07S57
CAMSHAFT POSITION (CMP) SENSOR INSPECTION / REPLACEMENT
09S09
SPEED CONTROL SYSTEM MODIFICATION
Standard Claims List For Model Year 2001
1FTNX21F41EC42021 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 21-FEB-2001 30-MAR-2001 123206 USA 11 * * * * * * * 33637
AWS Claim Key: 6512937 Trx Code: 01S21 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 03947 - * Name: CONLEY FORD, INC. Ph: 870-8562788 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:25-JAN-2002 Doc #:0239392
Cust Comments: RECALL 01S21
Tech Comments: CHECK BUCKLES, RIGHT BUCKLE FAILED, INSTALL BUCKLE
1FTNX21F41EC42021 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 21-FEB-2001 30-MAR-2001 123206 USA 11 5A09 0502XX E8TZ 4676 B L86 D8 33637
AWS Claim Key: 6512936 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 03947 - * Name: CONLEY FORD, INC. Ph: 870-8562788 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:25-JAN-2002 Doc #:0239391
Cust Comments: REAR PINION SEAL IS LEAKING
Tech Comments: CONFIRMED, R R DRIVELINE AND REPLACE SEAL
1FTNX21F41EC42021 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 21-FEB-2001 30-MAR-2001 123206 USA 12 2I04 NANANA F81Z 12B533 AC D03 42 49372
AWS Claim Key: 7547523 Trx Code: E72 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 03947 - * Name: CONLEY FORD, INC. Ph: 870-8562788 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:22-MAR-2002 Doc #:0082781
Cust Comments: HARD STARTING COLD
Tech Comments: CONFIRMED HARD START COLD,NGS HOOK UP,RETRIVE & CLEAR KOEO,KOER,CHECK GLOW PLUG RELAY,POWERS AND GROUNDS(OK)RELAY BAD,R&R RELAY,RETEST (OK)
Reactions: ash_flat_diesel
