1FTNW21P54ED49627 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2004 02-SEP-2004 152571 USA 9 3A03 * * * * * * 34574
AWS Claim Key: 5493143 Trx Code: 04B24 Labor Hrs: 11.6
Dlr Cd-Sub Cd: 09936 - * Name: MAC HAIK FORD LINCOLN MERCURY Ph: 361-5761221 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:26-MAY-2005 Doc #:183503A
Cust Comments: 04S24 TRANS REVERSE PLANET REPLCT.
Tech Comments: 34585 04S24 11.4 WARRANTY R&I TORQUE SHIFT TRANS & TRANSFER CASE 4+4 INSTALLED REVERSE PLANITARY THAT WAS COMMING APART R&R HUB OR GEAR PLANITARY GOES IN R&R SOLINOID ON VALVE BODY R&R AUG.COOLER R&R FRAME FILTER INSTALLED INLINE FILTER FLUSHED COOLER LINES TEST DROVE HAD TRUBLE SHIFTING WENT TO LINE B
1FTNW21P54ED49627 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2004 02-SEP-2004 152571 USA 9 3A15 070100 5C3Z 7G391 BA P67 42 34574
AWS Claim Key: 5425188 Trx Code: S07 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 09936 - * Name: MAC HAIK FORD LINCOLN MERCURY Ph: 361-5761221 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:26-MAY-2005 Doc #:183503B
Cust Comments: CK FOR WHEN IN 3RD GEAR , ACTS LIKE NOT WANTING TO MOVE, BINDING UP
Tech Comments: 34585 42 WARRANTY TEST DROVE AFTER DOING LINE AND STILL HAD PROB LUM DID NGS NO CODES R&I TRANS PAN TO R&R SOLINOID VALVE BODY TEST DROVE ALL IN SPEC
1FTNW21P54ED49627 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2004 02-SEP-2004 152571 USA 12 * * * * * * * 40570
AWS Claim Key: 6641986 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09936 - * Name: MAC HAIK FORD LINCOLN MERCURY Ph: 361-5761221 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2005 Doc #:187536A
Cust Comments: 05S34 FUEL INJECTOR WIRING HARNESS
Tech Comments: 40570 RECALL WA INSPECT FICM HARNESS INSTALLED FICM HARNESS KIT REPLACED ICP CONNECTOR
1FTNW21P54ED49627 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2004 02-SEP-2004 152571 USA 12 2G04 031401 * 12A650 * D21 42 40570
AWS Claim Key: 6665838 Trx Code: S07 Labor Hrs: 4
Dlr Cd-Sub Cd: 09936 - * Name: MAC HAIK FORD LINCOLN MERCURY Ph: 361-5761221 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2005 Doc #:187536B
Cust Comments: C FOR WHEN AT 30 40 MPH IS SURGING AND IS ONLY GETTING 9 MPG , WAS AT 19 MPG SLUGGISH , NO POWER
Tech Comments: 40570 42 WA PERFORMED DIESEL DIAGNOSTICS KOEC P1111 KOEO P1111 KOER EGR TEST FUEL PRESSURE TEST ICP TEST IPR TEST BOOST PRESSURE TEST REPROGRAMED PCM AND RETESTED AND TEST DROVE
AWS Claim Key: 6641987 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09936 - * Name: MAC HAIK FORD LINCOLN MERCURY Ph: 361-5761221 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2005 Doc #:187536F
Cust Comments: 59B01 CUSTOMER DRIVE
Tech Comments: 40570 RECALL WA TEST DROVE AS PER RECALL
1FTNW21P54ED49627 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2004 02-SEP-2004 152571 USA 33 * * * * * * * 88661
AWS Claim Key: 11508671 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 04473 - * Name: CHAMPION FORD GULF FREEWAY Ph: 713-3714000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-APR-2007 Doc #:228592B
Cust Comments: 05E15 EXHAUST PRESSURE SENSOR REPLACEMENT ENGINE CONTROL MODULE RECALIBRATION
Tech Comments: 88661 REPLACED EP SENSOR AND RECALIBRATED ENGINE CONTROL MODULE AS PER RECALL
