFORM OPEN CAMPAIGN 8U7A 12A650 MC TCM 8C3A 12B565 CA ICM 9C3T 14C026 DC
