Trying to decide between two trucks. I guess an Oasis will help me decide.
1FTWW31P06ED29685
1FTWW33P56ED78474
Thanks so much.
1st one
OASIS RESULT:
1FTWW31P06ED29685
USA
EN
04/02/2009
18:34:34
FCXWS446
© Copyright 2002-2008 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 08-26-03
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-16-13
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-11-03
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/24/2006 BUILD DATE
03/16/2006 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
12/12/2008
DEALER: Tomball Ford, Inc.
WARRANTY CLAIM NUMBER: 409865 ODOMETER: 093168M
LABOR OP
CONDITION CODE
CONDITION DESC
F6DZ 8100A CAP ASY RADIATOR 001 6005PA 42 DOES NOT OPERATE PROPERLY
6C3Z 6051AA GASKET CYL HEAD 002 081103A
3C3Z 9433AA GASKET SET-MANIFOLD 001 081103E
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 15W40QSD 015
VC 7B 003
5C3Z 9N622A IND ASY ENG A/C REST 001
93628 HEAD GASKETS LEAKING VERIFIED CUSTOMER CONCERN, VEHICLE WAS LOOSING C OOLANT. RADIATOR CAP WAS DEFECTIVE, NOT HOLDING PRESSURE. CUSTOMER PAID FOR NEW CAP, INSTALLED A NEW CAP AND PER TSB 08-11-3 INSTALLED PRESSURE TESTER INLINE AND MONITORED PIDS EOT ADN ECT WHILE ON TEST DRIVE. PIDS WERE NEVER MORE THAN 10 DEGREES APART, BUT THE PRESSURE TESTER INDICATED BAD HEADS OR
12/12/2008
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9G489AARM KIT TRBCH CTR HSG RO 001 081613F 42 DOES NOT OPERATE PROPERLY
6K682 TURBO CHG-EXH DRIVE 000
93641 42 AFTER REPLACING BOTH CYLINDER HEAD GASKETS, NOTICED EXCESSIVE WHIT E SMOKE FROM EXHAUST ON TEST DRIVE. SMOKE SMELLED LIKE OIL NOT COOLANT. OIL LEAK DIAG LED TO TURBO. REMOVED CLAMPS ON INTAKE AND EXHAUST PIPES THAT AR E CONNECTED TO TURBO. INTAKE SIDE WAS DRY LOOKED NORMAL. EXHAUST SIDE HAD A LOT OF OIL RESIDUE IN IT. PER TSB 08-16-13, REMOVED AND DISASSEMBLED
05/21/2008
WARRANTY CLAIM NUMBER: 398249 ODOMETER: 076134M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 081103A 42 DOES NOT OPERATE PROPERLY
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 081103B
3C3Z 6619AA GASKET (OIL PUMP) 001 072109A
3C3Z 6619BA GASKET (OIL PUMP) 001 081103G
VC 7B 002
6051 GASKET CYL HEAD 000
76134 CONDITION CODE 42 CONFIRMED CUSTOMERS CONCERN,RAN ALL DIAGS RAN KOEO S ELF TEST FOUND P1335,401 AND 404 FOR EGR VALVE FAULT,PRESSURE TESTED COOLANT SYSTEM TO CHECK FOR OUTSIDE LEAKS,NONE FOUND BUT FOUND ENGINE HYDROLOCKED A FTER TEST RAN OASIS FOLLOWED TSB 08-11-03A FOR DIAGS FOLLOWED TSB 08-11-03B FOR REPAIR,FOUND EGR COOLER BLOWN DUE TO CLOGGED EGR VALVE OIL COOLER
2nd one
OASIS RESULT:
1FTWW33P56ED78474
USA
EN
04/02/2009
18:35:19
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
4N ENGINE CALIBRATION
ARN MESSAGES
WARRANTY START DATE
05/25/2006 BUILD DATE
04/18/2006 SALE MILEAGE
EXTENDED COVERAGES
NO RECENT REPAIR HISTORY ON VEHICLE
Reactions: HarleyMedic
What would you think about the 1st one? Trouble truck or all troublr found and fixed.
i would say fixed on number one. those are 2-common concerns that got repaired. the
2nd truck may have repair history too its just wont let us see it right now.
