Standard Claims List For Model Year 2004
1FTNW21P04EA88066 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-SEP-2003 12-APR-2004 4B6086 CAN 0 2G05 031405 * RECAL * D50 79 16
AWS Claim Key: 117157 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: B6086 - * Name: WINDSOR MOTORS 1975 LTD. Ph: 780-5329550 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:03-NOV-2003 Doc #:04651901
Cust Comments: RECLL 03T02 REPROGRAM PCM
Tech Comments: PERFORM RECALL 03T02, RE PROGRAM PCM.
1FTNW21P04EA88066 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-SEP-2003 12-APR-2004 4B6086 CAN 1 5G04 040105 * 5482 * N50 42 2160
AWS Claim Key: 789333 Trx Code: 1 Labor Hrs: 0.6
Dlr Cd-Sub Cd: B6086 - * Name: WINDSOR MOTORS 1975 LTD. Ph: 780-5329550 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:29-APR-2004 Doc #:05155101
Cust Comments: FRONT END IS SQUEAKING. WHEN TRAVELLING REGULAR ROADS.
Tech Comments: CHECKED FOR FRONT END SQUEAKING. FOUND FRONT STAB BUSHINGS FULL OF WATER ANDDIRT. NO LUBE FROM FACTORY. LUBRICATED. VERIFIED REPAIR BY ROADTEST OK. MT TIME TO INSPECT AND COMPLETE REPAIR.
1FTNW21P04EA88066 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-SEP-2003 12-APR-2004 4B6086 CAN 1 2G05 031405 * RECAL * D50 42 2565
AWS Claim Key: 897646 Trx Code: 1 Labor Hrs: 1
Dlr Cd-Sub Cd: B6086 - * Name: WINDSOR MOTORS 1975 LTD. Ph: 780-5329550 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:07-MAY-2004 Doc #:05180301
Cust Comments: ENGINE CUTS OUT AT 135 KMH
Tech Comments: INSPECTED FOR ENGINE CUTS OUT AT 135KM/HR. PERFORMED A PCM UPDATE, & TIRE RPM REPROGRAM. ROAD TESTED FOUND THIS MADE NO CHANGE. CONTACTED TECH HOTLINE AND SPOKE WITH MARK REPORT #4EFI2023. DISCOVERED IT WAS A FACTORY ERROR, THE PCM HAD BEEN PROGRAMMED FOR A F550/450. DOWNLOADED RELAVANT DATA FROM INFORD, IT HAD A 3U7A FVA PCM, CHANGED PROGRAMMING TO 307A FTC PCM & RETESTED OK. MT TIME TO DIAG FOR
1FTNW21P04EA88066 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-SEP-2003 12-APR-2004 4B6086 CAN 3 5J01 040301 * 18124 * N50 33 6386
AWS Claim Key: 1141511 Trx Code: 1 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B6086 - * Name: WINDSOR MOTORS 1975 LTD. Ph: 780-5329550 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:17-JUN-2004 Doc #:05310901
Cust Comments: KNOCK IN FRONT END OVER BUMPS
Tech Comments: ROADTESTED TO VERIFY KNOCK IN FRONT END. RIGHT SIDE SHOCK IS LOOSE. TIGHTENED SHOCK AND RETESTED OK MT TIME TO INSPECT & COMPLETE REPAIR.
1FTNW21P04EA88066 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-SEP-2003 12-APR-2004 4B6086 CAN 4 5J01 040301 * 18124 * H44 42 12059
AWS Claim Key: 1436520 Trx Code: 1 Labor Hrs: 0.4
Dlr Cd-Sub Cd: B6086 - * Name: WINDSOR MOTORS 1975 LTD. Ph: 780-5329550 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:22-JUL-2004 Doc #:05422501
Cust Comments: CHECK FOR HARSH RIDE.
Tech Comments: INSPECTED AND VERIFIED HARSH RIDE. FOUND FRONT SHOCKS LEAKING BADLY. REPLACED FRONT SHOCKS AND TESTED OK. SIMILAR REPAIR WITH RO#053109, HOWEVER IN THAT RO WE SIMPLY TIGHTENED THE SHOCKS AS THEY WERE LOOSE. IN THIS RO THE SHOCKS WERE LEAKING AND HAD TO BE REPLACED. NOTE: THIS IS NOT A REPEAT REPAIR, IN RO#053109, THE SHOCKS WERE TIGHTENED FOR LOOSENESS
1FTNW21P04EA88066 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-SEP-2003 12-APR-2004 4B6086 CAN 11 2E05 100106 3C3Z 9B249 AB G29 42 60168
AWS Claim Key: 4028588 Trx Code: E72 Labor Hrs: 1
Dlr Cd-Sub Cd: 09845 - * Name: SWEETWATER FORD, INC. Ph: *-* St:WY Ctry Cd: USA Reg Cd: NA Repr Date:24-FEB-2005 Doc #:604821C
Cust Comments: WATER IN FUEL LIGHT STAYS ON
Tech Comments: DRAINED, LIGHT WOULDNT RESET, REPLACED WATER I N FUEL MODULE
1FTNW21P04EA88066 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-SEP-2003 12-APR-2004 4B6086 CAN 14 5U90 031801 3C3Z 9F836 BA D50 42 74787
AWS Claim Key: 5175997 Trx Code: E72 Labor Hrs: 1
Dlr Cd-Sub Cd: 09845 - * Name: SWEETWATER FORD, INC. Ph: *-* St:WY Ctry Cd: USA Reg Cd: NA Repr Date:09-MAY-2005 Doc #:605383B
Cust Comments: FUEL PEDAL BROKEN.
Tech Comments: REPLACED ACCELERATOR PEDAL ASSEMBLY
1FTNW21P04EA88066 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-SEP-2003 12-APR-2004 4B6086 CAN 18 2I04 NANANA YC3Z 12B533 AA D03 28 63885
AWS Claim Key: 7157145 Trx Code: E72 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 02928 - * Name: BARBER BROTHERS FORD, INC. Ph: 801-8293447 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:21-SEP-2005 Doc #:52024301
Cust Comments: CUSTOMER STATES HARD TO START WHEN COLD.
Tech Comments: VERIFIED CONCERN. PERFORMED HARD TO START DIAGNOSTICS AND FOUND GLOW PLUG CONTROL MODULE FAULTY. REPLACED MODULE, RECHECKED OPERATION.
1FTNW21P04EA88066 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-SEP-2003 12-APR-2004 4B6086 CAN 18 1H03 030008 4C3Z 9F452 A D13 69 63885
AWS Claim Key: 7157146 Trx Code: E72 Labor Hrs: 3.5
Dlr Cd-Sub Cd: 02928 - * Name: BARBER BROTHERS FORD, INC. Ph: 801-8293447 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:21-SEP-2005 Doc #:52024302
Cust Comments: CUSTOMER STATES AFTER STARTED RAN ROUGH COLD.
Tech Comments: VERIFIED CONCERN. PERFROMED PERFORMANCE DIAGNOSTICS AND FOUND EGR VALVE STICKING. REPLACED EGR VALVE AND RETESTED. VERIFIED REPAIR.
1FTNW21P04EA88066 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-SEP-2003 12-APR-2004 4B6086 CAN 20 2E06 030008 4C3Z 9E527 AA D36 42 64933
AWS Claim Key: 7863709 Trx Code: E72 Labor Hrs: 4
Dlr Cd-Sub Cd: 08254 - * Name: KEN GARFF FORD Ph: 801-7636800 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:25-NOV-2005 Doc #:051171B
Cust Comments: CHECK FOR RUNNING ROUGH
Tech Comments: 64938 FAILED 1 AND 3 INJECTORS. 42. PERFORMED TESTON LINES 1 THRU 11 ON PERFORMANCE SHEETFOR DTC 0269 INCONTINIOUS MEMORY. PERFORMED COLD START UP ENHANCED POWER BALANCE TO TEST FOR MISS ON COLD ENGINE,FOUND 1 AND 3 ARE MISSING R&R RIGHT VALVE COVER TO REPLACE 1 AND 3 INJECTORS. PERFORMED ROADTEST TO VERIFY REPAIRS,OK. PERFORMED QUALTIY REPAIR CHECK.
1FTNW21P04EA88066 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-SEP-2003 12-APR-2004 4B6086 CAN 20 1H05 031004 3C3Z 6766 BA E23 D1 64933
AWS Claim Key: 7863708 Trx Code: E72 Labor Hrs: 5.7
Dlr Cd-Sub Cd: 08254 - * Name: KEN GARFF FORD Ph: 801-7636800 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:25-NOV-2005 Doc #:051171A
Cust Comments: CHECK FOR COOLANT LEAK
Tech Comments: 64933 COOLANT LEAK AT EGR COOLER HOSE. D8. PERFORM COOLING SYSTEM PRESSURE TEST TO INSPECT FOR COOLANT LEAK AT EGR COOLER HOSE.R&R INTAKE MANIFOLD TO REPLACE EGR COOLER HOSE.PERFORM COO LING SYSTEM PRESSURE TEST TO VERIFY REPAIRS,OK. PERFORM ROAD TEST TO VERIFY REPAIRS,OK.PERFORM QUA;ITY REPAIR CHECK.
1FTNW21P04EA88066 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-SEP-2003 12-APR-2004 4B6086 CAN 25 1H03 030008 4C3Z 9F452 A E29 42 78011
AWS Claim Key: 9286140 Trx Code: E72 Labor Hrs: 9.7
Dlr Cd-Sub Cd: 08332 - * Name: COMMUNITY FORD Ph: 435-6371972 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:04-APR-2006 Doc #:6421241
Cust Comments: CHECK ENGINE LIGHT IS ON, IDOLS FAST
Tech Comments: TEST DROVE AND VERIFIED CONCERN, PERF PERF DIAG SHEET RETEIVED P2285 INSPECTED ICP SENSOR FOUND LEAKING OIL INTO CONNECTOR FOUND COOLANT IN RESERVOR AND BLOWING BLACK SMOKE.INSPECTED EGR VALVE FOUND COOLANT SOAKED.REMOVED FAN AND SHROUDREMOVED TURBO AND INTAKE MANAFOLD.INSTALLED NEW EGR COOLER AND NEW EGR VALVE INSTALLED ICP SENSOR AND NEW CONNECTOR REASSEMBLED.TEST DROVE VERIFIED REPAIRS.
1FTNW21P04EA88066 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-SEP-2003 12-APR-2004 4B6086 CAN 25 * * * * * * * 78011
AWS Claim Key: 9128301 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08332 - * Name: COMMUNITY FORD Ph: 435-6371972 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:04-APR-2006 Doc #:6421231
Cust Comments: RECALL 06E17
Tech Comments: PERFOMRED RECALL AS PER BULLETIN
AWS Claim Key: 9128302 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08332 - * Name: COMMUNITY FORD Ph: 435-6371972 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:04-APR-2006 Doc #:6421232
Cust Comments: RECALL 59B01
1FTNW21P04EA88066 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-SEP-2003 12-APR-2004 4B6086 CAN 28 6Y20 000001 * MISC * A99 82 87025
AWS Claim Key: 12316012 Trx Code: PRM Labor Hrs: 0.8
Dlr Cd-Sub Cd: 08332 - * Name: COMMUNITY FORD Ph: 435-6371972 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:26-JUL-2006 Doc #:6443531
Cust Comments: THE TRUCK KEEPS OVERHEATING
Tech Comments: PER REGIONAL REP PAY 45.15
