OASIS RESULT:
1FTSW31P04EC44910
04/30/2007
21:07:02
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/25/2004 BUILD DATE
02/13/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
04/18/2007
DEALER: Sun State Ford, Inc.
WARRANTY CLAIM NUMBER: 021077 ODOMETER: 090069M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6006BARM ENGINE ASSY/BARE 001 061906A D8 FAILED GASKET/SEAL
4C3Z 9P456AF COOLER - EGR 001 6007A
3C3Z 8575AA THERMOSTAT 001 6007A28
3C3Z 6731AA ELEMENT ASY OIL FILT 001 6007A34
XO 15W405QSD 003 6642A
VC 7B 003 12650D84
XT 2QDX MOTORCRAFT BATTERY 002
388898S 002
OSP 001
6C3Z 8A080B COOLANT O/FLO BOTTLE 001
F6DZ 8100A CAP ASY RADIATOR 001
B7A 8287B CLAMP ASY-RAD HOSE 003
3C3Z 9P455AB SE E/G/R VLV 001
FAILED EGR COOLER SEAL DAMAGED ENGINE . CHECKED CONDITION OF ENGINE. CHECK ED EGR COOLER. COMPRESSION TEST. NUMBER 7 CYLINDER BAD. TEAR DOWN ENGINE AN D INSPECTED. CYLINDER WALLS SCORED. NUMBER 7 CYLINDER APPEARS TO BE CR ACKED. R&R ENGINE ASSEMBLY. R&R EGR COOLER. CLEANED EGR VALVE PER TECHNICAL SERVICE BULLETIN. REPROGRAMMED PCM, FICM, AND TCM
12/26/2006
DEALER: Bolton Ford, L.L.C.
WARRANTY CLAIM NUMBER: 049936 ODOMETER: 087392M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6079C GASKET SET-VALVE GRI 001 6051AT D8 FAILED GASKET/SEAL
F6DZ 8100A CAP ASY RADIATOR 001 8005D
VC 7B 002 8100A
W300013 001
W701706S2 001
XO 15W405QSD 003
XT 6QSP 002
HEAD GASKETS BLOWN TEST DRIVE COOLANT SYSTEM HAS EXCESSIVE PRESSURE REMOVE EGR VALVE PRESSURE TEST COOLANT SYSTEM TO CHEC K FO EGR COOLER LEAK OK REPLACE BOTH HEAD GASKETS CHANGE OIL AND FILTER REFI LL COOLANT STSYEM REDRIVE OK
10/16/2006
DEALER: Gray Ford Mercury
WARRANTY CLAIM NUMBER: 173912 ODOMETER: 084973M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 8005D D8 FAILED GASKET/SEAL
VC 7B 002 8146A
000 9438AZW
000 9438A
000 9456A
EGR COOLER IS LEAKING. PRESSURE TESTED COOLING SYSTEM. CONTACTED FORD HOT LINE. REMOVED FAN AND SHROUD, CAC TUBES, Y-PIPE, TURBO AND UPPER INTAKE. REP LACED EGR COOLER AND GASKETS. RE- ASSEMBLED. FILLED WITH COOLANT. ROAD TESTE D.
09/25/2006
WARRANTY CLAIM NUMBER: 173445 ODOMETER: 084192M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 12A342AA PLUG-GLOW 001 12342D1L 42 DOES NOT OPERATE PROPERLY
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 12650D30
000 6005E5
000 6005E2
CODES P0674 AND P0401. EGR VALVE AND GLOW PLUG FOR #4 CYL BAD RAN TESTING ON TRUCK. REPLACED EGR VALVE AND CYL 4 GLOW PLUG
END OF OASIS REPORT FOR 1FTSW31P04EC44910
