Hello everyone. I have a '07 2500hd classic. At 26000 miles I noticed oil in my radiator. Took it to dealership they said oil cooler was leaking and they fixed it. I went back about every 20000 miles and they said it was resideu in the engine. I finally got the to take a closer look at (after the 5th time back to dealership). Now they are saying it's my headgasket. Is this a common problem and is it going to keep giving me problem. The truck runs awesome I love it. I have heard it has to do with the heads. I don't know. this is my first deisel.
Mafia member #105
The older Dmaxs had some issues but not many newer trucks have any problems with sealing, If you end up wanting a vin check done on your truck to see what gm is just post your vin I can show you all the warranty work and build sheet and stuff
F
Sounds like an isolated incident, you hardly ever hear of headgaskets going on a Dmax.
my vin is 1gchc23d07f153361 they told me it wasn't leaking but the GM rep. for this area said it was the gasket. I ask if it was a problem and all they told me is they have seen it befor.
Mafia member #105
GM Vehicle Inquiry System
Summary
Home - Summary - Claim History - Vehicle Build - Vehicle Component - Delivery Information - Dealer Information - Service Contract - Warranty Block - Branded Title
Help
VIN : 1GCHC23D07F153361
VEHICLE INFORMATION
Merchandising Model : CC25943 -2007 SILVERADO 2500HD 2WD CREW W/T Warranty Start Date : 05/11/2007
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : MONUMENT CHEVROLET
3940 PASADENA FWY
PASADENA , TX 77503-1110
(713) 473-7601
Selling Source : 13 - CHEVROLET
Site Code : 30644
Business Associate Code : 114854
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 05/11/2007 2 miles 05/11/2010 36002 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/11/2007 2 miles 05/11/2013 100002 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/11/2007 2 miles 05/11/2015 80002 miles
60/100000 POWERTRAIN COVERAGE LIMITED WARRANTY 05/11/2007 2 miles 05/11/2012 100002 miles
60/50000 FEDERAL EMISSION 05/11/2007 2 miles 05/11/2012 50002 miles
60/100000 GM DIESEL ENGINE IN LIGHT DUTY VEHICLE LIMITED WARRANTY 05/11/2007 2 miles 05/11/2012 100002 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
08/20/2007 150739 # F1671 - SEAL, HUB OIL - REAR AXLE - LEFT - REPLACE 34721 miles
08/13/2007 150050 # J0933 - ENGINE OIL COOLER REPLACEMENT 33678 miles
08/13/2007 150050 # Z7903 - 3-DAY COURTESY TRANSPORTATION 33678 miles
06/27/2007 146350 # B9641 - LAMP ASSEMBLY, EXTERIOR - STOP, TAIL AND TURN SIGNAL - LEF 16897 miles
06/21/2007 145827 # J6353 - MODULE, POWERTRAIN CONTROL - EMISSIONS RELATED REPROGRAMMI 14872 miles
06/21/2007 145844 # J6270 - EXHAUST GAS RECIRCULATION VALVE REPLACEMENT 14880 miles
06/20/2007 145782 # J6353 - MODULE, POWERTRAIN CONTROL - EMISSIONS RELATED REPROGRAMMI 14764 miles
10/20/2006 A53361 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
CHECK HISTORY INFORMATION
Vehicle Has No Associated Check History Information.
? 1998-2005 General Motors Corporation. All Rights Reserved.
Claim History
Help
CLAIM HISTORY
Repair Order Date : 08/20/2007 Repair Order Number : 150739 Odometer Reading : 34721 miles
Serviced By : MONUMENT CHEVROLET
3940 PASADENA FWY
PASADENA, TX 77503-1110
(713) 473-7601 Selling Source : 13 - CHEVROLET
Site Code : 30644
Cycle Date Cycle Nbr Case Type Labor Operation Part Auth Code Person Code Line Total Comments
08/24/2007 824 01 # F1671 - SEAL, HUB OIL - REAR AXLE - LEFT - REPLACE 15823962 - SEAL N/A N/A $ 115.07 N
Repair Order Date : 08/13/2007 Repair Order Number : 150050 Odometer Reading : 33678 miles
3940 PASADENA FWY
Site Code : 30644
08/31/2007 826 01 # J0933 - ENGINE OIL COOLER REPLACEMENT 97329038 - COOLER EP N/A $ 585.07 N
08/31/2007 826 02 # Z7903 - 3-DAY COURTESY TRANSPORTATION N/A G N/A $ 126.00 Y
Repair Order Date : 06/27/2007 Repair Order Number : 146350 Odometer Reading : 16897 miles
3940 PASADENA FWY
Site Code : 30644
07/06/2007 810 01 # B9641 - LAMP ASSEMBLY, EXTERIOR - STOP, TAIL AND TURN SIGNAL - LEF 15844157 - LAMP EP N/A $ 269.71 N
Repair Order Date : 06/21/2007 Repair Order Number : 145827 Odometer Reading : 14872 miles
3940 PASADENA FWY
Site Code : 30644
06/26/2007 807 01 # J6353 - MODULE, POWERTRAIN CONTROL - EMISSIONS RELATED REPROGRAMMI N/A N/A N/A $ 58.64 N
Repair Order Date : 06/21/2007 Repair Order Number : 145844 Odometer Reading : 14880 miles
3940 PASADENA FWY
Site Code : 30644
07/13/2007 812 01 # J6270 - EXHAUST GAS RECIRCULATION VALVE REPLACEMENT 97365042 - VALVE BE N/A $ 425.96 N
Repair Order Date : 06/20/2007 Repair Order Number : 145782 Odometer Reading : 14764 miles
3940 PASADENA FWY
Site Code : 30644
06/26/2007 807 01 # J6353 - MODULE, POWERTRAIN CONTROL - EMISSIONS RELATED REPROGRAMMI N/A N/A N/A $ 33.51 N
Repair Order Date : 10/20/2006 Repair Order Number : A53361 Odometer Reading : 0 miles
3940 PASADENA FWY
Site Code : 30644
10/24/2006 737 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N/A N/A $ 96.91 N
CHECK HISTORY
Vehicle Has No Associated Check History.
The oil cooler is what they told me was the problem. They don't have the other three times I brought it back to them for the oil in radiator. They told me it was residue. I guess what I'm wanting to know is if they just replace the head gasket will it fix the problem. They told me that the gasket wasn't cracked it must have had blow by. I asked him if he was going to mil the heads. He said they would insp. them. I have a couple of mech. telling me it was probly because the heads were warped. I don't know anything about deisels. If it was gas I would know.
Strange.... Have you been losing engine oil?
I had my oil cooler go at about 8000 miles. They flushed it several times after replacing the cooler and I have never had a problem since.
My guess is either they didn't flush it good enough the first time or you have another leak from the cooler. Oil in the antifreeze via gaskets isn't very common-usually it's the other way around.
