Truck (04 GMC K2500 CC 4x4 Duramax/Ally) just went in the shop. Problems: Speedo went wonky (stuck @ 100 or so), fuel in oil, tapping from under the hood, surge at idle.
Dealer says! -- #8 inj bad, needs fuel pressure reg, guage cluster shorted. Will replace injectors under warranty (Who-hoo!)
Use to do lots of lb7 injectors for fuel in the oil. I also had a hand full of fuel pressure regulators that were slow to respond and would cause a 100rpm surge. The spedo clusters had all kinds of problems in those years. Hope you get it all fixed up. Good luck.
F
Yeah, those are fairly common problems, but the good thing is GM is standing behin the faults for 200K miles on the injectors.
