2nd Gen Guru
Diagnostic Error Codes
For 2000-2002 Year Trucks
(For Owners Without Code Readers)
Insert your ignition key. Turn it to the OFF position. Now turn it ON, OFF, ON, OFF, ON in less than 5 seconds. Leave it in the on position.
In the odometer display it should start to display codes. It starts with P PCU errors. This is to notify you that the error codes are coming. They would show up as Pnnnn. All error codes are listed in 4 digits. Write down all Pnnnn error codes that are displayed.
Short video of how it looks...
http://www.youtube.com/watch?v=7XQJmaIF9Do
This is notify that P PCU error code list is done. Now we display P ECU errors. This is to notify you that the error codes are coming. They would show up as Pnnnn. All error codes are listed in 4 digits. Write down all Pnnnn error codes that are displayed. This is notify that P ECU error code list is done.
Now turn your key off.
For 1998-2002 Year Trucks
(For All Code Readers)
The PCM and ECM monitor many different circuits in the powertrain system. If the ECM or PCM senses a problem with a monitored circuit often enough to indicate an actual problem, it stores a Diagnostic Trouble Code (DTC) in the ECM’s or PCM’s memory. With certain DTC’s, if the problem is repaired or ceases to exist, the ECM or PCM cancels the code after 40 warm-up cycles. Certain other DTC’s may be cancelled after 1 or 2 good “trips”. Refer to Trip Definition. DTC’s that affect vehicle emissions illuminate the Malfunction Indicator Lamp (MIL). The MIL is displayed as an engine icon (graphic) on the instrument panel. Refer to Malfunction Indicator Lamp.
Certain DTC’s will set a “P1693 companion DTC” in the opposite control module. This means that after repair, the DTC must be erased from both modules. Certain criteria must be met before the ECM or PCM will store a DTC in memory. The criteria may be a specific range of engine RPM, throttle opening, engine temperature or input voltage. The ECM or PCM might not store a DTC for a monitored circuit even though a malfunction has occurred. This may happen because one of the DTC criteria for the circuit has not been met. For example, assume the DTC criteria requires the ECM to monitor the circuit only when the engine operates between 750 and 2000 RPM. Suppose the sensor’s output circuit shorts to ground when engine operates above 2400 RPM (resulting in 0 volt input to the ECM). Because the condition happens at an engine speed above the maximum threshold (2000 rpm, the ECM will not store a DTC. There are several operating conditions for which the ECM and PCM monitors and sets DTC’s. Refer to Monitored Systems, Components, and Non-Monitored Circuits.
Technicians must retrieve stored DTC’s by connecting the DRB scan tool (or an equivalent scan tool) to the 16–way data link connector (Fig. 3).
Refer to the Diagnostic Trouble Code chart (list). Remember that DTC’s are the results of a system or circuit failure, but do not directly identify the failed component or components. Various diagnostic procedures may actually cause a diagnostic monitor to set a DTC. For instance, disconnecting a relay or removing an electrical connector while the engine is running. When a repair is completed and verified, connect the DRB scan tool to the 16–way data link connector to erase all ECM and PCM DTC’s and extinguish the MIL.
Self Erasing Of Error Codes
Trip Indicator
The Trip is essential for running monitors and extinguishing the MIL. In OBD II terms, a trip is a set of vehicle operating conditions that must be met for a specific monitor to run. All trips begin with a key cycle.
Good Trip
The Good Trip counters are as follows:
● Specific Good Trip
● Fuel System Good Trip
● Misfire Good Trip
● Alternate Good Trip (appears as a Global Good Trip on DRB III)
● Comprehensive Components
● Major Monitor
● Warm-Up Cycles
Specific Good Trip
The term Good Trip has different meanings depending on the circumstances:
●If the MIL is OFF, a trip is defined as when the Oxygen Sensor Monitor and the Catalyst Monitor have been completed in the same drive cycle.
● If the MIL is ON and a DTC was set by the Fuel Monitor or Misfire Monitor (both continuous monitors), the vehicle must be operated in the Similar Condition Window for a specified amount of time.
● If the MIL is ON and a DTC was set by a Task Manager commanded once-per-trip monitor (such asthe Oxygen Sensor Monitor, Catalyst Monitor, Purge Flow Monitor, Leak Detection Pump Monitor, EGR Monitor or Oxygen Sensor Heater Monitor), a good trip is when the monitor is passed on the next startup.
● If the MIL is ON and any other emissions DTC was set (not an OBD II monitor), a good trip occurs when the Oxygen Sensor Monitor and Catalyst Monitor have been completed, or two minutes of engine run time if the Oxygen Sensor Monitor and Catalyst Monitor have been stopped from running.
To count a good trip (three required) and turn off the MIL, the following conditions must occur:
● Engine in closed loop
● Operating in Similar Conditions Window
● Short Term multiplied by Long Term less than threshold
● Less than threshold for a predetermined time If all of the previous criteria are met, the PCM will count a good trip (three required) and turn off the MIL.
Misfire Good Trip
If the following conditions are met the PCM will count one good trip (three required) in order to turn off the MIL:
● Operating in Similar Condition Window
● 1000 engine revolutions with no misfire
Warm-Up Cycles
Once the MIL has been extinguished by the Good Trip Counter, the PCM automatically switches to a Warm-Up Cycle Counter that can be viewed on the DRB III. Warm-Up Cycles are used to erase DTCs and Freeze Frames. Forty Warm-Up cycles must occur in order for the PCM to self-erase a DTC and Freeze Frame. A Warm-Up Cycle is defined as follows:
● Engine coolant temperature must start below and rise above 160° F
● Engine coolant temperature must rise by 40° F
● No further faults occur
Error codes listing in PDF file
2nd Gen Guru
Discussion Starter #2 (Edited)
UPDATE! - P1693 Error Code Solo
I'm going to point out to everyone there is NO WAY to have just a P1693 code present during error code dumping. Yes the P1693 is a companion code and has no really meaning but...
"This code indicates there is more code present in the other computer" So if the P1693 is in the P PCU that means there is more codes present in the P ECU. So if there is a P1693 in the P ECU that means there is more codes present in the P PCU. Then even in rare cases seeing the P1693 code in both computers pointing out that both computers have codes. But there is NO WAY for the P1693 to be the only codes present during error code dump. It's totally impossible!
The reason I'm posting this is because it seem like everyone is cancelling out at the first P DONE thinking its done. WRONG! There is TWO computers in the truck.
P PCU = Powertrain Controller Unit (Passenger side firewall)
P ECU = Engine Controller Unit (Driver side of engine block)
You should always see both P PCU and P ECU displayed and 2 P DONE's in the display. If you want to see a video of this and how to properly do it please reffer to my web site and watch the video I produced so you can give us acurrate information on your problems your having with your truck.
Here is the order it should display...
http://mopar.mopar1973man.com/tips/cummins/2ndgen24v/obd2-error-codes/obd2-error-codes.htm
Now the other thing is alot of people are getting error code from OBD II sites or from manuals with the scanners. I'll point out that any code over P1000 is a manufacture specific code that only applies to the that make and model of vehicle so please refer to a proper Factory service manual and get the proper codes. I've got some books listed on my site provided by PDFTown.com
Download PDF Dodge Ram 2001 Service Manual | PDFTown.com
As for 2nd Gen 24V error codes I copied the error code listing straight out of the Dodge FSM for our truck and made a short PDF file for viewing...
http://mopar.mopar1973man.com/pdf/error-codes.pdf
This will help us diagnose your problem quickly and properly.
Reactions: Thundercraft
