Standard Claims List For Model Year 2002
1FTNW20FX2EA27054 T/F7 F T/BC T/BD T/B A1 T/D8 T/DS 14-AUG-2001 08-OCT-2001 152031 USA 1 2G02 030701 F7TZ 12K073 A D36 28 389
AWS Claim Key: 238364 Trx Code: S07 Labor Hrs: 4.2
Dlr Cd-Sub Cd: 01618 - * Name: HILLCREST FORD LINCOLN Ph: 936-2953784 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:11-OCT-2001 Doc #:00416251
Cust Comments: DRIVING 60 MPH TRUCK ACTS LIKE GOING TO DIE WAS STOPPED FOR LUNCH AT IDLE ENG DIED
Tech Comments: INOP REPLACED CAM SENSOR
1FTNW20FX2EA27054 T/F7 F T/BC T/BD T/B A1 T/D8 T/DS 14-AUG-2001 08-OCT-2001 152031 USA 1 7M01 150102 * 18806 * A07 28 911
AWS Claim Key: 235390 Trx Code: 2 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 01618 - * Name: HILLCREST FORD LINCOLN Ph: 936-2953784 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:16-OCT-2001 Doc #:00439651
Cust Comments: RADIO CUTS OF AND ON AT TIMES
Tech Comments: INOP RADIO REMOVE
1FTNW20FX2EA27054 T/F7 F T/BC T/BD T/B A1 T/D8 T/DS 14-AUG-2001 08-OCT-2001 152031 USA 1 7M01 150102 * 18C868 * A07 42 911
AWS Claim Key: 1778862 Trx Code: 2 Labor Hrs: 0
Dlr Cd-Sub Cd: 67701 - * Name: VISTEON AFTERMARKET-U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:16-OCT-2001 Doc #:76814908
Tech Comments: REQUESTING DEALER'S P/A CODE 01618
1FTNW20FX2EA27054 T/F7 F T/BC T/BD T/B A1 T/D8 T/DS 14-AUG-2001 08-OCT-2001 152031 USA 1 7M01 150102 * 18806 * A07 42 2790
AWS Claim Key: 294106 Trx Code: 1 Labor Hrs: 0
Dlr Cd-Sub Cd: 04511 - * Name: MAC HAIK FORD Ph: 713-9325000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:06-NOV-2001 Doc #:155758A
Cust Comments: A07 RADIO GOES OFF ,SOMETIMES WHEN HEADLIGHTS TURNED ON OR PWR WINDOWS USED
Tech Comments: 2790 EXCHANGED RADIO RS&S INV 41965
1FTNW20FX2EA27054 T/F7 F T/BC T/BD T/B A1 T/D8 T/DS 14-AUG-2001 08-OCT-2001 152031 USA 19 6D01 011001 * 2862900 * S50 D4 35928
AWS Claim Key: 5472795 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: 04511 - * Name: MAC HAIK FORD Ph: 713-9325000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:24-APR-2003 Doc #:189375A
Cust Comments: S50 MATERIAL ON PASS SIDE FRONT SEAT CUSHION IS LOOSE.
Tech Comments: 35928 R&I COVER AND PAD AND REBUILD PAD AT LEFT REAR CORNER
1FTNW20FX2EA27054 T/F7 F T/BC T/BD T/B A1 T/D8 T/DS 14-AUG-2001 08-OCT-2001 152031 USA 33 2C01 030603 2C3Z 11002 AA D50 42 74995
AWS Claim Key: 10393774 Trx Code: 0711D Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04511 - * Name: MAC HAIK FORD Ph: 713-9325000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:01-JUN-2004 Doc #:212395A
Cust Comments: D50 STARTER HANGS UP AT TIMES
Tech Comments: 74995 STARTER CHECK STARTING OPERATION. CHECK VOLTAGE SUPPLY TO STARTER. SUPPLY IS GOOD. DETERMINED STARTER WAS NO GOOD. REPLACE STARTER AND RECHECK OPERA TION. STARTING SYSTEM WORKING PROPERLY
1FTNW20FX2EA27054 T/F7 F T/BC T/BD T/B A1 T/D8 T/DS 14-AUG-2001 08-OCT-2001 152031 USA 79 * * * * * * * 170905
AWS Claim Key: 16739024 Trx Code: 07S57 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04511 - * Name: MAC HAIK FORD Ph: 713-9325000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:21-MAR-2008 Doc #:036880A
Cust Comments: A99 RECALL 07S57 CMP SENSOR
Tech Comments: 170905 RECALL REPLACE CAM SENSOR
1FTNW20FX2EA27054 T/F7 F T/BC T/BD T/B A1 T/D8 T/DS 14-AUG-2001 08-OCT-2001 152031 USA 106 * * * * * * * 213644
AWS Claim Key: 17830305 Trx Code: 09S09 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04511 - * Name: MAC HAIK FORD Ph: 713-9325000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-MAY-2010 Doc #:068713C
Cust Comments: PERFORM RECALL 09S09
Tech Comments: 213644 PERFORM RECALL 09S09,INSPECT CONNECTOR,O.K.INSTALL JUMPER HARNESS. 09S09B 0.2
