I need an Oasis Report for a truck I just bought, whenever one of you guys get time.
Thanks in advance!
1FTWW33P67EA53981
Standard Claims List For Model Year 2007
1FTWW33P67EA53981 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 28-JUN-2006 30-SEP-2006 123211 USA 33 2E01 030408 4C3Z 9B246 D D50 42 63055
AWS Claim Key: 4693395 Trx Code: E72 Labor Hrs: 12.2
Dlr Cd-Sub Cd: 05075 - * Name: LEWIS FORD SALES, INC. Ph: 479-4425301 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:03-JUN-2009 Doc #:074927A
Cust Comments: CUST STATES CRANK NO START AND EXTENDED CRANK INTER
Tech Comments: 63060 HIGH PRESSURE OIL LEAK CAUSING LONG CRANK TIMES CK LONG CRANK TIME, VERIFY CONCERN, CK OIL OK, CK CODES KOEO PASS, KOER PASS, KOEC P2291, CK OASIS TSB 08 18 6, CK ICP VOLTAGE OK, ICP PRESSURE SLOW TO BUILD ON CRANK, REPLACE IPR VALVE, RETEST, ICP SLOW TO BUILD PRESSURE,AIR PRESSURE TEST HIGH PRESSURE OIL SYSTEM PER TSB, INDICATES LEAK, TEST HIGH PRESSURE PUMP OK,
1FTWW33P67EA53981 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 28-JUN-2006 30-SEP-2006 123211 USA 46 2E03 030402 4C3Z 9E527 BRM D50 42 84456
AWS Claim Key: 6154562 Trx Code: S07 Labor Hrs: 4
Dlr Cd-Sub Cd: 05075 - * Name: LEWIS FORD SALES, INC. Ph: 479-4425301 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:17-JUN-2010 Doc #:088527B
Cust Comments: CUSTOMER STATES TRUCK RUNS ROUGH WHEN COLD. TAKES ABOUT 10 MIN TO RUN RIGHT
Tech Comments: DIAG AND FOUND CODE P0266,PREFORMED PREFORMANCE TESTS AND FOUND #2,6 FAIL POWER BALLANCE TESTS,TESTED FICM POWERS AND ARE GOOD MPWR 49V,VPWR 13.9V REPROGRAMED PCM AND RETESTED AND STILL HAS MISFIRE,TESTED FUEL PRESURE 55.PSI,RELITIVE COMP ALL GOOD,REPLACED INJECTORS #2,6 TEST DRIVE AND RETESTED OK.
