Ford OEM Parts Supplier
OASIS RESULT:
1FTSW21P26ED31303
USA
EN
05/03/2010
08:55:27
FCXWS446
© Copyright 2002-2010 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
PAINT COLOR
CHARCOAL BEIGE W/B #2 RADIO
AM/FM STRO/CD CHANGER/CLK GROSS VEHICLE WEIGHT
10,000 LB. GVW
AXLE RATIO
3.73 FINAL DRIVE RATIO WHEEL SIZE
7.5 X 17 FORGED POL ALUM WHL FRONT TIRE
LT265/70/R17E A/T OWL
WARNING MESSAGES
ARN MESSAGES
INSTALL 6A642-CA KIT WHEN REPLACING EGR COOLER UNDER 09-08-03
TO ENSURE OPTIMUM COOLING SYSTEM PREFORMANCE, REFER TO 09-08-05
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/14/2006 BUILD DATE
03/15/2006 SALE MILEAGE
New Vehicle Base Warranty
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
04/19/2010
DEALER: Gene Messer Ford
WARRANTY CLAIM NUMBER: 461138 ODOMETER: 095528M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527BRM NOZZLE ASY-FUEL INJE 003 6005F 42 DOES NOT OPERATE PROPERLY
W302725 001 6005F1
000 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F13
000 6005F18A
000 6005F21
000 6005F22
000 6005F23
000 6005F43
000 6005F45
000 6005F47
000 9527AT
000 6005F1X1
VERIFY CONCERN. PERFORM QUICK TEST. KOEO , KOER TEST P0266. CMDTC P0266. DI ESEL ENGINE PERFORMANCE DIAG, PERFORM PPT P FOR P0266. P9-CYLINDERS 1,2 AND 7 DROPPING OUT. P10-PERFORM RELATIVE COMPRESSION-PASS, P11- PERFORM FUEL P SI TEST-51 PSI, P12-FUEAL AERATION TEST-PASS, P13-PERFORM COMBUSTION BUBBL E TEST PASS, P14-CHECK SUPPLY VOLTAGE TO INJ-48V, P15 -PERFORM LOW IDLE
| On-line 1878
Standard Claims List For Model Year 2006
1FTSW21P26ED31303 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-MAR-2006 14-APR-2006 152572 USA 1 6R01 012001 6C3Z 78611B09 AAB S25 01 128
AWS Claim Key: 824940 Trx Code: 1 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 02561 - * Name: SEWELL FORD, INC. Ph: 432-3320421 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:17-APR-2006 Doc #:10756801
Cust Comments: LF SEATBELT WONT RETRACT
Tech Comments: VERIFIED DRIVERS FRONT SEAT BELT WONT RETRACT REPLACED SEAT BELT RETRACTOR SPRING CAME APART
1FTSW21P26ED31303 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-MAR-2006 14-APR-2006 152572 USA 6 1F06 030304 6C3Z 8A080 B E23 01 9877
AWS Claim Key: 1732598 Trx Code: 1 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 02561 - * Name: SEWELL FORD, INC. Ph: 432-3320421 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2006 Doc #:11874701
Cust Comments: TEMP GAGE READING HOT OVERHEATING,NO EXTERNAL LEAKS
Tech Comments: VERIFIED TEMP GUAGE READING HOT OVERHEATING,LOW COOLANT PRESSURE TESTED COOLING SYSTEM DEGAS BOTTLE HAD A CRACK INIT REPLACED DEGAS BOTTLE STEAMED OFF TEST DROVE OK
1FTSW21P26ED31303 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-MAR-2006 14-APR-2006 152572 USA 31 1B03 030204 3C3Z 6A642 AA L87 42 68474
AWS Claim Key: 7405670 Trx Code: E72 Labor Hrs: 8.8
Dlr Cd-Sub Cd: 20447 - * Name: KERMIT MOTOR CO, INC. Ph: 432-5862551 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:27-OCT-2008 Doc #:01713201
Cust Comments: DIESEL LOOSING COOLANT HAVING TO ADD COOLANT COOLANT LOOKS THIC
Tech Comments: CHECKED FOR OIL IN COOLANT OIL IS PRESENT PERFORMED TSB081103 PRESSURE TESTED COOLANT SYSTEM REMOVED AND SUBMERGED EGR COOLER IN WATER FOUND IT LEAKING CHECKED OIL COOLER WITH RADKIT PLUS AND IT INDICATES VACUUM PRESENT ASKED FOR PRIOR APPROVAL AND REPLACED OIL COOLER AND EGR COOLER FLUSHED SYSTEM AFTER REPAIR
1FTSW21P26ED31303 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-MAR-2006 14-APR-2006 152572 USA 49 2E03 030402 4C3Z 9E527 BRM D42 42 95528
AWS Claim Key: 9116309 Trx Code: S07 Labor Hrs: 7.2
Dlr Cd-Sub Cd: 03566 - * Name: GENE MESSER FORD Ph: 806-7932727 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2010 Doc #:461138A
Cust Comments: CUST STATES IDLES ROUGH UNTIL WARMS UP, IDLES FINE, BUT WHEN DRIVING OVER 2 MILES, WILL OVERHEART & HAS TO SLOW DOWN D42
Tech Comments: VERIFY CONCERN. PERFORM QUICK TEST. KOEO , KOER TEST P0266. CMDTC P0266. DIESEL ENGINE PERFORMANCE DIAG, PERFORM PPT P FOR P0266. P9 CYLINDERS 1,2 AND 7 DROPPING OUT. P10 PERFORM RELATIVE COMPRESSION PASS, P11 PERFORM FUEL PSI TEST 51 PSI, P12 FUEAL AERATION TEST PASS, P13 PERFORM COMBUSTION BUBBLE TEST PASS, P14 CHECK SUPPLY VOLTAGE TO INJ 48V, P15 PERFORM LOW IDLE
