sorry about that, i thought i caught all of them, here ya go...
1FTNW21P84EC75703 T/F7 F T/BC T/BD T/E A1 T/VG T/YB 12-MAR-2004 30-AUG-2004 144472 USA 10 4A02 080103 5C3Z 7563 A P24 63 17285
AWS Claim Key: 5945812 Trx Code: E84 Labor Hrs: 3.9
Dlr Cd-Sub Cd: 07628 - * Name: MURRAY'S FORD, INC. Ph: 814-3716600 St
A Ctry Cd: USA Reg Cd: NA Repr Date:22-JUN-2005 Doc #:07623751
Cust Comments: CHECK CLUTCH SLIPS AND PEDAL SEEMS SPONGY
Tech Comments: CLTCH SLIPS PEDL FEELS SFT CKD CLTCH OPERATION PDL PRESS SEEMS SFT REM TRANS AND TRNSFR CASE REM CLTCH PRSS PLTE AND DISC PRESS PLTE TOO WEAK AND WLD NOT PROVIDE SUFFICIENT FRCE TO PROPERLY ENGAGE CLTCH CSING CLTCH TO SLIP REPL CLTCH PLTE AND PRESS PLTE INSP FLYWHL OK INSP CLTCH HYDRAULIC SYST OK REASSEMBLED TSTD
1FTNW21P84EC75703 T/F7 F T/BC T/BD T/E A1 T/VG T/YB 12-MAR-2004 30-AUG-2004 144472 USA 10 2H01 * * * * * * 17285
AWS Claim Key: 5738351 Trx Code: 05B29 Labor Hrs: 0.4
A Ctry Cd: USA Reg Cd: NA Repr Date:23-JUN-2005 Doc #:07627551
Cust Comments: 05B29 CHARGE AIR COOLER DUCT
Tech Comments: RECALL 05B29 COMPLETED RECALL 05B29 REPLACED AIR INLET TUBE AS PER RECALL
1FTNW21P84EC75703 T/F7 F T/BC T/BD T/E A1 T/VG T/YB 12-MAR-2004 30-AUG-2004 144472 USA 10 * * * * * * * 17285
AWS Claim Key: 5738352 Trx Code: 05S34 Labor Hrs: 1.1
A Ctry Cd: USA Reg Cd: NA Repr Date:23-JUN-2005 Doc #:07627552
Cust Comments: 05S34 FUEL INJECTOR CONTROL MODULE WIRING
Tech Comments: RECALL 05S34 COMPLETED RECALL 05S34 INSPECT WIRING NO DAMAGE,INSTALLED SHIELDS
1FTNW21P84EC75703 T/F7 F T/BC T/BD T/E A1 T/VG T/YB 12-MAR-2004 30-AUG-2004 144472 USA 13 * * * * * * * 22489
AWS Claim Key: 7198408 Trx Code: 59B01 Labor Hrs: 0.3
A Ctry Cd: USA Reg Cd: NA Repr Date:22-SEP-2005 Doc #:08010352
Cust Comments: 59B01 TEST DRIVE
Tech Comments: PERFORMD TST DRV NO ISSUES FND
AWS Claim Key: 7198407 Trx Code: 05E15 Labor Hrs: 1.3
A Ctry Cd: USA Reg Cd: NA Repr Date:22-SEP-2005 Doc #:08010351
Cust Comments: 05E15 EX PRESSURE SENSOR
Tech Comments: R&R INTKE AIR BX R&R CAC TBE REM EBP SNSR CANNOT READ PRT NO REPLCD SNSR CONN REFLSHED TO LTST CALIBRATION
1FTNW21P84EC75703 T/F7 F T/BC T/BD T/E A1 T/VG T/YB 12-MAR-2004 30-AUG-2004 144472 USA 21 7W15 011902 3F2Z 15K859 BA G29 42 35862
AWS Claim Key: 9548354 Trx Code: E83 Labor Hrs: 0.7
A Ctry Cd: USA Reg Cd: NA Repr Date:15-MAY-2006 Doc #:08933352
Cust Comments: CHECK BACK UP ALARM WARNING LIGHT SHUTS OFF ON ITS OWN
Tech Comments: PRK AID SYST SLF TST CDE C1704 RT OUTR SNSR CKT FLT PERF PPT B1 B6 FLTY PARK AID SNSR REPL RT OUTR PRK AID SNSR RETST
1FTNW21P84EC75703 T/F7 F T/BC T/BD T/E A1 T/VG T/YB 12-MAR-2004 30-AUG-2004 144472 USA 26 1H03 030804 4C3Z 9P456 AF L87 D8 46657
AWS Claim Key: 10679023 Trx Code: S07 Labor Hrs: 5.2
A Ctry Cd: USA Reg Cd: NA Repr Date:28-SEP-2006 Doc #:00353203
Cust Comments: INSUFFICIENT FLUID, COOLANT LOSS
Tech Comments: TESTED ENGINE COOLING SYSTEM FOR LEAKS, PART OF THE LEAK IS FROM THE COOLING SYSTEM PRESSURE CAP LEAKING. PART OF THE LEAK IS FROM THE EGR COOLER LEAKING COOLANT INTO THE EXHAUST SYSTEM THROUGH THE EGR CIRCUIT INTERNAL TO THE COOLER REPLACED THE EGR COOLER, FILLED WITH COOLANT AND TESTED, OK
1FTNW21P84EC75703 T/F7 F T/BC T/BD T/E A1 T/VG T/YB 12-MAR-2004 30-AUG-2004 144472 USA 26 2H02 030407 5C3Z 6F089 BA D42 42 46657
AWS Claim Key: 10679022 Trx Code: E72 Labor Hrs: 6.4
A Ctry Cd: USA Reg Cd: NA Repr Date:28-SEP-2006 Doc #:00353202
Cust Comments: ENGINE POOR PERFORMANCE LACKS POWER, 5 50 DIESEL WAR
Tech Comments: REMOVED AND CLEANED AND THE TURBOCHARGER. SEE REMARKS SECTION.
1FTNW21P84EC75703 T/F7 F T/BC T/BD T/E A1 T/VG T/YB 12-MAR-2004 30-AUG-2004 144472 USA 26 1H03 030008 4C3Z 9F452 A D42 55 46657
AWS Claim Key: 10712229 Trx Code: S07 Labor Hrs: 0
A Ctry Cd: USA Reg Cd: NA Repr Date:28-SEP-2006 Doc #:00353204
Tech Comments: PRFORM TSB 06 19 06 EGR CLEANING DID NOT RESOLVE CONCERN REPLACE EGR VALVE SEE REMARKS
1FTNW21P84EC75703 T/F7 F T/BC T/BD T/E A1 T/VG T/YB 12-MAR-2004 30-AUG-2004 144472 USA 30 1A02 030102 * 6051 * L87 42 53794
AWS Claim Key: 11274316 Trx Code: E72 Labor Hrs: 16.3
A Ctry Cd: USA Reg Cd: NA Repr Date:13-FEB-2007 Doc #:00817502
Cust Comments: CUST STATES THE VEHICLE IS LOSING COOLANT OUT THE OVERFLOW
Tech Comments: CHECKED COOLING SYSTEM OPERATION, NO OBVIOUS CONCERNS FOLLOWED TSB 06 21 2 FOR COOLANT OVERFLOW. NO ENGINE OIL PRESENT IN COOLANT, EEC TEST KOEO P1111 KOER P1111 KOEC P1111, MONITORED EOT AND ECT USING IDS DIAGNOSTIC TOOL, NO CONCERNS FOUND. TESTED COOLANT PRESSURE CAP OPERATION, TEST PASSED. PERFORMED EGR COOLER TEST AS PER TSB, NO CONCERN FOUND WITH THE EGR COOLER. NO EXTERNAL COOLANT
1FTNW21P84EC75703 T/F7 F T/BC T/BD T/E A1 T/VG T/YB 12-MAR-2004 30-AUG-2004 144472 USA 39 1H03 030008 4C3Z 9F452 A D13 55 60630
AWS Claim Key: 12171080 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 00733 - * Name: WARREN MIDTOWN MOTORS, INC. Ph: 814-7235400 St
A Ctry Cd: USA Reg Cd: NA Repr Date:18-OCT-2007 Doc #:19689001
Cust Comments: CUSTOMER STATES RUNS ROUGH AT TIME, ALSO AT TIMES WILL BUILD MORE BOOST THAN NORMAL CHECK ENGINE LIGHT IS ON
Tech Comments: TESTED CODES P0299,P0401,P0403,P0404 TESTED AND REPALCED EGR VALVE AS PER TSB 07 21 09
