Could I get an OASIS report for a 2003 F-250 vin: 1ftnx21p93eb52777
Thanks,
Standard Claims List For Model Year 2003
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 0 2G05 031405 * RECAL * D50 79 7
AWS Claim Key: 3352600 Trx Code: 2 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07780 - * Name: COUNTRY FORD TRUCKS Ph: 209-5753673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:28-OCT-2003 Doc #:101514A
Cust Comments: RECALL 03T02
Tech Comments: PERFORMED RECALL 03T02.
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 0 6Y05 000001 * TDRIVE * A96 82 7
AWS Claim Key: 3372055 Trx Code: R7U Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07780 - * Name: COUNTRY FORD TRUCKS Ph: 209-5753673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:28-OCT-2003 Doc #:101514B
Cust Comments: SPECIAL TEST DRIVE FOR 6.0 DIESEL.
Tech Comments: PERFORMED SPECIAL ROAD TEST FOR 6.0 ENGINE.
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 9 1F05 030306 4C3Z 8A616 AA E29 42 12078
AWS Claim Key: 7704236 Trx Code: E84 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 07749 - * Name: FUTURE FORD Ph: 916-7863673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-SEP-2004 Doc #:548589A
Cust Comments: CS CHECK ENGINE LIGHT HAS BEEN ON HAS CODE P0480 IN SYSTEM CHECK AND ADVISE
Tech Comments: CHECKED FOR CONCERN, FOUND CODE P0480. TESTED AND FOUND FAULTY FAN CLUTCH ASSEMBLY. REPLACED FAN CLUTCH ASSEMBLY. RECHECKS OK AFTER REPAIRS.
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 9 2E01 * * * * * * 12078
AWS Claim Key: 7687132 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07749 - * Name: FUTURE FORD Ph: 916-7863673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-SEP-2004 Doc #:548589B
Cust Comments: INJECTION CONTROL PRESSURE (IPC) SENSOR REPLACEMENT
Tech Comments: REPLACED ICP SENSOR PER RECALL
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 9 * * * * * * * 12078
AWS Claim Key: 7687133 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07749 - * Name: FUTURE FORD Ph: 916-7863673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-SEP-2004 Doc #:548589C
Cust Comments: NEGATIVE BATTERY TERMINAL TO ENGINE BLOCK CONNECTION.
Tech Comments: REPLACED NEGATIVE PINCH BOLT PER RECALL.
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 21 5V05 060603 * 2265 * L63 33 24166
AWS Claim Key: 12235385 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07900 - * Name: FORD OF DUBLIN Ph: 925-8295211 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:25-AUG-2005 Doc #:02436851
Cust Comments: CUSTOMER STATES BRAKE FLUID LEAK AT MASTER CYL. SWITCH CHECK AND ADVISE
Tech Comments: FLUID LEAK FOUND LOOSE LINE AND SENSOR AT MASTER CYL.
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 21 1F06 030304 F6DZ 8100 A L87 D1 24166
AWS Claim Key: 12246470 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07900 - * Name: FORD OF DUBLIN Ph: 925-8295211 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:25-AUG-2005 Doc #:02436852
Cust Comments: CUSTOMER STATES COOLANT COMING OUT OF RADIATOR CAP, AND MELTED AIR FILTER SENSER CHECK AND ADVISE
Tech Comments: COOLANT CAP PRESSURE TEST COOLING SYSTEM, FOUND COMING FROM CAP, REPLACED
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 23 2E06 100101 3C3Z 9275 CA L69 42 28939
AWS Claim Key: 12338825 Trx Code: S07 Labor Hrs: 2
Dlr Cd-Sub Cd: 07900 - * Name: FORD OF DUBLIN Ph: 925-8295211 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:17-OCT-2005 Doc #:02798451
Cust Comments: CHECK AND ADVISE ON FUEL GAUGE OUT OF RANGE. SEE DAVE
Tech Comments: INSPECTED AND VERIFIED COMPLAINT FOUND FAULTY SENDER. REMOVED AND REPLACED SENDER , RECHECKED OK
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 24 1F06 030304 * 8A080 * L85 42 28036
AWS Claim Key: 12524356 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00602 - * Name: CROWN FORD Ph: 530-2414321 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:22-NOV-2005 Doc #:26347902
Cust Comments: CHECK RADIATOR OVER FLOW CONTAINER OVERFLOWS
Tech Comments: HOSE CAMES DISCONNECTED FROM RESERVIOR. REATTACH HOSE TO RESERVOIR.ONLY TIME VEHICLE HAS BEEN TO OUR DEALERSHIP
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 24 6J14 011404 6L3Z 25218A43 AA L07 28 28036
AWS Claim Key: 12524355 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 00602 - * Name: CROWN FORD Ph: 530-2414321 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:22-NOV-2005 Doc #:26347904
Cust Comments: CUSTOMER STATES DRIVERS DOOR LOCK ACTUATOR IS NOISY.. CHECK AND ADVISE.
Tech Comments: CONFIRMED NOISY ACTUATOR MOTOR. REPLACE DRIVERS DOOR LOCK ACTUATOR MOTOR..OPERATION NOW QUITE.ONLY TIME VEHICLE HAS BEEN HERE
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 24 7K11 130101 3C3Z 10849 HA L69 42 28842
AWS Claim Key: 12742655 Trx Code: E83 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 07900 - * Name: FORD OF DUBLIN Ph: 925-8295211 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:07-DEC-2005 Doc #:03120951
Cust Comments: CUST. STATES REPLACE PARTS FOR THE FUEL SYSTEM REPLACE INSTRUMENT CLUSTER FUEL GAUGE STICKING
Tech Comments: INSPECTED AND VERIFEID COMPLAINT REMOVED AND REPLACED INSTRUMENT CLUSTER , ADJUSTED AND
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 24 1F06 030304 F6DZ 8100 A L87 D1 28842
AWS Claim Key: 12742656 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 07900 - * Name: FORD OF DUBLIN Ph: 925-8295211 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:07-DEC-2005 Doc #:03120952
Cust Comments: CHECK AND ADVISE ON POSSIBLE COOLANT RESIDUE ON TOP OF ENGINE
Tech Comments: INSPECTED AND VERIFIED COMPLAINT REPLACE RADIATOR CAP , CLEANED AND RECHECKED OK
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 25 1H03 030804 4C3Z 9J460 A E29 42 29741
AWS Claim Key: 12775531 Trx Code: S07 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 07900 - * Name: FORD OF DUBLIN Ph: 925-8295211 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:22-DEC-2005 Doc #:03222951
Cust Comments: CHECK AND ADVISE ON CHECKE ENGINE LIGHT ON.
Tech Comments: REMOVED AND REPLACED EBP AND EGR SENSORS , CLEARED CODES , ROAD TESTED AND RECHECKED OK
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 26 6Y05 000001 * MAINT * A96 82 31725
AWS Claim Key: 13172301 Trx Code: 0862S Labor Hrs: 2.4
Dlr Cd-Sub Cd: 07900 - * Name: FORD OF DUBLIN Ph: 925-8295211 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:07-FEB-2006 Doc #:03540230
Cust Comments: CUST STATES PERFORM 30K SERVICE INTERVAL PER ATTACHED MENU
Tech Comments: PERFORMED 30K SERVICE INTERVAL SEE COMMENTS
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 26 1H03 030804 3C3Z 9P456 AE L87 D1 31725
AWS Claim Key: 13181427 Trx Code: S07 Labor Hrs: 6
Dlr Cd-Sub Cd: 07900 - * Name: FORD OF DUBLIN Ph: 925-8295211 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:07-FEB-2006 Doc #:03540252
Cust Comments: CHECK AND ADVISE ON COOLANT OVERFLOWING OUT OF COOLANT BOTTLE.
Tech Comments: INSPECTED AND VERIFIED COMPLAINT CHECKED AND FOUND EGR COOLER LEAKING. REMOVED AND REPLACED
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 26 1G04 030008 5C3Z 8509 A N11 42 31725
AWS Claim Key: 13172302 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 07900 - * Name: FORD OF DUBLIN Ph: 925-8295211 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:07-FEB-2006 Doc #:03540253
Cust Comments: CHECK AND ADVISE ON SQUEALING NOISE IN ENGINE AREA
Tech Comments: INSPECTED AND VERIFIED COMPLAINT FOUND PULLEY AND BELT CAUSING CONCERN. REMOVED AND REPLACED
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 26 1D01 03XXXX 3C3Z 6701 AA L65 D8 31725
AWS Claim Key: 13172303 Trx Code: E84 Labor Hrs: 4.9
Dlr Cd-Sub Cd: 07900 - * Name: FORD OF DUBLIN Ph: 925-8295211 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:07-FEB-2006 Doc #:03540254
Cust Comments: CHECK AND ADVISE ON POSSIBLE OIL LEAK.
Tech Comments: INSPECTED AND VERIFIED COMPLAINT CHECKED FOR LEAKS AND FOUND FRONT CRANK SEAL LEAKING AND FRONT
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 28 * * * * * * * 33302
AWS Claim Key: 13458112 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07900 - * Name: FORD OF DUBLIN Ph: 925-8295211 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-MAR-2006 Doc #:03832340
Cust Comments: 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO
Tech Comments: ROAD TESTEED VEHICLE AS PER RECALL
AWS Claim Key: 13458113 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07900 - * Name: FORD OF DUBLIN Ph: 925-8295211 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-MAR-2006 Doc #:03832341
Cust Comments: 06E17 CONTROL MODULE RECALIBRATION
Tech Comments: RECALL COMPLETED REPROGRAMMED CONTROL MODULE
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 29 6Y05 000001 * MAINT * A96 82 34818
AWS Claim Key: 13740951 Trx Code: 0862S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07900 - * Name: FORD OF DUBLIN Ph: 925-8295211 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-APR-2006 Doc #:04105205
Cust Comments: CUST STATES PERFORM 5K SERVICE INTERVAL PER ATTACHED MENU
Tech Comments: PERFORMED 5K SERVICE INTERVAL SEE COMMENTS
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 32 6Y05 000001 * MAINT * A96 82 38502
AWS Claim Key: 14183350 Trx Code: 0862S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07900 - * Name: FORD OF DUBLIN Ph: 925-8295211 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-JUL-2006 Doc #:04666051
Cust Comments: PERFORM 40K SERVICE PER ATTACHED MAINT CHECKLIST
Tech Comments: CHANGED OIL AND FILTER
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 34 6Y05 000001 * MAINT * A96 82 42717
AWS Claim Key: 14498319 Trx Code: 0862S Labor Hrs: 1.8
Dlr Cd-Sub Cd: 07900 - * Name: FORD OF DUBLIN Ph: 925-8295211 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:10-OCT-2006 Doc #:057216A
Cust Comments: 45K MILE MAINT.
Tech Comments: PERFORM SCHEDULED MAINT.
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 35 2E06 030008 3C3Z 9F838 EA E29 42 43446
AWS Claim Key: 14590113 Trx Code: S07 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 07900 - * Name: FORD OF DUBLIN Ph: 925-8295211 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-NOV-2006 Doc #:058535B
Cust Comments: CHECK ENG LIGHT IS ON. HARD TIME STARTING AT TIMES WHEN COLD.
Tech Comments: VERIFIED CK ENG LIGHT ON. RAN QUICK TEST. CK OIL LEVEL, AIR FILTER, FUEL CONDITION. REMOVED AND REPLACED FAN CLUTCH, RAN PINPOINT TEST. REMOVED AND REPLACED ICP SENSOR, ROAD TEST, RETEST, OK. PCM AT LATEST LEVEL.
1FTNX21P93EB52777 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 27-DEC-2003 172018 USA 38 6Y05 000001 * MAINT * A96 82 46945
AWS Claim Key: 14806422 Trx Code: 0862S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07900 - * Name: FORD OF DUBLIN Ph: 925-8295211 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-JAN-2007 Doc #:062443A
Cust Comments: 50K MAINT REQUESTED
Tech Comments: REPLACE OIL AN DIFLTER
