I have an oil leak seems to be behind the front cover compressor (seal?) behind the hub does anyone know what seal number or if i'm even calling it right? gasket? seal? its behind the belts on the hub the one that goes threw all of the belts, air compressor not the air conditioner compressor thanks for any help
I think you are referring to the accessory drive seal. You would need your engine serial number to determine the correct seal and sleeve. There is also a timing plug behind the pulley too. Would be worth your while to put a new oring on that too while you have the pulley off. You will need a puller to get the water pump drive pulley off and an installer to pull it back on.
