Looking at a 2005 Excursion.
VIN = 1FMSU45PX5EA49464
I would be extremely grateful if someone could help me by running an Oasis report on the vehicle.
Thanks in advance, Damon.
OASIS RESULT: 1FMSU45PX5EA49464 USA: EN 22-JANUARY-2013 / 00:51:54 EST/ APP1
Local Time: 21-JANUARY-2013 / 10:51:59 PM
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2005 EXCURSION
BODY STYLE: 4 DR EDDIE BAUER 4X4
ENGINE: 6.0L OHV Diesel V8
TRANSMISSION: 5 Speed Auto 5R110W - HI/Torque
AXLE CODE: C1
ENGINE CALIBRATION: 5L110N0A
PAINT COLOR: Ebony Solid C/C
PAINT CODE: UA
RADIO: AM/FM CD Changer/Clock
AXLE RATIO: 3.73 Ratio
WHEEL SIZE: 7.0 X 16" 6 Window Aluminum Wheel
FRONT TIRE: LT265/75R-16E OWL A-T Tire
GROSS VEHICLE WEIGHT: 9200 LB. GVW
CLAIMS:
Customer Comments DRIVER'S SIDE DOOR EXTERIOR TRIM PANEL DETACHING FROM DOOR
Tech Comments REPLACED EXTERIOR DOOR TRIM. M TIME: NO SLTS FOR THIS LABOR OP.
Customer Comments RECALL AS PER FORD
Tech Comments RECALL 05E15 AS PER FORD
Tech Comments RECALL 05B32 AS PER FORD
Tech Comments RECALL 59B01 AS PER FORD
Customer Comments CHECK LACK OF POWER AND RUNNING VERY ROUGH
Tech Comments ENGINE PROFORMANCE TESTS PINPOINT TOO PLUGED EGR VALVE REMOVE VALVE CLEAN
Customer Comments BLACK SMOKE WONT EXCELERATE CHECK ENGINE LIGHT ON
Tech Comments FOUND TSB 06 17 01 REMOVE EGR VLAVE AND TURBO ATTEMPT TOO CLEAN BOTH EGR OK REPLACE TURBO REPLACE OIL TUBE WITH UPDATED PART UPDATE PCM
Customer Comments CHECK ENGINE STUBBLES AND SURGES AT IDEL AND UNDEREXCELL
Tech Comments ENGINE TESTS PINPOINT TOO EGR VALVE REPLACE EGR VALVE AND CLEAN PORTS
Customer Comments ENGINE LEAKS OIL
Tech Comments FOUND HIGH PRESSURE OIL LINE LEAKING REPLACED LINE
Thanks so much Fred. I think I will be giving this one a miss. Looks like more than enough history with the EGR for my liking. Who knows what else was affected also?
