OASIS RESULT:
1FTWW33P63EB42184
USA
EN
05/24/2009
03:24:43
FCXWS446
© Copyright 2002-2008 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
F2 ENGINE CALIBRATION
WARNING MESSAGES
ALL WARRANTY CANCELLED; TITLE BRANDED(CODE T1)
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 08-26-03
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/12/2002 BUILD DATE
11/27/2002 SALE MILEAGE
00078
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
1FTWW33P63EB42184 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-NOV-2002 12-DEC-2002 147463 USA 0 1F03 030304 * 8286 * L87 42 20
AWS Claim Key: 274085 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04629 - * Name: FRED FIRST, INC. Ph: 765-9660505 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:05-DEC-2002 Doc #:23429801
Cust Comments: COOLANT LEAK.
Tech Comments: CC 42 CCC L87 FOUND LOWER RADIATOR HOSE CLAMP LOOSE AND LEAKING. REPLACED CLAMP.
1FTWW33P63EB42184 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-NOV-2002 12-DEC-2002 147463 USA 4 3B01 070202 * 7A030 * L72 33 8474
AWS Claim Key: 860575 Trx Code: 2 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07965 - * Name: CRONIN FORD, INC. Ph: 513-3675300 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:13-MAR-2003 Doc #:061511B
Cust Comments: CUST REPORTS TRANS PAN IS LEAKING FLUID
Tech Comments: INSPECT & TIGHTEN TRANS COOLER LINES. RECHECK OK
1FTWW33P63EB42184 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-NOV-2002 12-DEC-2002 147463 USA 4 2E06 NANANA 3C3Z 9F838 DA D21 42 8474
AWS Claim Key: 860574 Trx Code: 2 Labor Hrs: 6.8
Dlr Cd-Sub Cd: 07965 - * Name: CRONIN FORD, INC. Ph: 513-3675300 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:13-MAR-2003 Doc #:061511A
Cust Comments: CUST REPORTS EXCESSIVE AMOUNT OF WHITE SMOKE COMING OUT OF TAIL PIPE, ENG FEELS LIKE IT IS GOING TO STALL
Tech Comments: TEST DRIVE VERIFY DIAG BY SHEET. CHANGE OIL DUE TOICP TEST. REPLACE ICP. R&R TURBO & INTAKE FOR ACC ESS. RETEST OK
1FTWW33P63EB42184 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-NOV-2002 12-DEC-2002 147463 USA 5 1A03 030100 * 6005 * D03 42 12634
AWS Claim Key: 1584016 Trx Code: E84 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 07965 - * Name: CRONIN FORD, INC. Ph: 513-3675300 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:23-APR-2003 Doc #:062333A
Cust Comments: IN MORNINGS ON COLD START, VEH STARTS RUNNING ROUGH AFTER 5 SEC
Tech Comments: VERIFY DIAG BY SHEET, PINPOINT TEST ICP, IPR, REPROGRAM MULTPLE MODULES PER REPROGRAMED PCM TCM AND FICM RESET ALL PARAMETERS CLEARED CODES RETEST
1FTWW33P63EB42184 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-NOV-2002 12-DEC-2002 147463 USA 6 2G05 * * * * * * 15426
AWS Claim Key: 1466598 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07965 - * Name: CRONIN FORD, INC. Ph: 513-3675300 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:09-JUN-2003 Doc #:063198A
Cust Comments: CHECK ENGINE LIGHT IS ON
Tech Comments: REPROGRAM MODULES TO LATEST CALIBRATION
1FTWW33P63EB42184 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-NOV-2002 12-DEC-2002 147463 USA 8 5A09 050201 1C3Z 4676 AA L86 D1 22822
AWS Claim Key: 1991149 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07965 - * Name: CRONIN FORD, INC. Ph: 513-3675300 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:16-JUL-2003 Doc #:063930A
Cust Comments: CK FLUID LEAK FROM REAR AXLE HOUSING
Tech Comments: VERIFED CONCERN FOUND PINION SEAL LEAKING R AND R DRIVE SHAFT FLANGE SEAL AND REPLACED RETESTE D OK
1FTWW33P63EB42184 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-NOV-2002 12-DEC-2002 147463 USA 10 2G01 * * * * * * 30205
AWS Claim Key: 2615970 Trx Code: 03L12 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07965 - * Name: CRONIN FORD, INC. Ph: 513-3675300 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:18-SEP-2003 Doc #:065138A
Cust Comments: RECALL 03L12 EEC1 LABEL REPLACEMENT
Tech Comments: REPLACE LABLE WITH REVISED LABEL AS PER INSTRUC TIONS
1FTWW33P63EB42184 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-NOV-2002 12-DEC-2002 147463 USA 15 2E05 100106 3C3Z 9B249 AB G29 42 53354
AWS Claim Key: 4617179 Trx Code: E72 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 07965 - * Name: CRONIN FORD, INC. Ph: 513-3675300 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:19-FEB-2004 Doc #:067965A
Cust Comments: CUST STATES THAT THE WHEN THEY HIT THE BRAKES THE WATER IN THE FUEL LIGHT COMES ON (SOP)
Tech Comments: VERIFY CUST CONCERN REPLACE FUEL MANIFOLD AS PER SSM 17076 RETESTED DROVE THE TRUCK IT IS OK NOW
1FTWW33P63EB42184 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-NOV-2002 12-DEC-2002 147463 USA 35 2E01 * * * * * * 136884
AWS Claim Key: 12206531 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01466 - * Name: TOWN & COUNTRY FORD Ph: 812-4713673 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2005 Doc #:06385940
Cust Comments: 03B05 INJECTION CONTROL PRESSURE (ICP) SENSOR REPLACEMENT
Tech Comments: PERFORM RECALL REPLACE SENSOR
1FTWW33P63EB42184 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-NOV-2002 12-DEC-2002 147463 USA 41 * * * * * * * 147553
AWS Claim Key: 13651484 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04634 - * Name: MIKE RAISOR FORD Ph: 765-4479444 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:21-APR-2006 Doc #:04961441
Cust Comments: 06E17 CONTROL MODULE RECALIBRATION
Tech Comments: REPROGRAM PCM, TCM, AND FICM
AWS Claim Key: 13651483 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04634 - * Name: MIKE RAISOR FORD Ph: 765-4479444 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:21-APR-2006 Doc #:04961440
Cust Comments: 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO
Tech Comments: CUSTOMER ASSURANCE ROADTEST
