2004 f-350 1ftsw31p94ea46293 thank you in adavance
Standard Claims List For Model Year 2004
1FTSW31P94EA46293 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-AUG-2003 13-NOV-2003 116422 USA 5 2H02 030008 3C3Z 6F089 AA N12 42 6454
AWS Claim Key: 638434 Trx Code: S07 Labor Hrs: 3.8
Dlr Cd-Sub Cd: 01492 - * Name: KEYSER & MILLER FORD, INC. Ph: 610-4899366 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:30-MAR-2004 Doc #:06315401
Cust Comments: CHECK NOISE WHILE DRIVING SOUNDS LIKE CHAINS DRAGGING
Tech Comments: ROAD TEST VERIFIED CUSTOMERS CONCERN CALLED TECH ASSIST HOTLINE CHECKED AIR CHARGE TUBES AND AIR BOX FOUND TURBO ACTUATOR FAULTY REPALCED TURBO ACTUATOR ROAD TEST TO RECHECK OPERATION GOOD NOISE GONE
1FTSW31P94EA46293 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-AUG-2003 13-NOV-2003 116422 USA 8 2H02 030008 3C3Z 6F089 AA N12 42 11996
AWS Claim Key: 1296782 Trx Code: S07 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 01492 - * Name: KEYSER & MILLER FORD, INC. Ph: 610-4899366 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:05-JUL-2004 Doc #:06731001
Tech Comments: ROAD TESTED VERIFIED NOISE WHILE DRIVING PREFORMED PIN POINT TEST CALLED FORD TECHNICIAN HOTLINE REPLACED TURBO ACCUATOR RECHECKED OPERATION AFTER REPAIRS ROAD TEST OKAY
1FTSW31P94EA46293 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-AUG-2003 13-NOV-2003 116422 USA 8 3N01 110402 3C3Z 7210 BBA P51 42 12158
AWS Claim Key: 1438710 Trx Code: 2 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01492 - * Name: KEYSER & MILLER FORD, INC. Ph: 610-4899366 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:08-JUL-2004 Doc #:06749401
Cust Comments: CUSTOMER STATES LEVER FOR OVERDRIVE CAME APART
Tech Comments: GEAR SELECTOR LEVER 7210 REPLACE INCLUDES SHIFT BOOT ON MANUAL TRANSMISSI ON APPLICATIONS INCLUDES TIME TO REMOVE AND INSTALL STEERING COLUMN SHROUDS ORAUTO TRANS
1FTSW31P94EA46293 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-AUG-2003 13-NOV-2003 116422 USA 21 2G05 031405 * RECAL * E29 79 29078
AWS Claim Key: 6204572 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01350 - * Name: NORRISTOWN AUTOMOBILE COMPANY, INC. Ph: 610-5395400 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:29-JUL-2005 Doc #:20677601
Cust Comments: CUSTOMER STATES BLACK SMOKE OUT EXHAUST
Tech Comments: PERFORM DIAGNOSTIC CK .. REPROGRAM CONTROLLER ORDER EGR VALVE .. WILL CONTACT CUSTOMER WHEN PARTS ARE HERE
1FTSW31P94EA46293 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-AUG-2003 13-NOV-2003 116422 USA 22 1H03 030008 4C3Z 9F452 A D42 42 29938
AWS Claim Key: 6497365 Trx Code: S07 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 01350 - * Name: NORRISTOWN AUTOMOBILE COMPANY, INC. Ph: 610-5395400 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:16-AUG-2005 Doc #:20781201
Cust Comments: CUSTOMER STATES SMOKE OUT EXHAUST PARTS HERE
Tech Comments: PERFORM DIAGNOSTIC CK .. FOUND EGR VALVE STICKING REPLACE EGR VALVE AND RETEST
1FTSW31P94EA46293 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-AUG-2003 13-NOV-2003 116422 USA 31 2H01 031202 5C3Z 6C640 AA D50 42 46764
AWS Claim Key: 9338430 Trx Code: E72 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03952 - * Name: JOHN KENNEDY FORD, INC. Ph: 610-9335811 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:06-MAY-2006 Doc #:14959101
Cust Comments: CUST STS HOSE TO TURBO BALLOONED UP
Tech Comments: VERIFIED CONCERN REPLACED AFFECTED CAC TUBE
1FTSW31P94EA46293 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-AUG-2003 13-NOV-2003 116422 USA 31 * * * * * * * 46764
AWS Claim Key: 9338429 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03952 - * Name: JOHN KENNEDY FORD, INC. Ph: 610-9335811 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:06-MAY-2006 Doc #:14959102
AWS Claim Key: 9338428 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03952 - * Name: JOHN KENNEDY FORD, INC. Ph: 610-9335811 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:06-MAY-2006 Doc #:14959103
1FTSW31P94EA46293 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-AUG-2003 13-NOV-2003 116422 USA 32 2H01 030008 3C3Z 6K854 DA E41 D1 50546
AWS Claim Key: 9766865 Trx Code: E72 Labor Hrs: 7.8
Dlr Cd-Sub Cd: 03952 - * Name: JOHN KENNEDY FORD, INC. Ph: 610-9335811 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:19-JUN-2006 Doc #:15074101
Cust Comments: CUSTOMER STATES EXHAUST PIPE TO TURBO IS CRACKED
Tech Comments: TURBO Y PIPE FLEX JOINT CRACKED ACCESS AND REPLACE Y PIPE TO TURBO. NECESSARY TO R&I TRANSMISSION TO GAIN ACCESS TO SEIZED PIPE BOLTS. EXTRACTED AND REPLACED BOLTS. REASSEMBLED AND ROAD TESTED OK
1FTSW31P94EA46293 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-AUG-2003 13-NOV-2003 116422 USA 36 2E06 030008 3C3Z 9F838 EA L65 D8 58659
AWS Claim Key: 10505988 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 01273 - * Name: FRED BEANS FORD OF BOYERTOWN, INC. Ph: 610-3672081 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:17-OCT-2006 Doc #:31149801
Cust Comments: CUSTOMER STATES: CHECK FOR OIL LEAK AT THE BACK OF MOTOR AREA
Tech Comments: CHECK OIL LEAK PUT DYE INTO ENGINE OIL AND CHECK WITH LIGHT FOUND ICP SENSOR LEAKING THROUGH PLUG REPLACED ICP SENSOR AND RECHECK OK
1FTSW31P94EA46293 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-AUG-2003 13-NOV-2003 116422 USA 36 7W06 000301 3L2Z 14A626 AA L20 42 58945
AWS Claim Key: 10590380 Trx Code: 0736D Labor Hrs: 0.9
Dlr Cd-Sub Cd: 01330 - * Name: JOHN KENNEDY FORD-LINCOLN-MERCURY, INC. Ph: 610-4957172 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:24-OCT-2006 Doc #:20578801
Cust Comments: CUST STS KEYLESS ENTRY INOP, ALSO PAD DOES NOT LIGHT UP PAD HERE
Tech Comments: REPLACED KEYLESS ENTRY PAD EXTRA TIME NEEDED TO SCRAPE OFF ADHESIVE ON DOOR
1FTSW31P94EA46293 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-AUG-2003 13-NOV-2003 116422 USA 43 2H02 030008 * 6F089 * D13 42 66845
AWS Claim Key: 11611999 Trx Code: E72 Labor Hrs: 8.3
Dlr Cd-Sub Cd: 01273 - * Name: FRED BEANS FORD OF BOYERTOWN, INC. Ph: 610-3672081 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2007 Doc #:32145201
Cust Comments: CUSTOMER STATES: AT TIMES TURBO CUTS OUT , NO BOOST AND THAN COMES BACK ON AND RUNS FINE, NO CHECK ENGINE LIGHT WAS SEEN
Tech Comments: CHECK FOR NO BOOST TEST DROVE VEHICLE VERIFIED CONCERN PERFORMED COMPUTER TEST PULLED CODES P0404,P0478,P2263 AND P0299 EGR CODE AND TURBO CODE. CHECKED TSB FOUND TSB 06 23 2 AND TSB 06 19 6 AND 07 5 4. FOLLOWED TSB PROCEDURE CLEANED AND TESTED TURBO FAILED TEST REPLACED TURBO CLEANED EGR VALVE PASSED REPROGRAMED FICM CLEARED ALL CODES TEST
1FTSW31P94EA46293 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-AUG-2003 13-NOV-2003 116422 USA 43 2E06 100106 3C3Z 9C407 AB E68 42 66845
AWS Claim Key: 11611998 Trx Code: E72 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 01273 - * Name: FRED BEANS FORD OF BOYERTOWN, INC. Ph: 610-3672081 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2007 Doc #:32145202
Cust Comments: CUSTOMER STATES: CHECK FOR LOUD HUM NOISE FROM FUEL TANK LIKE FUEL PUMP IS GOING BAD
Tech Comments: CHECK FUEL SYSTEM REPLACED FUEL PUMP NO NOISE AT THIS TIME.
