i have oil leak coming from the right side rear wheels is it brake fluid or what is it im in the dark really know nothing
how in the world can someone on here tell you if it's brake fluid :shrug:
Not hard to check and see which one is getting low, either. I would check the brake fluid level, and the rear diff level.
It could be rear wheel seals, or a leaky caliper.
its coming from the wheel axel seals and all that are new any idea of what it could be maybe a simple fix cheap or expensive
shouldn't be too spendy. One of the axle seals could have been installed incorrectly.
Or it could be a brake caliper, line etc, none of which is too expensive.
