Hey guys looking for a Oasis report for a buddy looking to get a 6.0l
Vin - 1FTSX31P53ED40799
THANK YOU AGAIN!!!!
OASIS RESULT: 1FTSX31P53ED40799 USA: EN 16-JANUARY-2013 / 06:16:42 EST/ APP1
Local Time: 16-JANUARY-2013 / 4:16:46 AM
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2003 F-SERIES
BODY STYLE: F-350 S/CAB PICKUP 4X4
ENGINE: 6.0L OHV Diesel V8
TRANSMISSION: 5 Speed Auto 5R110W - HI/Torque
AXLE CODE: D1
ENGINE CALIBRATION
PAINT COLOR: Dark Toreador Red
PAINT CODE: FN
RADIO: AM/FM CD Changer/Clock
AXLE RATIO: 3.73 Ratio
WHEEL SIZE
FRONT TIRE: LT265/75R-16E OWL A-T Tire
GROSS VEHICLE WEIGHT: 9900 LB. GVW
CLAIMS:
Customer Comments CHECK ON FUEL LEAK
Tech Comments RETURN LINR FROM FUEL LINE NOT SECURED PROPERLY RESCUE AND RE INSTALL SAFETY CLIP WASH ENGINE AREA
Customer Comments INSP FOR SQUEAKING NOSIE WHEN IDLEING NOISE IS HAPPEN NOW WHEN RUNNING
Tech Comments VERIFY SQUEAKING.PROBLEM IS NOISY V BELTS. REMOVE FAN CLUTCHTO ACCESS BELTS.REPLACE INNER AND OUTTER BELTS. RECHECK OK
Customer Comments 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE
Tech Comments PERFORM RECALL 59B01.
Customer Comments CHECK FOR SQUEAL IN ENGINE COMPARTMENT
Tech Comments INSPECT ENGINE COMPARTMENT,CHECK OASIS,CONTACT HOTLINE, REPLACE PULLEY AS PER TSB 05 13 16.RECHECK, OK.
Customer Comments 06E17 CONTROL MODULE RECALIBRATION
Tech Comments PERFORM RECALL 06E17.
Customer Comments REAR SEAT BELT INOP
Tech Comments VERIFY REAR SEAT BELT ASSEMBLEY DOES NOT WORK.INSTALL NEW REAR SEAT BELT ASSY KIT NOT BUCKLING.RECHECK, OK.
Customer Comments TOWED IN ENGINE SIEZED
Tech Comments INSPECT AND DIAG UNABLE TO TURN OVER REMOVE ENGINE WITH TORQUE CONVERTOR DISSASSEMBLE AND PERFORM TEARDOWN CRANK THRUST BEARING GONE AND FILINGS EVE RYWHERE CRANKSHAFT BROKEN METAL IN OIL FILTER AND ASSY REPLACE ENGINE AS SY REPLACE REAR YPIPE TUBE CRACKED INSTALL NEW FLEX PLATE CRACKED RO ADTEST ALL OK
Customer Comments NO POWER WHAT SO EVER INSPECT LOUD BANG YESTERDAY THEN NO POWER
Tech Comments PERFORM DIAG AS PER TSB 07 16 01,REPLACE TURBO(OVER BOOSTI NG),CAC BLEW OPEN FROM OVER BOOST, REPLACE
