Standard Claims List For Model Year 2003
1FTNW21F73EA45432 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 23-AUG-2002 15-SEP-2002 124486 USA 4 2E03 030008 F81Z 9C968 AB D42 42 6510
AWS Claim Key: 370670 Trx Code: S07 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 01033 - * Name: YADKIN VALLEY MOTOR COMPANY, INC. Ph: 336-8384155 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:04-JAN-2003 Doc #:102677A
Cust Comments: CHECK LOSS OF POWER ENGINE DIES AT TIMES
Tech Comments: STAR TEST CODE P1211. R&R ICP AND IPR SENSOR & VALVE. RETEST OK. CLEAR TEST. ROAD TEST OK
1FTNW21F73EA45432 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 23-AUG-2002 15-SEP-2002 124486 USA 25 2G02 0300XX F7TZ 12K073 A D02 42 36183
AWS Claim Key: 7861008 Trx Code: S07 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 04970 - * Name: KARL FLAMMER FORD INC Ph: 727-9375131 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:28-SEP-2004 Doc #:07052651
Cust Comments: CUSTOMER STATES THAT VEHICLE CRANKS BUT WILL NOT START ADVISE
Tech Comments: INOP HARD START NO START DIAGNOSTICS DIESEL ENGINE DIAGNOSI
1FTNW21F73EA45432 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 23-AUG-2002 15-SEP-2002 124486 USA 53 2E05 100103 F81Z 9155 AC L65 42 66845
AWS Claim Key: 14782050 Trx Code: E72 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 04807 - * Name: FREEDOM FORD, INC. Ph: 727-7972277 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:10-JAN-2007 Doc #:16101101
Cust Comments: CUSTOMER STATES ENGINE OIL LEAK ,ADVISE
Tech Comments: FUEL WATER SEPARATOR VERIFY CONCERN FOR MAJOR FUEL LEAK. PINPOINT LEAK TO FUEL WATER SEPARATOR. REPLACE ASSEMBLY.RECHECK ALL O.K.
1FTNW21F73EA45432 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 23-AUG-2002 15-SEP-2002 124486 USA 54 2E03 030402 F81Z 9A543 CRM L85 42 67223
AWS Claim Key: 14834014 Trx Code: E72 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 04807 - * Name: FREEDOM FORD, INC. Ph: 727-7972277 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:29-JAN-2007 Doc #:16220501
Cust Comments: ENGINE OIL LEAK, WAS TOLD INJECTOR PUMP, ADVISE 3.
Tech Comments: INJECTOR PUMP VERIFY COMPLAINT PERFORM OIL LEAK DIAG. PINPOINT LEAK TO OIL PIMP AND GASKET. ROADTEST AFTER REPAIR
1FTNW21F73EA45432 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 23-AUG-2002 15-SEP-2002 124486 USA 76 * * * * * * * 86204
AWS Claim Key: 16264739 Trx Code: 07S57 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08183 - * Name: COUNTRYSIDE FORD OF CLEARWATER Ph: 727-7936222 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2008 Doc #:01885952
Cust Comments: PERFORM RECALL 07S57
Tech Comments: OPEN RECALL 07S57 INSPECT AND REPLACE CMP SENSOR BLACK WITH GOLD BRACKET
09s09 speed control recall open
