OASIS RESULT:
1FTSX31F73EB10334
03/17/2009
22:06:06
FCXWS447
© Copyright 2002-2008 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 S/CAB PICKUP 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
D1 ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/31/2002 BUILD DATE
10/16/2002 SALE MILEAGE
00013
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
03/27/2008
DEALER: Bell Motors, Inc.
WARRANTY CLAIM NUMBER: 074986 ODOMETER: 064740M
LABOR OP
CONDITION CODE
CONDITION DESC
F7TZ 12K073B TRNSDC ASY-C/SHT PSN 001 07S57B
PERFORMED RECALL 07S57, CMP SENSOR.
1FTSX31F73EB10334 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 16-OCT-2002 31-DEC-2002 141148 USA 10 3A11 070100 1C3Z 7000 FBRM P59 42 9717
AWS Claim Key: 2961777 Trx Code: 1 Labor Hrs: 10.3
Dlr Cd-Sub Cd: 06109 - * Name: BELL MOTORS, INC. Ph: 608-6354383 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:03-OCT-2003 Doc #:05206601
Cust Comments: VEHICLE WILL NOT GO OVER 45 MPH. SEEMS TO SLIP.
Tech Comments: DIAGNOSED FOUND FLUID VERY BURNT AND CODE P0782. PERFORMED TEAR DOWN AS PER HOTLINE. REPLACED UNIT AS PER HOTLINE.
1FTSX31F73EB10334 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 16-OCT-2002 31-DEC-2002 141148 USA 13 3T06 070701 F81Z 7B214 AA K03 42 13616
AWS Claim Key: 4695799 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 06109 - * Name: BELL MOTORS, INC. Ph: 608-6354383 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:02-JAN-2004 Doc #:05326101
Cust Comments: CLUNK COMING FROM UNDER VEHICLE.
Tech Comments: INSPECTED FOR NOISE FOUND FLANGE CAUSING CONCERN. REMOVED DRIVESHAFT AND REPLACED FLANGE.
1FTSX31F73EB10334 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 16-OCT-2002 31-DEC-2002 141148 USA 23 7B02 140201 * 10346 * G29 42 25932
AWS Claim Key: 8547374 Trx Code: E83 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 06109 - * Name: BELL MOTORS, INC. Ph: 608-6354383 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:09-NOV-2004 Doc #:05779901
Cust Comments: BATTERY LIGHT COMES ON WHEN DRIVING.
Tech Comments: CHECKED CHARGING SYSTEM AND REPLACED BATTERY.
1FTSX31F73EB10334 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 16-OCT-2002 31-DEC-2002 141148 USA 24 5T01 031801 1C3Z 9F836 BA D50 42 26029
AWS Claim Key: 8605452 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06109 - * Name: BELL MOTORS, INC. Ph: 608-6354383 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:26-NOV-2004 Doc #:05804301
Cust Comments: VEHICLE ONLY IDLES AT TIMES.
Tech Comments: REMOVED AND REPLACED AP SENSOR.
1FTSX31F73EB10334 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 16-OCT-2002 31-DEC-2002 141148 USA 24 7C10 030311 F7TZ 6A051 AA D03 42 26029
AWS Claim Key: 8605451 Trx Code: E83 Labor Hrs: 2.8
Dlr Cd-Sub Cd: 06109 - * Name: BELL MOTORS, INC. Ph: 608-6354383 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:26-NOV-2004 Doc #:05804302
Cust Comments: BLOCK HEATER INOPERATIVE?
Tech Comments: CHECKED AND FOUND ELEMENT BAD. REMOVED AND REPLACED BLOCK HEATER AND ANTI FREEZE.
1FTSX31F73EB10334 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 16-OCT-2002 31-DEC-2002 141148 USA 29 7S02 180102 * 14401 * A07 B4 32279
AWS Claim Key: 10898907 Trx Code: E83 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 06109 - * Name: BELL MOTORS, INC. Ph: 608-6354383 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:13-MAY-2005 Doc #:06031901
Cust Comments: RADIO WILL NOT TURN ON. DISPLAY IS OUT. 3C3T 18C815 AA
Tech Comments: DIAGNOSED RADIO INOPERATIVE FOUND NO POWER TO PIN 10. CHECKE 15 AMP FUSE POSITION F2.42, OK. CHECKED CIRCUIT 194 FROM BACKSIDE OF SIDE OF FUSE PANEL TO RADIO, OPEN. TRACED WIRING FOUND CIRCUIT 194, PINK WIRE BROKE ABOUT 8 INCHES FROM BACK SIDE OF FUSE PANEL. REPAIRED WIRING AND RECHECKED. OK AT THIS TIME.
1FTSX31F73EB10334 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 16-OCT-2002 31-DEC-2002 141148 USA 32 7M01 150101 1C3F 18C815 AA A07 42 32279
AWS Claim Key: 11882781 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 48915 - * Name: VISTEON AFTERMARKET - U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:01-AUG-2005 Doc #:56096500
Tech Comments: REQUESTING DEALER'S P/A CODE 06109
1FTSX31F73EB10334 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 16-OCT-2002 31-DEC-2002 141148 USA 33 7M01 150101 * 18C815 * A16 42 35852
AWS Claim Key: 12199740 Trx Code: E83 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 06109 - * Name: BELL MOTORS, INC. Ph: 608-6354383 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:06205101
Cust Comments: CHECK RADIO AND C.D. PLAYER OPERATION. DOES NOT WORK.
Tech Comments: REMOVED RADIO AND INSTALLED EXCHANGE UNIT.
1FTSX31F73EB10334 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 16-OCT-2002 31-DEC-2002 141148 USA 33 7K11 130101 2C3Z 10849 HA H19 42 35852
AWS Claim Key: 12199739 Trx Code: E83 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 06109 - * Name: BELL MOTORS, INC. Ph: 608-6354383 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:06205102
Cust Comments: AIR BAG LIGHT IS ON AT TIMES.
Tech Comments: CHECKED AND FOUND INSTRUMENT CLUSTER BAD. REMOVED AND REPLACED INSTRUMENT CLUSTER.
1FTSX31F73EB10334 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 16-OCT-2002 31-DEC-2002 141148 USA 34 7M01 150101 3C3T 18C815 AA A07 42 35852
AWS Claim Key: 12637205 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 48915 - * Name: VISTEON AFTERMARKET - U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:05-OCT-2005 Doc #:75946600
1FTSX31F73EB10334 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 16-OCT-2002 31-DEC-2002 141148 USA 35 7B02 140201 * 10346 * D02 42 35165
AWS Claim Key: 12492606 Trx Code: E83 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 06109 - * Name: BELL MOTORS, INC. Ph: 608-6354383 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:19-OCT-2005 Doc #:06263102
Cust Comments: VEHICLE HAS TO BE JUMPED AT TIMES.
Tech Comments: TESTED BOTH BATTERIES, OK. CHECKED CHARGING SYSTEM FOUND NO ALT OUTPUT. REMOVED AND REPLACED ALTERNATOR.
1FTSX31F73EB10334 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 16-OCT-2002 31-DEC-2002 141148 USA 43 2E06 03XXXX 2C3Z 9G804 AB L65 D8 44749
AWS Claim Key: 14022316 Trx Code: E72 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 06109 - * Name: BELL MOTORS, INC. Ph: 608-6354383 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:20-JUN-2006 Doc #:06608402
Cust Comments: DIAGNOSE DIESEL ENGINE OIL LEAKS AND ADVISE ON REPAIRS.
Tech Comments: 1 DEGREASED ENGINE FOR LEAKS. INSPECTED FOR ENGINE OIL LEAKS FOUND HIGH PRESSURE OIL PUMP FITTING LEAKING OIL. REMOVED AND REPLACD HIGH PRESSURE OIL PUMP FITTING AND O RING. RECHECKED FOR LEAKS, OK AT THIS TIME.
1FTSX31F73EB10334 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 16-OCT-2002 31-DEC-2002 141148 USA 45 2B01 0300XX F7TZ 12K073 A D36 42 46571
AWS Claim Key: 14268638 Trx Code: S07 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 06109 - * Name: BELL MOTORS, INC. Ph: 608-6354383 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2006 Doc #:06684301
Cust Comments: ENGINE BUCKS AND JERKS WHEN DRIVING.
Tech Comments: 1 PERFORMED DIESEL TESTS FOUND P1211, P1209, P0340. PERFORMED ADDITIONAL TESTS AND REPLACED CAM SENSOR AND ICP.
1FTSX31F73EB10334 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 16-OCT-2002 31-DEC-2002 141148 USA 47 2I04 030703 * 12B533 * D02 42 48651
AWS Claim Key: 14577019 Trx Code: E72 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 06109 - * Name: BELL MOTORS, INC. Ph: 608-6354383 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:01-NOV-2006 Doc #:06794501
Cust Comments: DIAG. NO START CONCERN.
Tech Comments: CHECKED AND FOUND GLOW PLUG RELAY BAD. REMOVED AND REPLACED GLOW PLUG RELAY.
1FTSX31F73EB10334 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 16-OCT-2002 31-DEC-2002 141148 USA 51 1H03 030804 4C3Z 9J460 A D21 42 53205
AWS Claim Key: 14877710 Trx Code: E72 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 06109 - * Name: BELL MOTORS, INC. Ph: 608-6354383 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:14-FEB-2007 Doc #:06931601
Cust Comments: ENGINE STALLS AT TIMES, TURBO CLAMP APPEARS TO LOOSE, AND TURBO MAKES NOISE.
Tech Comments: 1 DIAGNOSED CUSTOMER CONCERN FOUND CODES P0470, P0476, P1209 AND P1211. WATCHED PIDS AND REPLACED EBP SENSOR.
1FTSX31F73EB10334 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 16-OCT-2002 31-DEC-2002 141148 USA 63 6Y20 000000 * TAP5 * A99 82 63640
AWS Claim Key: 15852010 Trx Code: TAP5 Labor Hrs: 0
Dlr Cd-Sub Cd: 06109 - * Name: BELL MOTORS, INC. Ph: 608-6354383 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:14-FEB-2008 Doc #:07440502
Cust Comments: FREE LOANER CAR FOR REPAIR VISIT.
Tech Comments: LOANER CAR FOR RETAIL REPAIR.
1FTSX31F73EB10334 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 16-OCT-2002 31-DEC-2002 141148 USA 64 * * * * * * * 64740
AWS Claim Key: 15907143 Trx Code: 07S57 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06109 - * Name: BELL MOTORS, INC. Ph: 608-6354383 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:27-MAR-2008 Doc #:07498602
Cust Comments: PERFORM RECALL 07S57.
Tech Comments: PERFORMED RECALL 07S57, CMP SENSOR.
