1 - 11 of 11 Posts
Is anyone else finding that they have to add a quart of oil every three to four thousand miles? I have approximatly 27k miles on the truck. I have been watching it myself for the past 12-15 thousand miles and it has stayed consistent. I notified the dealer and they say all they can do is a oil consumption check and make recommendations based on that. I don't know for sure that I trust what thier recommendation will be though.
Thanks.
'Ol Builder guy
That's normal. If you do short trips, it might be more.
I only lose ~1/2 qt between changes.
Haulin' Azz
The one we had that blew up used oil , all our others have'nt used a drop in 5k ever.
I've read somewhere that if you dont break them in right , then they will use oil.
resident mason
Mine doesn't use/burn any either. I ran dino oil for the first 10k then synthetic for 45k now. What do you guys do to break an engine in? I usually wait till it's got around 500 miles on it then give it a good hot supper then change oil, and I don't keep rpm's constant for long periods of time until a 1000 or so. Even now I still hold it on the gov. once in a while just to keep ridges from forming. It's definitely broke in but the mileage is still crap though.
resident mason
Oil is oil. Any name brand syn. oil is just as good as the next. I use whatever is handy, Rotella, Valvoline, Amsoil. etc. Maybe if JHolt ran synthetic oil consumption would diminish unless he has real bad ring problems?
A dealer pry will tell you that is within specs but most dont use much if any oil.
my mom has 50k oh her 07 LBZ and never had to add any oil to it in between oil changes
1 - 11 of 11 Posts
