OASIS RESULT:
1FMNU44PX4EA00973
05/04/2007
21:33:54
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 EXCURSION BODY STYLE
4 DR EDDIE BAUER 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
3L11ON0A
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
06/09/2004 BUILD DATE
07/16/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0701 - USA 2006 NEW 84/100,000 PREMIUMCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: WILLIAM RENEGAR
OPTIONS:
EXPIRATION DATE: 06/09/2011
DISTANCE: 100,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 03669
ESP CONTRACT START DATE: 06/09/2004
WARRANTY REPAIR HISTORY
04/02/2007
DEALER: Ford Country
WARRANTY CLAIM NUMBER: 079564 ODOMETER: 052174M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6005F 41 STICKS/BINDS/GRABS
3L3Z 12B579AB SENSOR EEC MASS AIR 001 6005F13
3C3Z 6K854DA PIPE (TURBO INLET LO 001 6005F1
3C3Z 9T514AD KIT-HDW TRBCH MTNG 001 6005F14
3C3Z 6N640AA GASKET TURBO TO MANI 001 6005F20
W300006 002 6005F18
000 6005F12
000 12650D30
000 12650D25
000 9438A2
000 6005F6
000 9438A
VISUAL OK, FUEL OK, OIL OK, KOEO PASS, CMDTC P0401-404, INJ TEST OK, INT RES T OK, EGR FAILED, VALVE WAS JUST CLEANED REPLACED VALVE AND RETEST AFTER RD TEST FOUND P0401, PINPOINT TEST BOOST TEST, OK, SMOKE TEST INTAKLE SYSTEM OK , SMOKE EXH SYS FOUND YPIPE TO HAVE A HAIRLINE CRACK IN IT, REMOVE TURBO REP LACE YPIPE AND RETEST OK, RELEARN VGT SET P006A, FOUND MAF SENSOR, OUT OF SP
03/19/2007
WARRANTY CLAIM NUMBER: 077771 ODOMETER: 051445M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6K682CBRM TURBO CHG-EXH DRIVE 001 062302A 42 DOES NOT OPERATE PROPERLY
3C3Z 9P455AB SE E/G/R VLV 001 061906A
PM 2 MOTORCRAFT BATTERY 001
6C3Z 5A231AA CLAMP-MUFFLER 001
6F089 ACTUATOR ASSY 000
CHECK FOR DTCS FOUND P0404 PERFORM EGR CLEANING TSB CLEANED EGR VLAVEPER 06- 19-06 REETSDT FOUND TO RESET P0404, AND BLOWING EGR VALVE OFF OF SEAT, CLEAN TURBO PER TSB 06-23-02 AND RETESDT FOUND VEH TO RETEST OK
02/24/2007
WARRANTY CLAIM NUMBER: 075041 ODOMETER: 050743M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6K775AA COOLER ASSY 001 VERIFY60 D8 FAILED GASKET/SEAL
000 6775A
000 6005F
000 6005F13
000 6005F1
000 6005F2
000 6005F14
000 6005F20
000 6005F11
000 6005F18
000 6005F6
000 6005F12
000 MTSMOKE
VERIFY60, VISUAL OK, OIL OK, FUEL OK, KOEO PASS, CMDTC PASS, INT REST O K, EGR PASS, EXH REST OK, FUEL PRESS OK, KOER PASS,BOOST TEST FAILED, SMOKE TEST CAC SYSTEM FOUND SEAMS OF INTERCOOLER LEAKING REPLACED INTERCOO LER AND RETEST OK, BOOSTS 24 PSI
02/24/2007
LABOR OP
CONDITION CODE
CONDITION DESC
E8TZ 4676B SEAL ASY-DRIVE PINIO 001 4676AA D8 FAILED GASKET/SEAL
XY 75W140QL 001 MTSTEAM
LEAKING RA ISE AND INSPECT.REPLACE LEAKING REAR PINION SEAL.STEAM CLEAN GEA
09/18/2006
WARRANTY CLAIM NUMBER: 055698 ODOMETER: 040041M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9E527AE NOZZLE ASY-FUEL INJE 002 VERIFY60 42 DOES NOT OPERATE PROPERLY
000 9527AL
000 6005F
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F20
000 6005F22
000 6005F25
000 6005F33
000 6007A28
000 12650D47
000 12650D45
000 12650D81
VERIFY 60,VIS OK,CLEAN FUEL OK,OIL LEV OK,KOEO PASS,CONT DTCS P0278,KOEO INJ EC TEST PASS,INTAKE RESTRIC OK,EGR POSS OK,EXHAUST RESTRIC OK,FUEL PUMP PRES S OK,KOER PASS,LOW IDLE STAB OK,INJEC PRESS REG OK,BOOST PRESS OK,VGT TEST P ***,RELATIVE COMPRESSION TEST COULD NOT BE COMPLETED DUE TO CYLINDERS HYDROL OCKING, REMOVE ALL GLOW PLUGS FOUND CYL 6-8 SHOOTING OUT FUEL, COMPRESS TEST
09/18/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 06E17B
06E17 REFLKASH PCM PER 06E17
09/18/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
59B01 RD TEST OK
END OF OASIS REPORT FOR 1FMNU44PX4EA00973
