I was reading other posts, and figured if i just disconnected the ebp controller, i could hard wire it to a switch. Is it effective as an exhaust brake even though its not designed for it? Does it hurt any parts? Thanks.
member
I just ran mine to a toggle switch off and on and I have had it a year that way and no problems so far.. great in winter warmup! just be sure turn off before you hit the go pedal egt's will sky rocket
MAFIA MEMBER 106
i use mine as a brake and love it 50,000 now using it as an exhaust brake they are desiged for ex brake thats its funtion to back up the ex into the engine to help with warmup.
MAFIA MEMBER 106
hollinger-farms said:
Is it hard to disconnect? Mine drives me nuts the stupid thing shuts going through town and it sounds terrible.
no its not hard there is a plug down on the turbo ped /w a little steel clip just unplug it and you can get a plug from dfuser that will keep it from setting a code
hollinger i sent you a pm
