I called my local dealer and could not get the oasis report from them. If anyone could provide one I would greatly appreciate it.
Thanks.
1FTWW31P36EB15547
OASIS RESULT: 1FTWW31P36EB15547 USA: EN 16-JANUARY-2013 / 05:33:55 EST/ APP2
Local Time: 16-JANUARY-2013 / 3:33:59 AM
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2006 F-SERIES
BODY STYLE: F-350 CREW CAB 4X4
ENGINE: 6.0L OHV Diesel V8
TRANSMISSION: 5 Speed Auto 5R110W - HI/Torque
AXLE CODE: 3L
ENGINE CALIBRATION: 6F710D0A
PAINT COLOR: Oxford White WB C/C
PAINT CODE: Z1
RADIO: With AM/FM CD Player
AXLE RATIO: 3.73 Ratio
WHEEL SIZE: 18 X 8 Polished Alum Wheel
FRONT TIRE: LT 275/70R18E A/S BSW
GROSS VEHICLE WEIGHT: 11,500 LB. GVW
CLAIMS:
Customer Concern Code E68-FUEL TANK LEAK/ODOR
Condition Code 42-DOES NOT OPERATE PROPERLY
Technician Comment PULLED WATER SEPERATOR AND INSPECTED, REPLACED OUT SECTION THAT CONTAINED DRAIN PLUG. CODE C2
Customer Comment REPAIR CUSTOMER STATES FUEL WATER SEP THREADS STRIPT
Customer Concern Code D50-OTHER ENGINE TROUBLES
Technician Comment 99415 EGR COOLER FAILED. DIAG PER TSB 08 11 03.PRESSURE TEST COOLING SYSTEM LOST PRESSURE. NO VISIBLE LEAKS. INSTALLED RADKIT DID NOT HOLD VACUUM. REMOVED EGR COOLER PERFORMED LEAK TEST FAILED. CHECKED OIL COOLER WITH RADKIT, PASSED. ROAD TEST WITH GAUGE SET UP IN COOLING SYSTEM PRESSURE WAS WITHIN SPEC. ECT EOT WAS WITHIN SPEC. FLUSH COOLING SYSTEM. CHANGED OIL AND
Customer Comment CUSTOMER STATES THE ENGINE IS BLOWING WHITE SMOKE,CHECK AND ADVISE
