Many parts available
1. 175 P-Pump All stock w/ solenoid $400 plus ship
2. Timing case and cover (case was hit by the kdp and welded back) $200 plus shipping
3. 175 injectors $125 shipped
4. conversion stuff... Lift pump, lines, everything but the p pump, case and injectors... make offer (best offer takes it all)
5. Engine block with crank assembly..$ make offer
other parts available
"No motor mounts, turbo, Harmonic dampener, Fan or hub"
Engine was running good when pulled due to being caught in cold weather with water in the system so it popped out the freeze plugs which lead the owner of the truck to just replace the engine
Paypal or postal Money orders ONLY
what about the heater core hard lines? Chris
I'll check tomorrow on those
No dice on the heater lines (damaged pretty bad)
