Hello - New member here
Can someone help me with an Oasis Report on a newly purchased X
My Vin# 1FMSU43P63ED06300
Thanks in advance.
A. Shriner
OASIS RESULT:
1FMSU43P63ED06300
07/30/2006
21:12:15
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 EXCURSION BODY STYLE
LIMITED 4 DR 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/19/2003 BUILD DATE
04/22/2003 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
05/08/2006
DEALER: Sam Galloway Ford, Inc.
WARRANTY CLAIM NUMBER: 888899 ODOMETER: 035751M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6K682BARM TURBO CHG-EXH DRIVE 001 9438A 01 BROKEN/CRACKED
3C3Z 6K854DA PIPE (TURBO INLET LO 001 9438A2
W300013 002 6005F
W300051 004 6005F13
W300006 002 6005F1
3C3Z 6N640AA GASKET TURBO TO MANI 001 6005F1X1
F81Z 8287EA CLAMP ASY-RAD HOSE 001 6005F14
000 6005F20
000 6005F11
000 6005F6
000 6005F8
000 6005F12
000 VERIFY60
000 MTACCESS
6K854 INLET PIPE - CC 01 - 6K682 TURBO - CC69 M-O 35755 VERIFY CONCERN AND DIAG INCLUDED DIAG PERFORMANCE SHEET STEPS 1-5,7,11 CODE P132B(TURBO BOOST CONTROL A PERFORMANCE STORED IN MEMORY)P2263 LOW BOOST KOER.AS PER SSM #1914 1 CLEAR KAM,PERFORM 2 KEY ON-OFF CYCLES,IDLE VEH AT OPERATING TEMP FOR MIN O F 5 MINUTES FOR VGT LEARN PROCESS.CONCERN STIL L PRESENT.REFER TO PC-ED ONLI
05/01/2006
WARRANTY CLAIM NUMBER: 887101 ODOMETER: 035683M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 9B249A HEADER-FUEL FILTER 001 060605C 42 DOES NOT OPERATE PROPERLY
6C3Z 9F759A WIRE ASY FUEL VAPOR 001
BASIC 9B249 CODE 42 M-O 35687 VERIFIED CONCERN DRAINED FUEL WATER SEP RETE ST LIGHT STILL PRESENT. REPROGRAMMED MULTIPLE MODULES AS TSB 06-3-10. RETEST LIGHT STILL PRESENT. REMOVED FUEL WATER MAN VISUAL INSP FOUND EXCESSIVE DEB RIS IN RE AND CORROSION ON WIF PINS. REPLACED MANIFOLD WITH NEW AND INSTALLE D UPDATED HARNESS. RETEST OK. CONCERN CORRECTED.
05/01/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F13
000 6005F1
000 6005F14
000 6005F20
000 6005F11
000 6005F18
000 6005F6
000 6005F8
000 6005F12
000 6005F22
000 12650D80
000 6005F25
000 12650D30
000 VERIFY60
9F452 69 CC M-O 35708 VERIFIED CONCERN, PERFORMED 6.0L DIAG SHEET 1-13, CO DE P0299 KOER ON DEMAND CODE P0299, PERFORMED DCL DISPLAY TEST WATCHING EBP, MGP,EGRVP,ICP FOUND THAT ALL PIDS WERE WITHIN SPEC, PERFORMED VGT PERFORMANC E TEST, R-R VGT SOLENOID AND ACTIVE COMMAND FOUND THAT SOLENOID HAD GOOD MOV EMENT, REMOVE REAR PLUG AT TURBOCHARGER AND CHK MOVEMENT OF UNISON RING
04/05/2006
DEALER: Bay Harbor Ford
WARRANTY CLAIM NUMBER: 073070 ODOMETER: 035336M
LABOR OP
CONDITION CODE
CONDITION DESC
5C7Z 19980AB CONTROL A/C 001 12651D 42 DOES NOT OPERATE PROPERLY
000 12651D2
000 19980A
BCE TEST PIN POINT REPLACE AC CONTROLLER RECHECK OPER OK
03/29/2006
WARRANTY CLAIM NUMBER: 072815 ODOMETER: 035103M
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
PERFORM RECALL 59B01 CUSTOMER ASSURANCE ROAD TEST
03/29/2006
WARRANTY CLAIM NUMBER: 072816 ODOMETER: 035103M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 7153AD GASKET TRANSMISSION 001 7000A 42 DOES NOT OPERATE PROPERLY
XT 6QSP 016 7000AXQ
000 7000AZJ
000 7000A2
000 7000A2ZG
000 7000A4
000 7000A11
000 7000A13
VERIFY HARSH SHIFTS WHEN DRIVING ELECT TRANS DIAG R & R TRANS MOUNT TO FIXTU RE RESEAL TRAN AND VALVEBODY FLUSH CONV AND LINES POST ROAD TST OK
03/29/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 06E17B
PERFORM RECALL 06E17 RECAL CONTROL MODULES
END OF OASIS REPORT FOR 1FMSU43P63ED06300
Standard Claims List For Model Year 2003
1FMSU43P63ED06300 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-APR-2003 19-AUG-2003 124543 USA 3 * * * * * * * 3235
AWS Claim Key: 3405504 Trx Code: 03E04 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:10-NOV-2003 Doc #:04590940
Cust Comments: 03E04 NON CALIFORNIA CERTIFIED VEHICLES WITH CALIFORNIA VEHICLE EMISSIO
Tech Comments: REMOVE LABEL FROM HOOD
1FMSU43P63ED06300 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-APR-2003 19-AUG-2003 124543 USA 6 1H03 030008 3C3Z 9F452 AC D11 42 6470
AWS Claim Key: 4501396 Trx Code: 2 Labor Hrs: 5.2
Dlr Cd-Sub Cd: 04965 - * Name: BAY HARBOR FORD Ph: 941-4755444 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:10-FEB-2004 Doc #:047577A
Cust Comments: OWNER STATES THERE IS A HIGH IDLE WHEN IN DRIVE AND PARK
Tech Comments: DIESEL DIAG WORKSHEET. WDS TEST DRIVE RECORDER 30 MILES 3 TIMES PINPOINT TEST. R&R EGR VALVE, RETET
1FMSU43P63ED06300 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-APR-2003 19-AUG-2003 124543 USA 8 6H08 011108 YC3Z 7827008 AA G07 42 7376
AWS Claim Key: 5069521 Trx Code: 2 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04965 - * Name: BAY HARBOR FORD Ph: 941-4755444 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:17-MAR-2004 Doc #:048810A
Cust Comments: OWNER STATES PASS REAR WINDOW IS MAKING NOISE
Tech Comments: BCE DIAG, PINPOINT TEST, R&R REAR DOOR TRIM PANEL TO REPLACE REGULATOR ASSY, RETEST
1FMSU43P63ED06300 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-APR-2003 19-AUG-2003 124543 USA 8 7W88 000615 * NPF * G29 82 7376
AWS Claim Key: 5069522 Trx Code: 2 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04965 - * Name: BAY HARBOR FORD Ph: 941-4755444 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:17-MAR-2004 Doc #:048810B
Cust Comments: OWNER STATES BACK UP BEEPERS ARE GOING ON WHEN YOU PUT TRUCK IS REV
Tech Comments: EEC TEST, PASS, PID MONITOR AND RECORD, PINPOINT TEST, NO CONCERNS FOUND OASIS REVIEWED, SSM 16672ALL SENSORS OK. NO PROBLEM FOUND OPERATING AS NORMAL
1FMSU43P63ED06300 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-APR-2003 19-AUG-2003 124543 USA 9 2E05 100106 3C3Z 9B249 AB G29 42 9097
AWS Claim Key: 5746169 Trx Code: 2 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 04965 - * Name: BAY HARBOR FORD Ph: 941-4755444 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:28-APR-2004 Doc #:050211C
Cust Comments: WATER IN FUEL LIGHT STAYS ON
Tech Comments: DIESEL DIAG SHEET. PINPOINT TEST, REPLACE SENSOR, SHORTED, RETEST
1FMSU43P63ED06300 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-APR-2003 19-AUG-2003 124543 USA 20 7H12 120403 5C7Z 19980 AB C02 42 20988
AWS Claim Key: 10315760 Trx Code: E83 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04965 - * Name: BAY HARBOR FORD Ph: 941-4755444 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2005 Doc #:060985A
Cust Comments: OWNER STATES THAT THE AC CONTROL HEAD WILL INTERM GOES BLANK AND IS INOPERATIVE USE SOP PARTS
Tech Comments: VERIFIED R&R AC CONTROL HEAD, RETEST
1FMSU43P63ED06300 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-APR-2003 19-AUG-2003 124543 USA 20 2E05 100106 3C3Z 9B249 AB G29 42 20988
AWS Claim Key: 10364476 Trx Code: E84 Labor Hrs: 4.9
Dlr Cd-Sub Cd: 04965 - * Name: BAY HARBOR FORD Ph: 941-4755444 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2005 Doc #:060985B
Cust Comments: OWNER STATES THAT THE FUEL WATER LIGHT IS ON
Tech Comments: PERFORMED ALL 6.0 DIESEL DIAGS. REPROGRAM PCM, REPROGRAM FICM, REPROGRAM TCM, REPLACE FUEL MODULE, CLEAR CODES, ROADTEST
1FMSU43P63ED06300 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-APR-2003 19-AUG-2003 124543 USA 32 * * * * * * * 35103
AWS Claim Key: 13478727 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04965 - * Name: BAY HARBOR FORD Ph: 941-4755444 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:29-MAR-2006 Doc #:072815A
Cust Comments: RECALL 59B01
Tech Comments: PERFORM RECALL 59B01 CUSTOMER ASSURANCE ROAD TEST
AWS Claim Key: 13478728 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04965 - * Name: BAY HARBOR FORD Ph: 941-4755444 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:29-MAR-2006 Doc #:072815B
Cust Comments: RECALL 06E17
Tech Comments: PERFORM RECALL 06E17 RECAL CONTROL MODULES
1FMSU43P63ED06300 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-APR-2003 19-AUG-2003 124543 USA 32 3A11 070101 3C3Z 7153 AD P66 42 35115
AWS Claim Key: 13520759 Trx Code: E84 Labor Hrs: 11.7
Dlr Cd-Sub Cd: 04965 - * Name: BAY HARBOR FORD Ph: 941-4755444 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:29-MAR-2006 Doc #:072816A
Cust Comments: OWNER STATES TRANSMISION BANGS INTO GEAR AND BANGS WHEN PUT INTO REVERSE
Tech Comments: VERIFY HARSH SHIFTS WHEN DRIVING ELECT TRANS DIAG R & R TRANS MOUNT TO FIXTURE RESEAL TRAN AND VALVEBODY FLUSH CONV AND LINES POST ROAD TST OK
1FMSU43P63ED06300 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-APR-2003 19-AUG-2003 124543 USA 33 7H12 120403 5C7Z 19980 AB C20 42 35336
AWS Claim Key: 13531012 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: 04965 - * Name: BAY HARBOR FORD Ph: 941-4755444 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:05-APR-2006 Doc #:073070A
Cust Comments: OWNER STATES AT TIMES A C WILL STOP WORKING AND ALL THE LIGHTS ON DASH GO OFF
Tech Comments: BCE TEST PIN POINT REPLACE AC CONTROLLER RECHECK OPER OK
1FMSU43P63ED06300 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-APR-2003 19-AUG-2003 124543 USA 33 2E05 100106 6C3Z 9B249 A G29 42 35683
AWS Claim Key: 13739594 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 04845 - * Name: SAM GALLOWAY FORD, INC. Ph: 239-9363673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:01-MAY-2006 Doc #:88710101
Cust Comments: CUSTOMER STATES WATER IN FUEL LIGHT COMES ON
Tech Comments: BASIC 9B249 CODE 42 M O 35687 VERIFIED CONCERN DRAINED FUEL WATER SEP RETEST LIGHT STILL PRESENT. REPROGRAMMED MULTIPLE MODULES AS TSB 06 3 10. RETEST LIGHT STILL PRESENT. REMOVED FUEL WATER MAN VISUAL INSP FOUND EXCESSIVE DEBRIS IN RE AND CORROSION ON WIF PINS. REPLACED MANIFOLD WITH NEW AND INSTALLED UPDATED HARNESS. RETEST OK. CONCERN CORRECTED.
1FMSU43P63ED06300 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-APR-2003 19-AUG-2003 124543 USA 33 1H03 030008 4C3Z 9F452 A D42 42 35683
AWS Claim Key: 13739593 Trx Code: S07 Labor Hrs: 5.2
Dlr Cd-Sub Cd: 04845 - * Name: SAM GALLOWAY FORD, INC. Ph: 239-9363673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:01-MAY-2006 Doc #:88710102
Cust Comments: CUSTOMER STATES ENGINE LACKING POWER
Tech Comments: 9F452 69 CC M O 35708 VERIFIED CONCERN, PERFORMED 6.0L DIAG SHEET 1 13, CODE P0299 KOER ON DEMAND CODE P0299, PERFORMED DCL DISPLAY TEST WATCHING EBP,MGP,EGRVP,ICP FOUND THAT ALL PIDS WERE WITHIN SPEC, PERFORMED VGT PERFORMANCE TEST, R R VGT SOLENOID AND ACTIVE COMMAND FOUND THAT SOLENOID HAD GOOD MOVEMENT, REMOVE REAR PLUG AT TURBOCHARGER AND CHK MOVEMENT OF UNISON RING
1FMSU43P63ED06300 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-APR-2003 19-AUG-2003 124543 USA 34 2H01 030008 3C3Z 6K854 DA D42 01 35751
AWS Claim Key: 13864077 Trx Code: E84 Labor Hrs: 7.2
Dlr Cd-Sub Cd: 04845 - * Name: SAM GALLOWAY FORD, INC. Ph: 239-9363673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:08-MAY-2006 Doc #:88889901
Cust Comments: CUSTOMER STATES THAT VEHICLE HAS A LOSS OF POWER, AND DOESN GET OUT OF ITS WAY, PLEASE CHECK AND ADVISE
Tech Comments: 6K854 INLET PIPE CC 01 6K682 TURBO CC69 M O 35755 VERIFY CONCERN AND DIAG INCLUDED DIAG PERFORMANCE SHEET STEPS 1 5,7,11 CODE P132B(TURBO BOOST CONTROL A PERFORMANCE STORED IN MEMORY)P2263 LOW BOOST KOER.AS PER SSM #19141 CLEAR KAM,PERFORM 2 KEY ON OFF CYCLES,IDLE VEH AT OPERATING TEMP FOR MIN OF 5 MINUTES FOR VGT LEARN PROCESS.CONCERN STIL L PRESENT.REFER TO PC ED ONLINE.CONTACT HOTLINE(R
