with the cap on or off ?
It might be an "H_G", TxC would know, and how to check for it.TxChristopher said:Its a blown head gasket at minimum. Now to demonstrate it to the dealer and have them fix it under the 100k engine warranty, then all will be well. :Thumbup:
Hi idahofox,idahofox said:It might be an "H_G", TxC would know, and how to check for it.
I would check the " Free-bies " first, then..................
FWIW; with respect!
I am beginning to wonder if it has to do with the three different thicknesses of head gaskets they use. There is an A, B, and C grade gasket, the difference is supposed to be thickness. Perhaps the thicker gasket is more prone to blowing due to more surface area, who knows. Maybe the thinner one lacks material to keep a solid seal. Some trucks sure seem to let go of head gaskets easily, notably easier than most.cooksvillewildc said:Anyone know what may contribute to a blown head gasket - I used to have a 1989 Firebird Formula with a 5.0L V8 that was notorius for blowing intake manifold gaskets because the intake was aluminum, the block was cast iron and the gasket they used to mate the two did not expand correctly to accomodate both metals. Do you think there a gasket or metal issue in this case or is it luck of the draw or is it another problem?
The small block went through a major redesign seal wise around 86 and it took them several years to get them all right. The TPI Camaros/Firebirds had those gaskets that had sorta o-rings built into them. They changed the angle too on the bolts that held the intake to the heads, standing them up, which was not the best move because the intake was no longer being drawn directly to the heads but rather pushed downward like a wedge into a V. Due to the angle of the bolts it was far easier to end up with uneven torque on the intake manifold, which led to leaks after it went through enough warm up cycles. You started seeing a lot of the new anerobic sealers too around that time, as well as one piece seals on the crank. They also went to centerbolt valve covers which were nice and a definite improvement over the old design. Once you got to the 90's cars they had it down good. :Thumbup:cooksvillewildc said:Anyone know what may contribute to a blown head gasket - I used to have a 1989 Firebird Formula with a 5.0L V8 that was notorius for blowing intake manifold gaskets because the intake was aluminum, the block was cast iron and the gasket they used to mate the two did not expand correctly to accomodate both metals. Do you think there a gasket or metal issue in this case or is it luck of the draw or is it another problem?
