Hi,
Just wondering if one of you fine gentlemen can run:
1FTSW21R58EB05924
Very much appreciated.
Jeremy
Standard Claims List For Model Year 2008
1FTSW21R58EB05924 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 27-APR-2007 27-JUL-2007 4B3274 CAN 0 2E03 030008 8C3Z 9E527 DAA D13 42 157
AWS Claim Key: 59286 Trx Code: 07T07 Labor Hrs: 2.9
Dlr Cd-Sub Cd: B3230 - * Name: HIGHLAND FORD SALES LIMITED Ph: 902-7528243 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:04-JUN-2007 Doc #:07503001
Cust Comments: DEMONSTRATION DELIVERY HOLD AS PER 07T07 FUEL INJECTOR REPLACEMENT
Tech Comments: VERIFIED CAMPAIGN WITH SPECIAL SERVICE SUPPORT CENTER REFERENCE NUMBER 50380 REPLACED INJECTORS 1 5 AND 7 AS PER CAMPAIGN GUIDELINES AND RUN HIGH PRESUURE FUEL TEST. OK NOW
1FTSW21R58EB05924 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 27-APR-2007 27-JUL-2007 4B3274 CAN 2 1F03 030304 * 8287 * C07 D1 3100
AWS Claim Key: 124148 Trx Code: 2 Labor Hrs: 2
Dlr Cd-Sub Cd: B3274 - * Name: CANSO FORD SALES LTD Ph: 902-6251338 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:31-AUG-2007 Doc #:02177101
Cust Comments: VEHICL LOOSING COOLANT,LEAVING PUDDLE IN DRIVEWAY
Tech Comments: HOSE CLAMP LEAKING PRESSURE TEST AND FOUND HOSE CLAMP LEAKING,TIGHTEN CLAMPS. NECESSSARY TO FLUSH SYSTEM,AS WRONG COOLANT WAS PUT AS REPLACEMENT WHEN COOLANT WAS FILLED AT LOCAL GARAGE
1FTSW21R58EB05924 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 27-APR-2007 27-JUL-2007 4B3274 CAN 7 7D07 170202 E6DZ 13466 B L29 46 14464
AWS Claim Key: 460925 Trx Code: E83 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B3274 - * Name: CANSO FORD SALES LTD Ph: 902-6251338 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:06-FEB-2008 Doc #:02445202
Cust Comments: RIGHT SIDE BACK UP LIGHT OUT
Tech Comments: NESC. TO REPLACE BULB TESTED OK
1FTSW21R58EB05924 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 27-APR-2007 27-JUL-2007 4B3274 CAN 7 2G88 000615 * NPF * L87 D1 14464
AWS Claim Key: 460924 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: B3274 - * Name: CANSO FORD SALES LTD Ph: 902-6251338 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:06-FEB-2008 Doc #:02445203
Cust Comments: GOING DOWN IN COOLANT
Tech Comments: COULD NOT DUPLICATE CONCERN AT HTIS TIME CHECKED HOTLINE ,CHECKED OASIS ,NO ISSUES,PRESSURE TESTED SYSTEM,INSPECTED COOLING SYSTEM,COULD NOT DUPLICATE .
1FTSW21R58EB05924 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 27-APR-2007 27-JUL-2007 4B3274 CAN 12 6E01 * * * * * * 23788
AWS Claim Key: 1264982 Trx Code: 08C01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B3274 - * Name: CANSO FORD SALES LTD Ph: 902-6251338 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:26-JUN-2008 Doc #:02684305
Cust Comments: 08C01 SEAT BACK INSPECTION
Tech Comments: INSTALL CLAMP ON SEAT BACK PER 08C01
1FTSW21R58EB05924 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 27-APR-2007 27-JUL-2007 4B3274 CAN 12 1H03 030008 8C3Z 9F464 B L87 D1 23788
AWS Claim Key: 1293680 Trx Code: S07 Labor Hrs: 8.2
Dlr Cd-Sub Cd: B3274 - * Name: CANSO FORD SALES LTD Ph: 902-6251338 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:26-JUN-2008 Doc #:02684303
Cust Comments: VEHICLE GOING DOWN ON COOLANT
Tech Comments: LEAKING COOLERS PRESSURE TEST SYSTEM,REMOVED EBP SENSOR AND FOUND PRESENCE OF COOLANT IN COOLERS,NECESSARY TO REPLACE VERTICAL AND HORIZONTAL EGR COOLERS,RETEST ALL OK
1FTSW21R58EB05924 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 27-APR-2007 27-JUL-2007 4B3274 CAN 12 2E02 * * * * * * 23788
AWS Claim Key: 1264983 Trx Code: 08C04 Labor Hrs: 0.9
Dlr Cd-Sub Cd: B3274 - * Name: CANSO FORD SALES LTD Ph: 902-6251338 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:26-JUN-2008 Doc #:02684304
Cust Comments: 08S04 FUEL TANK BRACKET
Tech Comments: PERFORM FUEL TANK BRACKET RECALL
1FTSW21R58EB05924 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 27-APR-2007 27-JUL-2007 4B3274 CAN 17 7S06 180101 * 12A581 * L26 42 35133
AWS Claim Key: 2281429 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: B3352 - * Name: CHEBUCTO FORD SALES Ph: 902-4347700 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:17-DEC-2008 Doc #:21377101
Cust Comments: CUST STATES THE PLUG FOR THE LIGHTS DOES NOT WORK IN THE TRAILOR HI
Tech Comments: CHECKED TRAILER WIRING, OK @ PRESENT(BOTH PLUGS), TIGHTENED CONNECTIONS @ TRAILER TOW RELAYS IN BATTERYJUNCTION BOX. PIN 85 @ RELAY WAS LOOSE, TRA ILER TOW RELAY IN BATTERY JUNCTION BOX.
1FTSW21R58EB05924 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 27-APR-2007 27-JUL-2007 4B3274 CAN 19 1F01 * * * * * * 35133
AWS Claim Key: 2914231 Trx Code: 08B06 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B3352 - * Name: CHEBUCTO FORD SALES Ph: 902-4347700 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:27-JAN-2009 Doc #:21548201
Cust Comments: RECALLS 08B06
Tech Comments: PERFORMED CAMPAIGN 08B06C
1FTSW21R58EB05924 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 27-APR-2007 27-JUL-2007 4B3274 CAN 19 2G01 * * * * * * 35133
AWS Claim Key: 2914233 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: B3352 - * Name: CHEBUCTO FORD SALES Ph: 902-4347700 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:27-JAN-2009 Doc #:21548203
Cust Comments: PERFORM CAMPAIGN 08B07
Tech Comments: PERFORMED CAMPAIGN 08B07B
1FTSW21R58EB05924 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 27-APR-2007 27-JUL-2007 4B3274 CAN 19 2H01 030008 8C3Z 6K854 A E42 42 35133
AWS Claim Key: 2914232 Trx Code: S07 Labor Hrs: 7.2
Dlr Cd-Sub Cd: B3352 - * Name: CHEBUCTO FORD SALES Ph: 902-4347700 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:27-JAN-2009 Doc #:21548202
Cust Comments: CUST STASTES THERE'S A WHISTLE NOISE IN ENGINE
Tech Comments: VERIFIED NOISE, CHECKED AROUND THE TURBO, NOTICED THE RIGHT ADAPPTOR PIPE BLACK WITH SOOT AROUND THE BELLOWS. REMOVEDTHE EBP SENSOR AND PLUGGED TH E EXHAUST, SMOKE TESTED THE SYSTEM, THE ADAPTOR PIPE WAS LEAKING AT THE BELLOWS. ORDERED PARTS. REMOVED THE CAB AS PER WORKSHOP MANUAL, REPLACED THE RIGHT ADAPTOR PIPE AND ALL RELATED GASKETS AND BOLTS. THE SECOND AND FIRST MOUNT CAGE NUTS SPUN IN
1FTSW21R58EB05924 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 27-APR-2007 27-JUL-2007 4B3274 CAN 19 7D01 170101 5C3Z 13N021 AA L26 46 35133
AWS Claim Key: 2914234 Trx Code: E83 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B3352 - * Name: CHEBUCTO FORD SALES Ph: 902-4347700 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:27-JAN-2009 Doc #:21548204
Cust Comments: CUST STATES THE L/F HEADLIGHT IS NOT WIRKING
Tech Comments: REPLACED THE BULB,TRIED OKAY.
1FTSW21R58EB05924 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 27-APR-2007 27-JUL-2007 4B3274 CAN 22 6A06 010301 * 2820124 * F06 05 36117
AWS Claim Key: 3867525 Trx Code: E84 Labor Hrs: 2.8
Dlr Cd-Sub Cd: B3274 - * Name: CANSO FORD SALES LTD Ph: 902-6251338 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:27-APR-2009 Doc #:03203101
Cust Comments: PAINT PEELED & RUSTED AT BELT MOULDING AREAS OF RT & LEFT REAR DOORS
Tech Comments: BELT MOULDING CHAFFED TRHOUGH PAINT REMOVED RT & LEFT REAR DOOR BELT MLDS. REPAIRED RUSTED AREAS PREPPED FOR PAINT & REFINISHED.
1FTSW21R58EB05924 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 27-APR-2007 27-JUL-2007 4B3274 CAN 24 5Y03 06XXXX 8C3Z 2553 A H02 41 44506
AWS Claim Key: 3867526 Trx Code: 2169D Labor Hrs: 1.2
Dlr Cd-Sub Cd: B3274 - * Name: CANSO FORD SALES LTD Ph: 902-6251338 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:19-JUN-2009 Doc #:03315803
Cust Comments: LEFT REAR CALIPER STUCK AND WORE PADS
Tech Comments: NESC. TO REPLACE LEFT REAR CALIPER AND REAR BRAKE PADS, BLEED BRAKES. VERIFIED PROPER OPERATION.
1FTSW21R58EB05924 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 27-APR-2007 27-JUL-2007 4B3274 CAN 30 1H03 030804 8C3Z 9D475 D D03 46 55992
AWS Claim Key: 5032060 Trx Code: S07 Labor Hrs: 4.3
Dlr Cd-Sub Cd: A3219 - * Name: FAIRLEY & STEVENS LTD Ph: 902-4631220 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:21-DEC-2009 Doc #:18748401
Cust Comments: TRUCK JUST STARTS UP AND THEN JUST QUITS, PLEASE ADVISE (D03)
Tech Comments: EEC TEST AND PINPOINT TEST, NEEDS EGR VALVE, EGR VALVE WAS SEIZED IN HOUSING, HAD TO REPLACE HOUSING RETEST (46)
1FTSW21R58EB05924 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 27-APR-2007 27-JUL-2007 4B3274 CAN 32 2E03 030402 8C3Z 9E527 A D50 42 60179
AWS Claim Key: 5473388 Trx Code: S07 Labor Hrs: 5.3
Dlr Cd-Sub Cd: B3352 - * Name: CHEBUCTO FORD SALES Ph: 902-4347700 St:NS Ctry Cd: CAN Reg Cd: NA Repr Date:24-FEB-2010 Doc #:23404101
Cust Comments: CUSTOMER REPORTS THAT VEHICLE IS BUCKING AND SMOKING DOES SEEM TO B
Tech Comments: VERIFIED CONCERN, FOLLOWED THE ENGINE PERF SHEET, PERFORMED ALL PRECHECKS, CHECKED LOW PRESSURE FUEL SYSTEM AND HIGHPRESSURE SYSTEM, OK. CHECKED F UEL CONDITION, OK. PERFORMED EEC TEST, SERVICE CODE P0272 WAS RECEIVED. PERFORMED CYLINDER BALANCE, #4 INJECTOR WASN'T FIRING. PERFORMED RELATIVE COMPRESSION, OK. REMOVED THE LEFT SIDE VALVE COVER AND REPLACED THE INJECTOR, BLED FUEL SYSTEM, ROAD T
Reactions: jstreet
Pretty good list there but thats your money not mine.
