Hi,
OASIS RESULT:
1FMNU43SXYEA29711
12/13/2006
08:11:01
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2000 EXCURSION BODY STYLE
LIMITED 4 DR 4X4 ENGINE
6.8L EFI SOHC
TRANSMISSION
4R100 (E4OD) 4SP O/D AXLE CODE
ENGINE CALIBRATION
0L118N0A
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/14/1999 BUILD DATE
08/14/1999 SALE MILEAGE
00029
05S28
SPEED CONTROL SYSTEM MODIFICATION
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
1FMNU43SXYEA29711 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 14-AUG-1999 14-SEP-1999 4B1289 CAN 9 5R02 110601 F81Z 3600 BAG N57 42 8798
AWS Claim Key: 2699271 Trx Code: 2 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 09897 - * Name: TUBBS BROTHERS, INC. Ph: 810-6482848 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:02-JUN-2000 Doc #:034056A
Cust Comments: STEERING WHEEL LEATHER WRAP HAS BUBBLES
Tech Comments: R&R AND REPLACE STEERING WHEEL
1FMNU43SXYEA29711 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 14-AUG-1999 14-SEP-1999 4B1289 CAN 9 6Q06 011902 * 17D826 * B69 42 8798
AWS Claim Key: 2319423 Trx Code: 2 Labor Hrs: 2
Dlr Cd-Sub Cd: 09897 - * Name: TUBBS BROTHERS, INC. Ph: 810-6482848 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:02-JUN-2000 Doc #:034063A
Cust Comments: TRAILER HITCH PLUG LOOSE NEEDS NEW BOLT
Tech Comments: R&R FUEL TANK FOR ACCESS TO TRAILER HITCH R&R TRAILER HITCH CUT OFF BROKEN BOLT REINSTALL TRAILER HITCH BOLT REASSEMBLE
1FMNU43SXYEA29711 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 14-AUG-1999 14-SEP-1999 4B1289 CAN 9 5V01 060301 * 1102 * N27 13 8798
AWS Claim Key: 2230554 Trx Code: 2 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 09897 - * Name: TUBBS BROTHERS, INC. Ph: 810-6482848 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:02-JUN-2000 Doc #:034063B
Cust Comments: BRAKES SHUTTER BAD NEED ROTORS TURNED
Tech Comments: VERIFY CONCERN R&R FRONT BRAKE PADS MACHINE FRONT ROTORS ON VEHICLE REASSEMBLE RETEST OK
1FMNU43SXYEA29711 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 14-AUG-1999 14-SEP-1999 4B1289 CAN 17 7F03 011605 1C7Z 17508 AA W06 42 20172
AWS Claim Key: 6433686 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 09723 - * Name: REESE FORD Ph: 989-8684114 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:11-JAN-2001 Doc #:0841751
Cust Comments: REAR WIPER MOTOR INOP AT TIMES WIPER INTERMITTENT NO OPERATION
Tech Comments: REPLACED WIPER MOTOR
1FMNU43SXYEA29711 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 14-AUG-1999 14-SEP-1999 4B1289 CAN 19 5V01 050301 F81Z 1125 DA N27 13 23627
AWS Claim Key: 7717835 Trx Code: E84 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 09723 - * Name: REESE FORD Ph: 989-8684114 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:03-APR-2001 Doc #:0158301
Cust Comments: BRAKES PULSATE
Tech Comments: ROTORS OUT OF ROUND REPLACE FRONT AND REAR ROTORS
1FMNU43SXYEA29711 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 14-AUG-1999 14-SEP-1999 4B1289 CAN 19 4C03 090201 * 5E212 * N50 33 23627
AWS Claim Key: 7785443 Trx Code: S07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 09723 - * Name: REESE FORD Ph: 989-8684114 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:03-APR-2001 Doc #:0158303
Cust Comments: RATTLE NOISE WHEN BACKING UP
Tech Comments: CONVERTER SHIELD LOOSE, TIGHTEN CONVERTER SHIELD
1FMNU43SXYEA29711 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 14-AUG-1999 14-SEP-1999 4B1289 CAN 29 5G04 040105 * 5K483 * N50 33 35900
AWS Claim Key: 13958673 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 09723 - * Name: REESE FORD Ph: 989-8684114 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:11-JAN-2002 Doc #:0229821
Cust Comments: CLUNK NOISE IN FRONT END WHEN TURNING
Tech Comments: SWAY BAR LINKS INPROPER TORQUE, RETORQUE SWAY BAR LINKS PER SERVICE MESSAGE
1FMNU43SXYEA29711 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 14-AUG-1999 14-SEP-1999 4B1289 CAN 33 5G02 040103 2C3Z 3050 BA H21 33 35941
AWS Claim Key: 16416757 Trx Code: E84 Labor Hrs: 6.9
Dlr Cd-Sub Cd: 09897 - * Name: TUBBS BROTHERS, INC. Ph: 810-6482848 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:29-MAY-2002 Doc #:0544541
Cust Comments: CHECK STEERING, SEEMS TO WANDER
Tech Comments: REPLACED UPPER AND LOWER BALL JOINTS DUE TO BEING LOOSE, TESTED OUT GOOD ALIGN FRONT END SET AND CORRECT TOE MTIME REQUESTED FOR NO LOPS TO REPLACE BALL JOINTS
1FMNU43SXYEA29711 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 14-AUG-1999 14-SEP-1999 4B1289 CAN 33 5R05 110402 F2UZ 7A214 A P09 33 35941
AWS Claim Key: 16436388 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 09897 - * Name: TUBBS BROTHERS, INC. Ph: 810-6482848 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:29-MAY-2002 Doc #:0544546
Cust Comments: O/D BUTTON ON HANDLE HAS RING MISSING AROUND BUTTON
Tech Comments: INSTALLED O/D RING ON SHIFTER LOOSE AND FELL OFF LOST RING
1FMNU43SXYEA29711 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 14-AUG-1999 14-SEP-1999 4B1289 CAN 57 5K06 * * * * * * 67564
AWS Claim Key: 22741489 Trx Code: 04B14 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 09897 - * Name: TUBBS BROTHERS, INC. Ph: 810-6482848 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:29-APR-2004 Doc #:0747101
Cust Comments: INSPECT TIRES PER RECALL INSTRUCTIONS
Tech Comments: REPLACE 5 TIRES PER NOTIFICATION INSTRUCTIONS #04B14
Thanks,
Vivian
