Would one of you guys be so kind to run a Oasis Report for me?
I bought my truck used with 21000 miles on it about a year ago and want to know if anything major was done to it prior to my purchase.
So far so good at 42000 miles (Job 1 - 2008 F350 - SRW - King Ranch - CC)
VIN # 1FTSW31R68EB17201
Thank you for your help.
Standard Claims List For Model Year 2008
1FTSW31R68EB17201 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 01-MAY-2007 10-MAY-2007 124480 USA 23 6J08 0114XX 7C3Z 2522405 AA L08 33 24427
AWS Claim Key: 3080442 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04845 - * Name: SAM GALLOWAY FORD LINCOLN MERCURY Ph: 239-9363673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2009 Doc #:09460207
Cust Comments: CHECK DR EXCT DOOR HANDLE LOOSE
Tech Comments: REMOVE INNER DOOR PANEL, REPLACE LEFT EXT DOOR HANDLE
1FTSW31R68EB17201 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 01-MAY-2007 10-MAY-2007 124480 USA 23 1F01 * * * * * * 24427
AWS Claim Key: 3092058 Trx Code: 08B06 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 04845 - * Name: SAM GALLOWAY FORD LINCOLN MERCURY Ph: 239-9363673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2009 Doc #:09460206
Cust Comments: PERFORM 08B06 RELATED DAMAGE
Tech Comments: PRESS TEST COOLING SYS REPLACE LEAKING RADIATOR
1FTSW31R68EB17201 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 01-MAY-2007 10-MAY-2007 124480 USA 23 2E02 * * * * * * 24427
AWS Claim Key: 3080440 Trx Code: 08C04 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 04845 - * Name: SAM GALLOWAY FORD LINCOLN MERCURY Ph: 239-9363673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2009 Doc #:09460204
AWS Claim Key: 3080439 Trx Code: 08B06 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04845 - * Name: SAM GALLOWAY FORD LINCOLN MERCURY Ph: 239-9363673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2009 Doc #:09460203
1FTSW31R68EB17201 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 01-MAY-2007 10-MAY-2007 124480 USA 23 6E01 * * * * * * 24427
AWS Claim Key: 3080441 Trx Code: 08C01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04845 - * Name: SAM GALLOWAY FORD LINCOLN MERCURY Ph: 239-9363673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2009 Doc #:09460205
1FTSW31R68EB17201 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 01-MAY-2007 10-MAY-2007 124480 USA 23 2G01 * * * * * * 24427
AWS Claim Key: 3080438 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04845 - * Name: SAM GALLOWAY FORD LINCOLN MERCURY Ph: 239-9363673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2009 Doc #:09460202
1FTSW31R68EB17201 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 01-MAY-2007 10-MAY-2007 124480 USA 27 7H06 120305 6W7Z 19B596 B C02 D1 28311
AWS Claim Key: 3993878 Trx Code: E83 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 04845 - * Name: SAM GALLOWAY FORD LINCOLN MERCURY Ph: 239-9363673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:22-JUL-2009 Doc #:11641902
Cust Comments: CHECK AC GOES FROM COLD TO WARM
Tech Comments: .43 PSI LOW 145 HI LOW ON COOLANT PEANUT GASKET LEAKING ON COMP INLET HOSE REPLACE GASKET EVAC RECHARGE VENTS 43 DEG
1FTSW31R68EB17201 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 01-MAY-2007 10-MAY-2007 124480 USA 29 7A01 140101 BXT 65 750 C26 42 30290
AWS Claim Key: 4355113 Trx Code: E83 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 04845 - * Name: SAM GALLOWAY FORD LINCOLN MERCURY Ph: 239-9363673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:11-SEP-2009 Doc #:12464901
Cust Comments: CHECK NO START
Tech Comments: TEST AND REPLACE BOTH BATTERIES
Reactions: MGRECO
Thank you very much for the info.
Looks like the radiator already pooped out on the prior owner and was replaced before me.
Thanks again!
