Check the VIN to make sure it is correct.
Soory - Wrong VIN
I had two sitting on my desk and gave you the wrong one. The correct one is: 1FTSW21P05ED01764
Sorry
Standard Claims List For Model Year 2005
1FTSW21P05ED01764 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-APR-2005 28-JUN-2005 124476 USA 6 6N04 010802 5C3Z 16720 VA B62 30 6956
AWS Claim Key: 2856861 Trx Code: 2 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04798 - * Name: WEIKERT FORD INC Ph: 863-6767944 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:20-DEC-2005 Doc #:13120701
Tech Comments: PEELING REPLACED THE EMBLEM THE PASS FRONT
1FTSW21P05ED01764 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-APR-2005 28-JUN-2005 124476 USA 7 2E05 100106 6C3Z 9B249 A G29 42 8216
AWS Claim Key: 3162870 Trx Code: 2 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04798 - * Name: WEIKERT FORD INC Ph: 863-6767944 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2006 Doc #:13190301
Tech Comments: WATER IN FUEL MODULE BAD REPLACED WATER IN FUEL MODULE
1FTSW21P05ED01764 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-APR-2005 28-JUN-2005 124476 USA 16 2E05 100106 6C3Z 9B249 A D50 42 19712
AWS Claim Key: 6022391 Trx Code: E90 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 04798 - * Name: WEIKERT FORD INC Ph: 863-6767944 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-OCT-2006 Doc #:13859301
Tech Comments: BAD FUEL MODULE SERVICE REPLACE FUEL MODULE
1FTSW21P05ED01764 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-APR-2005 28-JUN-2005 124476 USA 16 * * * * * * * 19712
AWS Claim Key: 6022389 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04798 - * Name: WEIKERT FORD INC Ph: 863-6767944 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-OCT-2006 Doc #:13859303
Tech Comments: OPEN RECALL PERFORMED RECALL
AWS Claim Key: 6022390 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04798 - * Name: WEIKERT FORD INC Ph: 863-6767944 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-OCT-2006 Doc #:13859302
Tech Comments: OPEN RECALL PERFORM RECALL
1FTSW21P05ED01764 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-APR-2005 28-JUN-2005 124476 USA 19 7K11 130101 5C3Z 10849 RD G32 42 29880
AWS Claim Key: 7199111 Trx Code: S07 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 04798 - * Name: WEIKERT FORD INC Ph: 863-6767944 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2007 Doc #:14121101
Tech Comments: CLUSTER INOP REMOVED DASH PANEL TO REPLACE INTRUMENT CLUSTER TO CORRECT
1FTSW21P05ED01764 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-APR-2005 28-JUN-2005 124476 USA 30 2E01 03XXXX 4C3Z 9B246 A D50 42 52479
AWS Claim Key: 9002326 Trx Code: E72 Labor Hrs: 10.7
Dlr Cd-Sub Cd: 04798 - * Name: WEIKERT FORD INC Ph: 863-6767944 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:19-NOV-2007 Doc #:14915301
Tech Comments: COMING APART PERFORMED DIAG. REMOVED HIGH PRESSURE OIL PUMP TO REPLACE COUPLER ON BACK OF OIL PUMP. ALSO REPLACED LEAKING ORING AND UPDATED PCM TO LATEST CALIBRATION
1FTSW21P05ED01764 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-APR-2005 28-JUN-2005 124476 USA 39 1A02 030102 * 6051 * D50 42 72069
AWS Claim Key: 10309033 Trx Code: E72 Labor Hrs: 10.2
Dlr Cd-Sub Cd: 04798 - * Name: WEIKERT FORD INC Ph: 863-6767944 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:26-AUG-2008 Doc #:00245701
Cust Comments: CHECK DRIVABILITY ISSUE CUSTOMER STATES CK FOR WHITE SMOKE FROM FROM TAILPIPE WHEN STARTEDAFTER SITTING
Tech Comments: LEAKING ENGINE OIL COOLER CP: 6051 PERFORM DIAGNOSIS,REPLACE LEAKING ENGINE OIL AND LEAKING EGR COOLER.DURING ROAD TEST IPR FAILED, REPLACE IPR
1FTSW21P05ED01764 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-APR-2005 28-JUN-2005 124476 USA 40 2E03 0304XX 5C3Z 9C968 CA D50 42 73388
AWS Claim Key: 10406845 Trx Code: E72 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 04798 - * Name: WEIKERT FORD INC Ph: 863-6767944 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:22-SEP-2008 Doc #:00307401
Cust Comments: CHECK DRIVABILITY ISSUE CUSTOMER STATES CK VEHICLE SHUTS OFF WHILE DRIVING
Tech Comments: IPR VALVE FAILED PERFORM DIESEL NO START DIAGNOSIS,CODE P2291 FOUND SCREEN BLOWN OUT OF IPR,REPLACE IPR TO CORRECT
