found this 7.3L in the area, thinking about getting it
1FTNW21FX1ED84456
Thanks,
Robert
Standard Claims List For Model Year 2001
1FTNW21FX1ED84456 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 31-MAY-2001 26-SEP-2001 171498 USA 0 6R01 012001 1C3Z 2561203 CAC S25 42 6
AWS Claim Key: 3436594 Trx Code: 1 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07941 - * Name: HERITAGE FORD Ph: 209-5295110 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-JUL-2001 Doc #:06191051
Cust Comments: PERFORM RECALL 01S21 LEFT BUCKLE FAILED, RIGHT BUCKLE PASSED.
Tech Comments: SEAT BELT RECALL R&R LEFT BUCKLE
1FTNW21FX1ED84456 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 31-MAY-2001 26-SEP-2001 171498 USA 19 2G02 030701 F7TZ 12K073 A D21 42 46500
AWS Claim Key: 14120033 Trx Code: S07 Labor Hrs: 4
Dlr Cd-Sub Cd: 07941 - * Name: HERITAGE FORD Ph: 209-5295110 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2003 Doc #:01122651
Cust Comments: REPORTS THAT VEHICLE HAS BEEN STALLING OUT WHILE DRIVING
Tech Comments: PERFORM DIESAL PERFORMANCE DIAG KOEO PASS KOER PASS INJECTOR ELECTRICAL PASS KOER PASS ICP PASS IDLE STABILITY PASS CRANKCASE PRESSURE PASS EXHAUST INLRT RESTRICTION PASS ROAD TEST MONITOR PIDS CMP VOLTAGE ERATIC ONE TIME NO CODES REPLACED CMP SENSOR
1FTNW21FX1ED84456 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 31-MAY-2001 26-SEP-2001 171498 USA 42 2A01 031202 YC3Z 6C640 KA L65 D8 97133
AWS Claim Key: 19663141 Trx Code: E72 Labor Hrs: 3.9
Dlr Cd-Sub Cd: 07941 - * Name: HERITAGE FORD Ph: 209-5295110 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-FEB-2005 Doc #:05592251
Cust Comments: CUST STATES OIL LEAK CK AND ADVISE
Tech Comments: REMOVED BEAUTY COVER,MAP SENSOR AND NOSE.REMOVED AIR FILLER DUCT TO TURBO.REMOVED BULKHEAD ENGINE HARNESS CONNECTOR, REMOVED AND REPLACED ALL CAC HOSES,REMOVED COMPRESSOR MANIFOLD AND REPLACED COMPRESSOR MANIFOLD HOSES. STEAM CLEAN, ROAD TEST AND RECHECKED OK NOW
07s57 cmp recall open and 09s09 cruise control recall open
Reactions: Robert S.
