please if you don't mind. I am going to give up and go buy new if this one isn't worth a ***** or it sells before I can go look at it tomorrow and put a deposit on it.
1FTSW21P07EA08305
thanks again
Craig Glenn
Standard Claims List For Model Year 2007
1FTSW21P07EA08305 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 19-MAY-2006 18-JAN-2007 152731 USA 9 5V10 060601 5C3Z 2140 HA G32 42 12179
AWS Claim Key: 1627664 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 07282 - * Name: CHASTANG FORD Ph: 713-6785000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:04-OCT-2007 Doc #:116452A
Cust Comments: INSTRUMENT CLUSTER SHOWS TBC FAULT
Tech Comments: CK FAULT CODE, HOOK UP ODS AND RETRIEVE DTCS FOR TBC. DTC C2800. PERFOM PINPOINT C7 C9 REPLACE MASTER CYLINDER AND BLEED AIR OUT BRK SYS.,RETEST,O
1FTSW21P07EA08305 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 19-MAY-2006 18-JAN-2007 152731 USA 10 6E07 011001 5C3Z 7863388 CA T53 33 11930
AWS Claim Key: 1344398 Trx Code: 2 Labor Hrs: 0
Dlr Cd-Sub Cd: 04462 - * Name: RANDALL REED'S PLANET FORD Ph: 281-4469171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-NOV-2007 Doc #:39839701
Cust Comments: CK SCUFF PLATES TRIM COVERS COMING LOOSE
Tech Comments: INSTALLED SCUFF PLATE
1FTSW21P07EA08305 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 19-MAY-2006 18-JAN-2007 152731 USA 17 5Q02 110203 5C3Z 3A717 CA L68 D1 23964
AWS Claim Key: 2590646 Trx Code: E84 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 07462 - * Name: ANDERSON FORD-MERCURY Ph: 281-5922611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-MAY-2008 Doc #:165942A
Cust Comments: L85 C S VEHICLE LEAKING FLUID IN FRT. END AREA SOP PART HERE
Tech Comments: VERIFY CUSTOMER CONCERN FOUND POWER STEERING LINE LEAKING AT HYDRO BOOST FROM PUMP NECESSARY TO REPLACE LINE FILL UNIT VACUUM BLEED ROAD TEST OK
