Considering buying this truck. Could someone please get me the report.
VIN: 1FTNX21P13EB45211
Thanks,
Steve
OASIS RESULT:
1FTNX21P13EB45211
07/30/2006
21:14:43
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
06/02/2003 BUILD DATE
12/02/2002 SALE MILEAGE
00151
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
03/17/2006
DEALER: Brian Hoskins Ford
WARRANTY CLAIM NUMBER: 046062 ODOMETER: 071817M
LABOR OP
CONDITION CODE
CONDITION DESC
000 06E17B
PERFORM CONTROL MODULE RECALIBRATION RECALL
03/17/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
PERFORM RECALL 59B01
END OF OASIS REPORT FOR 1FTNX21P13EB45211
Standard Claims List For Model Year 2003
1FTNX21P13EB45211 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 02-DEC-2002 02-JUN-2003 158470 USA 0 2E01 * * * * * * 151
AWS Claim Key: 1109015 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 09304 - * Name: LUNDGREN MOTORS, INC. Ph: 218-7444821 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2003 Doc #:08362051
Cust Comments: RECALL 03B05 ICP SENSOR REPLACEMENT
Tech Comments: X REPLACED ICP SENSOR
1FTNX21P13EB45211 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 02-DEC-2002 02-JUN-2003 158470 USA 0 2G05 * * * * * * 151
AWS Claim Key: 1109016 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 09304 - * Name: LUNDGREN MOTORS, INC. Ph: 218-7444821 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2003 Doc #:08362052
Cust Comments: RECALL 03B06 COLD OPERATION CALIBRATION UPDATE
Tech Comments: X REPROGRAMMED
1FTNX21P13EB45211 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 02-DEC-2002 02-JUN-2003 158470 USA 1 * * * * * * * 2918
AWS Claim Key: 1599716 Trx Code: 57B98 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 09304 - * Name: LUNDGREN MOTORS, INC. Ph: 218-7444821 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:25-JUN-2003 Doc #:08551410
Cust Comments: CHANGE OIL AND FILTER (6.0L DIESEL)
Tech Comments: X CHANGED OIL AND FILTER
1FTNX21P13EB45211 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 02-DEC-2002 02-JUN-2003 158470 USA 7 5V09 12XXXX F81Z 2A451 BA C20 42 19000
AWS Claim Key: 3665052 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 09304 - * Name: LUNDGREN MOTORS, INC. Ph: 218-7444821 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:05-DEC-2003 Doc #:08919851
Cust Comments: CUSTOMER STATES HEATER ONLY WORKS ON DEFROST ALSO THE 4X4 DOES NOT WORK
Tech Comments: X ELECTRONIC SHIFT FOUR WHEEL DRIVE DIAGNOSIS
1FTNX21P13EB45211 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 02-DEC-2002 02-JUN-2003 158470 USA 9 5V09 12XXXX F81Z 2A451 BA C20 42 25157
AWS Claim Key: 4890105 Trx Code: E90 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 09304 - * Name: LUNDGREN MOTORS, INC. Ph: 218-7444821 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:05-FEB-2004 Doc #:09047551
Cust Comments: CUSTOMER STATES THAT THE HEATER ONLY BLOWS OUT THE DEFROSTER AND THE AUTO 4X4 DOESNT WORK NOW ADVISE
Tech Comments: PART WAS REPLACED ON 12 5 03, 19000 MILES. RO# 89198
1FTNX21P13EB45211 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 02-DEC-2002 02-JUN-2003 158470 USA 14 5A09 0502XX E8TZ 4676 B L88 D8 34125
AWS Claim Key: 7213243 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 08220 - * Name: LINK FORD - RICE LAKE, INC. Ph: 715-2348196 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:14-JUL-2004 Doc #:049048A
Cust Comments: REAR DIFF PINION SEAL LEAKING
Tech Comments: LK OVER FND PINION SEAL AND CVR GSKT LKNG RPLCD PINION SEAL RESEAL REAR COVER ON REAR DIFF RD TEST OK
1FTNX21P13EB45211 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 02-DEC-2002 02-JUN-2003 158470 USA 14 2E02 030408 3C3Z 9N693 HA L65 D8 34125
AWS Claim Key: 7213244 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 08220 - * Name: LINK FORD - RICE LAKE, INC. Ph: 715-2348196 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:14-JUL-2004 Doc #:049048B
Cust Comments: ENGINE LEAKING OIL
Tech Comments: LK OVER FND CMP SENS LKNG RMV AND RPLCD O RINGSCLND OFF MOTOR OK
1FTNX21P13EB45211 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 02-DEC-2002 02-JUN-2003 158470 USA 14 1H03 030008 3C3Z 9J460 AA D42 42 34125
AWS Claim Key: 7213245 Trx Code: S07 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 08220 - * Name: LINK FORD - RICE LAKE, INC. Ph: 715-2348196 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:14-JUL-2004 Doc #:049048C
Cust Comments: WHILE TEST DRIVING WITH CUST, ENGINE SMOKES AND CHUGS AND LACKS POWER
Tech Comments: LK OVER RD TESTED PERF UPDATE TO PCM TCM PICM PERFEEC TEST NO CODES LK AT DCL DISPLAY FND EBP MAP BARO ALL READING DIFF RPLCD EBP RD TEST GOOD CLND OUT HOSE TO MAP AND EXH TUBE TO EBP RETEST OK
1FTNX21P13EB45211 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 02-DEC-2002 02-JUN-2003 158470 USA 16 * * * * * * * 37767
AWS Claim Key: 7846275 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08220 - * Name: LINK FORD - RICE LAKE, INC. Ph: 715-2348196 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:16-SEP-2004 Doc #:050909E
Cust Comments: RECALL #04S15
1FTNX21P13EB45211 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 02-DEC-2002 02-JUN-2003 158470 USA 19 2G01 * * * * * * 43552
AWS Claim Key: 8984835 Trx Code: 03L12 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00627 - * Name: BREON-CONFAIR FORD Ph: 570-3982330 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:20-DEC-2004 Doc #:21347304
Cust Comments: RECALL, 03L12 ENGINE EMISSION CONTROL INFORMATION.
Tech Comments: 1 COMPLETED RECALL 03L12B
1FTNX21P13EB45211 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 02-DEC-2002 02-JUN-2003 158470 USA 34 * * * * * * * 71817
AWS Claim Key: 13379878 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01239 - * Name: BRIAN HOSKINS FORD Ph: 610-3844242 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:17-MAR-2006 Doc #:046062A
Cust Comments: PERFORM RECALL 06E17
Tech Comments: PERFORM CONTROL MODULE RECALIBRATION RECALL
AWS Claim Key: 13394684 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01239 - * Name: BRIAN HOSKINS FORD Ph: 610-3844242 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:17-MAR-2006 Doc #:046062D
Cust Comments: PERFORM RECALL 59B01
Tech Comments: PERFORM RECALL 59B01
OASIS RESULT:
1FTNX21P13EB45211
07/30/2006
21:14:43
VEHICLE INFORMATION
VEHICLE DESCRIPTION
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
WARRANTY START DATE
00151
ARN MESSAGES
WARNING MESSAGES
EXTENDED COVERAGES
REPAIR HISTORY
03/17/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 06E17B
03/17/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
