OASIS RESULT:
1FTSW21P57EB29489
02/27/2008
19:42:07
FCXWS447
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2007 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
6F710H0A
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-04-07
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/05/2007 BUILD DATE
11/15/2006 SALE MILEAGE
00032
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
01/22/2008
DEALER: Vista Ford of Oxnard
WARRANTY CLAIM NUMBER: 085510 ODOMETER: 040157M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6K682CARM TURBO CHG-EXH DRIVE 001 071601C 42 DOES NOT OPERATE PROPERLY
TURBO OVERBOOST CAUSING COOLING TO OVERPRESSURIZE,DIAGNOSE AND REPLACE TURBO ASSY., RETEST
11/26/2007
WARRANTY CLAIM NUMBER: 082671 ODOMETER: 035810M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9433BE GASKET SET-MANIFOLD 001 6051AT 14 SURFACE ROUGH/UNEVEN
3C3Z 6A642AA COOLER CRANKCASE OI 001
6C3Z 6049A CYLINDER HEAD 002
6C3Z 6051A GASKET CYL HEAD 002
3C3Z 6731AA ELEMENT ASY OIL FILT 001
3C3Z 6734AA GASKET-ENG OIL PAN D 001
XO 15W40QSD 015
VC 7B 002
CYINDER HEADS WARPED, PRESSURE TEST SYSTEM, REPLACE HEADS, REPLACE OIL COOLE R DUE TO EOT AND ECT TEMPERATURE DIFFERANCE OF 23 DEGREES, RETEST
11/26/2007
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9229B GASKET CARB FUEL INL 001 6007D D8 FAILED GASKET/SEAL
OSP 001 MT9229
CAM SENSOR ORING LEAKING, PERFORM ENGINE OIL DYE TEST, REPLACE CAM SENSOR OR ING, RETEST
04/25/2007
DEALER: Mel Clayton Ford
WARRANTY CLAIM NUMBER: 086862 ODOMETER: 007234M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6K682A TURBO CHG-EXH DRIVE 001 062302A 42 DOES NOT OPERATE PROPERLY
TURBO OUT OF LIMITS REPLACED TURBO, RETESTED OK
04/04/2007
WARRANTY CLAIM NUMBER: 085940 ODOMETER: 004584M
LABOR OP
CONDITION CODE
CONDITION DESC
RECALEM ECC PROCESSOR RECAL 000 6005F 04 SOFTWARE REVISION/FLASH MODULE
000 6005F1
000 6005F6
000 MT12650D84
000 6005F1X1
PCM OUT OF CALIBRATION ENGINE PERFORMANCE DIAGNOSTICS - DIESEL ENG INE - DIAGNOSIS
| On-line 1878
END OF OASIS REPORT FOR 1FTSW21P57EB29489
Standard Claims List For Model Year 2007
1FTSW21P57EB29489 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-NOV-2006 05-FEB-2007 171457 USA 1 6P07 010302 * 5424630 * B19 D4 63
AWS Claim Key: 265855 Trx Code: 1 Labor Hrs: 0
Dlr Cd-Sub Cd: 05599 - * Name: R E BARBER FORD Ph: 805-6426701 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:07-FEB-2007 Doc #:42494401
Cust Comments: CUST STATES OUTWARD DENT IN LEFT REAR DOOR
Tech Comments: REPAIRED BY DENTCRAFTERS
1FTSW21P57EB29489 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-NOV-2006 05-FEB-2007 171457 USA 1 6Y06 0502XX * 1240 * A96 51 63
AWS Claim Key: 269669 Trx Code: 07T05 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 05599 - * Name: R E BARBER FORD Ph: 805-6426701 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:09-FEB-2007 Doc #:42515001
Cust Comments: CUST STATES PERFORM RECALL 07T05 AXLE BRG INSPECTION
Tech Comments: REPAIR PER RECALL
1FTSW21P57EB29489 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-NOV-2006 05-FEB-2007 171457 USA 2 2G05 031405 * RECALEM * D42 04 4584
AWS Claim Key: 429649 Trx Code: S07 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 05445 - * Name: MEL CLAYTON FORD Ph: 805-6822444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:04-APR-2007 Doc #:08594051
Cust Comments: CUST STATES ENGINE LACKS POWER, ADVISE
Tech Comments: PCM OUT OF CALIBRATION ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
1FTSW21P57EB29489 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-NOV-2006 05-FEB-2007 171457 USA 3 2H01 030407 5C3Z 6K682 A D42 42 7234
AWS Claim Key: 485595 Trx Code: S07 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 05445 - * Name: MEL CLAYTON FORD Ph: 805-6822444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:25-APR-2007 Doc #:08686251
Tech Comments: TURBO OUT OF LIMITS REPLACED TURBO, RETESTED OK
1FTSW21P57EB29489 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-NOV-2006 05-FEB-2007 171457 USA 10 1A01 030102 6C3Z 6049 A D50 14 35810
AWS Claim Key: 1505397 Trx Code: E84 Labor Hrs: 14.3
Dlr Cd-Sub Cd: 03893 - * Name: VISTA FORD OF OXNARD Ph: 805-9836511 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:26-NOV-2007 Doc #:082671B
Cust Comments: COOLANT COMING OUT OF COOLANT RECOVERY, WHITE SMOKE WHEN COLD, ADVISE
Tech Comments: CYINDER HEADS WARPED, PRESSURE TEST SYSTEM, REPLACE HEADS, REPLACE OIL COOLER DUE TO EOT AND ECT TEMPERATURE DIFFERANCE OF 23 DEGREES, RETEST
1FTSW21P57EB29489 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-NOV-2006 05-FEB-2007 171457 USA 10 2E03 03XXXX 3C3Z 9229 B L65 D8 35810
AWS Claim Key: 1505398 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 03893 - * Name: VISTA FORD OF OXNARD Ph: 805-9836511 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:26-NOV-2007 Doc #:082671C
Cust Comments: CUSTOMER STATES ENGINE OIL LEAKS, ADVISE
Tech Comments: CAM SENSOR ORING LEAKING, PERFORM ENGINE OIL DYE TEST, REPLACE CAM SENSOR ORING, RETEST
1FTSW21P57EB29489 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-NOV-2006 05-FEB-2007 171457 USA 12 2H01 030407 5C3Z 6K682 CARM L87 42 40157
AWS Claim Key: 1810796 Trx Code: S07 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 03893 - * Name: VISTA FORD OF OXNARD Ph: 805-9836511 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:22-JAN-2008 Doc #:085510A
Cust Comments: CUSTOMER STATES VEHICLE LEAKING COOLANT, ADVISE
Tech Comments: TURBO OVERBOOST CAUSING COOLING TO OVERPRESSURIZE,DIAGNOSE AND REPLACE TURBO ASSY., RETEST
