Built Not Bought
So i have some oil seeping out of the front of my transfer case from wat i have noticed is it is the either the weepage plug or the front seal and i am talking bout where the front driveshaft goes into the transfer case. Its not really bad enough to where it is leaving a spot on the ground but i knows it there and i gotta fix it cause it bothers me i have checked to see how low it was i put a little ATF plus 4 in it to top it off but it still seeps anyone else had a this happen on there Dodge oh mine is a 07 wit 86k on the clock.
ADMIN/MAFIA
I would look at the front seal that goes around the front shaft. Has that ujoint went out? and could it have damaged the seal when it did?
Let it rip tator chip!
Mine is leaking there to at he front driveshaft.I called the dealer and they said, that there was 2 seals side by side there.(from what i understand) The seal surpose to come monday and ill try to get some pics of it for you, if you need?
