vin #1FMSU41P63EC79554
thank you
OASIS RESULT:
1FMSU41P63EC79554
09/17/2006
23:37:39
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 EXCURSION BODY STYLE
XLT 4 DR WAGON 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/31/2003 BUILD DATE
03/27/2003 SALE MILEAGE
00047
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0759 - USA 2004 NEW 72/100,000 PREMIUMCARE W/ROADSIDE ASSIST
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: STEPHEN BARTLEY
OPTIONS: $100,DED.
EXPIRATION DATE: 05/31/2009
DISTANCE: 100,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 05574
ESP CONTRACT START DATE: 05/31/2003
REPAIR HISTORY
07/24/2006
DEALER: Sunrise Ford
WARRANTY CLAIM NUMBER: 033208 ODOMETER: 067139M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6K682BARM TURBO CHG-EXH DRIVE 001 6005F 42 DOES NOT OPERATE PROPERLY
3C3Z 6766BA CAP ASY OIL FILLER 001 6005F1
PM 15 002 6005F1X1
3C3Z 9E527AE NOZZLE ASY-FUEL INJE 001 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F19
000 6005F20
000 6005F22
000 6005F23
000 6005F25
000 9438A
000 9438AZW
000 9438A3
000 9527AL
67202 #2 INJECTOR AND TURBO ASSY 11.1HRS 6005F0.4 F10.1 F1X10.1 F20.1 F60.1 F80.6 F90.1 F110.1 F120.4 F130.2 F140.1 F180.6 190.3 F200.1 F210.3 F220.1 F230.4 F251.2 F330.2 12650D450.3 D470.1 D810.5 D840.5 9438A1.8 AZN0.1 A30.6 9527AL1.7 CHECK ENGINE,CHASSIS,FUEL,AND OIL LEVEL,ALL OK. PERFORM ALL KOE O AND KOER ON DEMAND SELF TEST FOR CODES,P0266,P2262. CHECK INTAKE AND EXHAU
06/27/2006
WARRANTY CLAIM NUMBER: 031124 ODOMETER: 065706M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6005F 68 SEALER MISSING/SKIPPED
3C3Z 9P456AE COOLER - EGR 001 6005F1
3C3Z 9424AE INTAKE MANIFOLD 001 6005F1X1
3C3Z 12A697AA AIR CHARGE TEMP SENS 001 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F19
000 6005F20
000 6005F21
000 6005F22
000 6005F23
000 6005F25
000 12650D30
000 9424A
000 9424A1
65706 EGR COOLER ASSY. 12.3HRS 6005F0.4 F10.1 F1X10.1 F20.1 F60.1 F80.6 F90 .1 F110.1 F120.4 F130.2 F140.1 F180.6 F190.3 F200.1 F210.3 F220.1 F230.4 F 251.4 12650D300.5 D450.3 D810.5 D840.5 9424A4.5 A10.5 CHECK ENGINE,CHASSIS, FUEL,AND OIL LEVEL,ALL OK. PERFORM ALL KOEO AND KOER ON DEMAND SELF TEST FO R CODES,P0401. CHECK INTAKE AND EXHAUST FOR RESTRICTION,8,13. CHECK EGR VAL
06/27/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9N693HA RING-SEALING 001 6007D 68 SEALER MISSING/SKIPPED
3C3Z 9N693JA RING-SEALING 001 6642A
VC 7B 003 9278A
OSP 003 3674A
3C3Z 6A642AA COOLER CRANKCASE OI 001
F81Z 9278AA SENDER-OIL PRES 001
OSP 002
65706 OIL COOLER,SENSOR,AND ORINGS. 6007D0.5 6642A4.8 9278A0.7 3674A1.9 7.9 HRS HAD TO ADD OIL DYE AND CHECK WITH BLACK LIGHT, FOUND O RINGS AND OIL PR ESSURE SENDER WAS LEAKING OIL, ALSO FOUND OIL IN COOLANT. HAD TO R&R POWERS TEERING PUMP TO ACCESS AND REMOVE SENSOR AND REPLACE BROKEN ORINGS. REPLAC E OIL PRESSURE SENSOR. REPLACE OIL COOLER DUE TO OIL IN COOLANT. HAD TO FLU
06/10/2006
WARRANTY CLAIM NUMBER: 029917 ODOMETER: 064167M
LABOR OP
CONDITION CODE
CONDITION DESC
3C7Z 10D898AA DISPLAY MODULE 001 12651D 42 DOES NOT OPERATE PROPERLY
000 12651D2
000 MT10898
64167 OVERHEAD DISPLAY 12651D 12651D2 PLUS M-TIME 1.4 TOTAL DIAG AND CHECKED ALL FUSES AND CONNECTORS, TESTED ALL COMPONENTS AND REMOVED OVERHEAD CONS OLE , TESTED ALL WIRES AND CONNECTORS AT OVER HEAD MODULE AND WAS NECESSARY TO REPLACE, REPROGRAM USING AS BUILT DATA AND VARIFIED OPERATION FOR OVERH EAD MODULE.
05/09/2006
WARRANTY CLAIM NUMBER: 027604 ODOMETER: 062270M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 10346AA ALTERNATOR LESS PULL 001 10200AB 42 DOES NOT OPERATE PROPERLY
000 10346A
62270 ALTERNATOR 10200AB,13346A,10654CA 2.2 PERFORMED DIAG. FOUND ALT VOLTS LOW 12.6 CHECK OUT AND CHARGED BATTERIES, ALTERNATOR REPLACED OUT PUT VOL S 14.3 OK AFTER REPAIR
05/09/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6584BA GASKET VALVE ROCKER 001 6584AL 68 SEALER MISSING/SKIPPED
3C3Z 12A690AA WIRING ASY EC SENSOR 001 6646AC
6C3Z 6C640A CONNECTION A/C DUCT 001 MT12690
6C2Z 6K786AA CLAMP AIR COOLING 002
3C3Z 6582BA COVER ASY-VALVE ROCK 001
62270 SEVERAL CONCERNS 6.0 CHECKED FOR OIL LEAKS CHECKS FOUND OIL LEAKING F OUND LEFT SIDE GLOWPLUG WIRING LOOM, VALVE COVER AND CAC HOSE HOT AT TURBO. REMOVED VALVE COVER AND FOUND VALVE COVER NOT STRAIGHT SLIGHTLY WARPED. M- TIME REQUIRED TO REPLACE GLOWPLUG WIRING LOOM. INSTALLED NEW VALVE COVER ON LEFT SIDE WITH NEW GASKET. INSTALLED NEW CAC HOSE AND CLAMPS. RETEST NOW OK
03/25/2006
WARRANTY CLAIM NUMBER: 024164 ODOMETER: 058499M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9E527AE NOZZLE ASY-FUEL INJE 002 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 9527AT
000 6005F19
000 6005F20
000 6005F21
000 6005F22
58505 9.5 PERFORM DIESEL ENGINE DIAG FOR ENGINE PERFORMANCE. KOEO KOER AND ON-DEMAND TESTING. PERFORM ALL AIR FUEL AND EXHAUST PRESSURE AND RESTRICTI ON TESTING. TEST OIL FOR AERATION AND CONTAMINATION. TEST FUEL PRESSURE AT BOTH HEADS AND PUMP. PERFORM EGR VGT AND IPR FUNCTION TESTS. PERFORM INJECT OR BUZZ TEST AND CYLINDER BALANCE TEST HOT AND COLD ACCORDING TO TSB 06-2-1
03/25/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 06E17B
58499 .7 REFLASH MODULES AS PER RECALL
03/25/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
58499 .3 PERFORM ROAD TEST
END OF OASIS REPORT FOR 1FMSU41P63EC79554
Standard Claims List For Model Year 2003
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 0 1F03 030304 * 8287 * E23 D1 6
AWS Claim Key: 909469 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05574 - * Name: PALM SPRINGS FORD LINCOLN MERCURY Ph: 760-3282102 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:04-APR-2003 Doc #:141911A
Cust Comments: VEH HAS COOLANT LEAK & OVERHEATS
Tech Comments: RMV UPPER & LOWER HOSES,CLEAN COOLANT INLET & OUTLET.CLEAN HOSES AND REINSTALL & REFILL COOLANT
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 3 6Y20 0003XX * 19D520 * B6* 30 7842
AWS Claim Key: 2753622 Trx Code: 2 Labor Hrs: 2.8
Dlr Cd-Sub Cd: 05439 - * Name: FIESTA FORD, INC. Ph: 760-7728000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-AUG-2003 Doc #:00250151
Cust Comments: HITCH ASY. SPO TECH 105 PIN HOLSE WEARING OUT. INSTALL HITCH. HITCH ORDERED R.O. 1976, 08 21 03, 7254 MILES REPLACE AS PER GARY B.
Tech Comments: WORN PIN HOLES M TIME 2.8 TO REMOVED FUEL TANK,CUT OFF RIVETS . RENEW HITCH REASS
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 8 * * * * * * * 17047
AWS Claim Key: 4235363 Trx Code: 03E03 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05574 - * Name: PALM SPRINGS FORD LINCOLN MERCURY Ph: 760-3282102 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-JAN-2004 Doc #:168406A
Cust Comments: RECALL 03E03
Tech Comments: 17047 RECALL RECALL PERFORMED PCM, TCM AND FICM RECLAIBRATION TO LATEST CALIBRATION SPECS AS PER RECALL INSTRUCTIONS.
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 8 6H08 011108 1C3Z 2523208 AA G05 41 17047
AWS Claim Key: 4235364 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 05574 - * Name: PALM SPRINGS FORD LINCOLN MERCURY Ph: 760-3282102 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-JAN-2004 Doc #:168406B
Cust Comments: BOTH FRT WINDOWS CHATTER GOING UP AND DOWN
Tech Comments: 170056 41 2523208 2523209 WARRANTY VERIFIED BOTH FRONT WINDOWS CHATTER GOING UP AND DOWN. REMOVED BOTH DRIVERS AND PASSENGERS DOOR PANELS TO INSPECT FOUND DRIVERS AND PASSENGERS WINDOW REGULATORS STICKING BINDING. NECESSARY TO REMOVE AND REPLACE DRIVERS AND PASSENGERS WINDOW REGULATORS. TRANSFER DRIVERS AND PASSENGERS WINDOW MOTORS TO NEW REGULATORS. RE INSTALL
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 8 6F33 010702 * 5420708 * B63 33 17047
AWS Claim Key: 4235365 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 05574 - * Name: PALM SPRINGS FORD LINCOLN MERCURY Ph: 760-3282102 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-JAN-2004 Doc #:168406C
Cust Comments: DRIVERS SIDE FRT DOO MOLDING RUNNING ALON BOTTOM OF DOOR IS LOOSE
Tech Comments: 170056 33 7825324 WARRANTY VERIFIED MOULDING ALONG BOTTOM OF DRIVERS DOOR LOOSE. INSPECTED AND FOUND PUSH PINS MISSING CAUSING LOOSE CONDITION. NECESSARY TO REPLACE PUSH PINS. VERIFIED REPAIR OK. THANK YOU AND HAVE A NICE DAY.
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 8 6N01 010805 * 5425556 * B63 33 17047
AWS Claim Key: 4235366 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 05574 - * Name: PALM SPRINGS FORD LINCOLN MERCURY Ph: 760-3282102 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-JAN-2004 Doc #:168406D
Cust Comments: DRIVERS SIDE REAR DOOR MOLDING ALONG INSIDE TOP OF DOOR IS LOOSE
Tech Comments: 170056 33 26247A50 WARRANTY VERIFIED DRIVERS SIDE REAR UPPER MOULDING LOOSE HANGING OFF. INSPECTED AND FOUND PUSH PINS HAD FALLEN OUT CAUSING LOOSE CONDITION. REPLACED PUSH PINS AND VERIFIED REPAIR OK. THANK YOU AND HAVE A NICE DAY.
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 14 7A01 140101 BXT 65 750 D03 42 26721
AWS Claim Key: 6810103 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05439 - * Name: FIESTA FORD, INC. Ph: 760-7728000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:14-JUL-2004 Doc #:03143651
Cust Comments: SLOW CRANK, NO CRANK.
Tech Comments: WEAK BATTERIES. BATTERY,CHARGING TESTS RENEW BOTH BATTERIES. ACES XE16P,
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 14 2G05 031405 * RECAL * D42 42 26721
AWS Claim Key: 6810104 Trx Code: E84 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 05439 - * Name: FIESTA FORD, INC. Ph: 760-7728000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:14-JUL-2004 Doc #:03143653
Cust Comments: LACK ON POWER. CHECK ENGINE LIGHTS COMES ON WHILE DRIVING.
Tech Comments: RETEST EEC OK.(FICM #K2Z2 17)AND ADD TO PERFORM DIAGNOSTICS STEPS FROM PERFORMANCE CHART OPERATION CODES 6005F F1,F1X1,F2,F6,F7,F8,F9,F10,F11,F12,E13,E14,F16,F18,F19.AND ADD TO ROADTEST OK.NOTE CUSTOMER MODIFIED EXHAUST TAIL PIPE,MUFFLER ASSEMBLY AND HALFE OT TAIL PIPE IS GONE, .TURBO TO NOISEY PIPE IS BEEN CUT ABOUT PASANGER SIDE LENGHT.
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 14 7B02 140201 4C3Z 10346 AA D03 42 27130
AWS Claim Key: 6985709 Trx Code: E83 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 05439 - * Name: FIESTA FORD, INC. Ph: 760-7728000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:23-JUL-2004 Doc #:03232151
Cust Comments: SLOW CRANK. SEE HISTORY.
Tech Comments: NO ALTARNATOR OUTPUT. BATTERY,CHARGING TESTS REMOVED AND REPLACED ALTERNATOR. ADD FOR
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 16 1H03 030008 3C3Z 9J460 AA D41 42 28660
AWS Claim Key: 7440508 Trx Code: S07 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 05574 - * Name: PALM SPRINGS FORD LINCOLN MERCURY Ph: 760-3282102 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:26-AUG-2004 Doc #:191618A
Cust Comments: CHECK ENGINE LIGHT WAS ON NOW OFF
Tech Comments: 28660 EXHAUST BACK PRESSURE SENSOR WARRANTY (42) CHECKED AND FOUND THE CODE P2263. I CHECKED THE FREEZE FRAME AND FOUND THE VSS AT 0 AND THE RPMS AT 650. THIS IS CAUSED FROM THE CALIBRATI ON AND EXHAUST BACK PRESSURE SENSOR. I MONITOR ED THE SENSOR AND FOUND IT READING 14.2 PSI WHICH IS BELOW SPECS FOR THIS AREA. I REPLACED THE SENSOR. CLEARED THE CODE AND ROAD TEST. THE CODE P0266
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 16 2E06 030008 * 9E527 * D11 42 28660
AWS Claim Key: 7440509 Trx Code: S07 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 05574 - * Name: PALM SPRINGS FORD LINCOLN MERCURY Ph: 760-3282102 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:26-AUG-2004 Doc #:191618B
Cust Comments: VEH SEEMS TO RUN ROUGH AND SURGES WHEN LIGHT IS ON WHEN LIGHT IS ON VEH WILL BLOW BLACK SMOKE BUT NOT WHEN LIGHT IS OFF
Tech Comments: 28660 WIRE DAMAGED FOR #2 INJECTOR WARRANTY (30 07) CHECKED AND FOLLOWED THE DIESEL FLOW CHART. I FOUND THE CODE PO266 AND THE ENGINE WOULD MISS AT TIMES. I DID A RELATIVE COMPRESSION TEST AND ALL OF THEM ARE WITHIN 1% OF EACH OTHER. I WOULD PUSH ON THE AIR CLEANER WHILE IT WAS RUNNING AND THIS WOULD CAUSE THE MISFIRE. I REMOVED THE AIR CLEANER BOX AND TUBE ASSEMBLY AND FOUND THE WIRES
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 16 * * * * * * * 28660
AWS Claim Key: 7440510 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 05574 - * Name: PALM SPRINGS FORD LINCOLN MERCURY Ph: 760-3282102 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:26-AUG-2004 Doc #:191618C
Cust Comments: RECALL 04S15
Tech Comments: 28660 RECALL WARRANTY REPLACED THE GROUND STUD AND CHECKED THE OTHER GROUNDS.
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 23 2E06 030008 3C3Z 9F838 EA E29 42 37961
AWS Claim Key: 10122522 Trx Code: E72 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 05574 - * Name: PALM SPRINGS FORD LINCOLN MERCURY Ph: 760-3282102 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-MAR-2005 Doc #:214365A
Cust Comments: CHECK ENGINE LITE ON, ODLES ROUGH, STALLS
Tech Comments: CHECKED AND FOLLOWED THE DIESEL DIAG CHART. I FOUND THE CODE P2285. I MONITORED THE ICP SIGNEL. IT WAS READING 0. I ALSO FOUND THE SENSOR LEAKING. I REPLACED THE SENSOR. CLEARED THE CODE AND RETEST OK, CAUSAL PART COVERED UNDER CAL EMISSIONS 3 50
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 27 1H03 030008 4C3Z 9J460 A D41 42 46402
AWS Claim Key: 11682282 Trx Code: S07 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 03680 - * Name: SUNRISE FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2005 Doc #:621827A
Cust Comments: SES LIGHT KEEPS COMING ON LOSS OF POWER EMITTING LOTS OF SMOKE
Tech Comments: 46402 EBP SENSOR 6005F.4,F1.1,F1X1.1,F6.1,F11.1,F12.4,F14.1, 12650D9.2, TOTAL 1.5 LABOR PERFORM WDS SET UP AND 6.0 DIESAL FLOW SHEET CODE P2263 RETURNED PINPOINT TEST EBP SENNSOR REPLACED AND RETEST OK AFTER REPAIR
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 35 2E06 030008 3C3Z 9E527 AE D41 42 58499
AWS Claim Key: 13480130 Trx Code: E72 Labor Hrs: 7.2
Dlr Cd-Sub Cd: 05539 - * Name: SUNRISE FORD Ph: 909-8224401 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:25-MAR-2006 Doc #:024164A
Cust Comments: CUSTOMER STATES ENGINE RUNS ROUGH WHEN STARTING COLD.IDLES BETTER AFTER ENIGNE IS WARMED UP
Tech Comments: 58505 9.5 PERFORM DIESEL ENGINE DIAG FOR ENGINE PERFORMANCE. KOEO KOER AND ON DEMAND TESTING. PERFORM ALL AIR FUEL AND EXHAUST PRESSURE AND RESTRICTION TESTING. TEST OIL FOR AERATION AND CONTAMINATION. TEST FUEL PRESSURE AT BOTH HEADS AND PUMP. PERFORM EGR VGT AND IPR FUNCTION TESTS. PERFORM INJECTOR BUZZ TEST AND CYLINDER BALANCE TEST HOT AND COLD ACCORDING TO TSB 06 2 13.
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 35 * * * * * * * 58499
AWS Claim Key: 13480132 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05539 - * Name: SUNRISE FORD Ph: 909-8224401 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:25-MAR-2006 Doc #:024164C
Cust Comments: RECALL 06E17 CONTROL MODULE RECALIB
Tech Comments: 58499 .7 REFLASH MODULES AS PER RECALL
AWS Claim Key: 13480131 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05539 - * Name: SUNRISE FORD Ph: 909-8224401 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:25-MAR-2006 Doc #:024164D
Cust Comments: RECALL 59B01 ONE TIME ASSANCE ROAD TEST
Tech Comments: 58499 .3 PERFORM ROAD TEST
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 36 7B02 140201 4C3Z 10346 AA L26 42 62270
AWS Claim Key: 13807880 Trx Code: 0759D Labor Hrs: 1.8
Dlr Cd-Sub Cd: 05539 - * Name: SUNRISE FORD Ph: 909-8224401 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:09-MAY-2006 Doc #:027604A
Cust Comments: CUSTOMER STATES HEADLIGHTS AND INTER.LIGHTS FLICKER AT IDLE OR HIGHER SPPED SEE HISTORY
Tech Comments: 62270 ALTERNATOR 10200AB,13346A,10654CA 2.2 PERFORMED DIAG. FOUND ALT VOLTS LOW 12.6 CHECK OUT AND CHARGED BATTERIES, ALTERNATOR REPLACED OUT PUT VOLS 14.3 OK AFTER REPAIR
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 36 1D05 031004 3C3Z 6584 BA L65 68 62270
AWS Claim Key: 13799409 Trx Code: E72 Labor Hrs: 7
Dlr Cd-Sub Cd: 05539 - * Name: SUNRISE FORD Ph: 909-8224401 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:09-MAY-2006 Doc #:027604C
Cust Comments: CUSTOMER STATES ENGINE LEAKING OIL SEE HISTORY
Tech Comments: 62270 SEVERAL CONCERNS 6.0 CHECKED FOR OIL LEAKS CHECKS FOUND OIL LEAKING FOUND LEFT SIDE GLOWPLUG WIRING LOOM, VALVE COVER AND CAC HOSE HOT AT TURBO. REMOVED VALVE COVER AND FOUND VALVE COVER NOT STRAIGHT SLIGHTLY WARPED. M TIME REQUIRED TO REPLACE GLOWPLUG WIRING LOOM. INSTALLED NEW VALVE COVER ON LEFT SIDE WITH NEW GASKET. INSTALLED NEW CAC HOSE AND CLAMPS. RETEST NOW OK.
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 37 7K12 010503 3C7Z 10D898 AA A85 42 64167
AWS Claim Key: 13970958 Trx Code: 0759D Labor Hrs: 1.4
Dlr Cd-Sub Cd: 05539 - * Name: SUNRISE FORD Ph: 909-8224401 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:10-JUN-2006 Doc #:029917A
Cust Comments: ROOF CONSOLE DISPLAY NOT WORKING INSTALL SOP REF RO#27604 9MAY06 62,270 MILES DEDUCT PAID ON PRIOR RO
Tech Comments: 64167 OVERHEAD DISPLAY 12651D 12651D2 PLUS M TIME 1.4 TOTAL DIAG AND CHECKED ALL FUSES AND CONNECTORS, TESTED ALL COMPONENTS AND REMOVED OVERHEAD CONSOLE , TESTED ALL WIRES AND CONNECTORS AT OVER HEAD MODULE AND WAS NECESSARY TO REPLACE, REPROGRAM USING AS BUILT DATA AND VARIFIED OPERATION FOR OVERHEAD MODULE.
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 38 1A04 030008 3C3Z 9424 AE D41 68 65706
AWS Claim Key: 14088143 Trx Code: S07 Labor Hrs: 10.8
Dlr Cd-Sub Cd: 03680 - * Name: SUNRISE FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2006 Doc #:031124A
Cust Comments: CUSTOMER STATES CHECK ENGINE LIGHT STAYS ON
Tech Comments: 65706 EGR COOLER ASSY. 12.3HRS 6005F0.4 F10.1 F1X10.1 F20.1 F60.1 F80.6 F90.1 F110.1 F120.4 F130.2 F140.1 F180.6 F190.3 F200.1 F210.3 F220.1 F230.4 F251.4 12650D300.5 D450.3 D810.5 D840.5 9424A4.5 A10.5 CHECK ENGINE,CHASSIS,FUEL,AND OIL LEVEL,ALL OK. PERFORM ALL KOEO AND KOER ON DEMAND SELF TEST FOR CODES,P0401. CHECK INTAKE AND EXHAUST FOR RESTRICTION,8,13. CHECK EGR VALVE,1.1,
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 38 2E02 030408 3C3Z 9N693 HA L65 68 65706
AWS Claim Key: 14095587 Trx Code: E72 Labor Hrs: 7.9
Dlr Cd-Sub Cd: 03680 - * Name: SUNRISE FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2006 Doc #:031124C
Cust Comments: CUSTOMER STATES GETTING A OIL BURNING SMELL AND LEAK
Tech Comments: 65706 OIL COOLER,SENSOR,AND ORINGS. 6007D0.5 6642A4.8 9278A0.7 3674A1.9 7.9HRS HAD TO ADD OIL DYE AND CHECK WITH BLACK LIGHT, FOUND O RINGS AND OIL PRESSURE SENDER WAS LEAKING OIL, ALSO FOUND OIL IN COOLANT. HAD TO R&R POWERSTEERING PUMP TO ACCESS AND REMOVE SENSOR AND REPLACE BROKEN ORINGS. REPLACE OIL PRESSURE SENSOR. REPLACE OIL COOLER DUE TO OIL IN COOLANT. HAD TO FLUSH
1FMSU41P63EC79554 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 31-MAY-2003 171430 USA 39 2H01 030008 3C3Z 6K682 BARM D41 42 67139
AWS Claim Key: 14196396 Trx Code: E72 Labor Hrs: 9.2
Dlr Cd-Sub Cd: 03680 - * Name: SUNRISE FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:24-JUL-2006 Doc #:033208B
Cust Comments: CUSTOMER STATES GETTING A SLIGHT ENGINE SURGE WHILE DRIVING AT STEADY SPEEDS
Tech Comments: 67202 #2 INJECTOR AND TURBO ASSY 11.1HRS 6005F0.4 F10.1 F1X10.1 F20.1 F60.1 F80.6 F90.1 F110.1 F120.4 F130.2 F140.1 F180.6 190.3 F200.1 F210.3 F220.1 F230.4 F251.2 F330.2 12650D450.3 D470.1 D810.5 D840.5 9438A1.8 AZN0.1 A30.6 9527AL1.7 CHECK ENGINE,CHASSIS,FUEL,AND OIL LEVEL,ALL OK. PERFORM ALL KOEO AND KOER ON DEMAND SELF TEST FOR CODES,P0266,P2262. CHECK INTAKE AND EXHAUST FOR
