1 - 17 of 17 Posts
BLING BLING
As requested here are some pics of the BOV. If any of you guys have questions let me know. Hooking up to the TPS was trial and error due to the fact that there are 2 of the same colored wires there and only one works.
BLING BLING
And the rest. Last one is where I wanted to put it but I could not get the IC pipe off. Anyone know how? haha.
Diesel Kid
Looks awesome. So how bad was the install?
cool as december
Looks good man, i like the location its at, but your other option would have been good too. Where did you get the valve, and of course how is it working for you?
Looks like a good install. So now educate me, what does it do? Thanks:thumbsup
Keeps the turbo's from "barking" or stalling when you let out of the throttle... saves the turbo's in the long run.
Thank you....................
BLING BLING
Thanks guys. Install wasnt to bad except for fighting with the drivers side IC pipe. I worked for damn near an hour trying to get it out and it wasnt coming. Took the sway bar down, power steering jug out of the way. Coolant hoses for the EGR and it wasnt coming. Once I gave up on that it went pretty easy. Ill do a write up on this shortly. BD has instructions but there not the best. And It is from BD diesel. Turbo gaurd I believe they call it.
Working good. Just fine tuning the box under the dash so it lets off quick and comes back quick. The 310 tune is pretty touchy on the pedal so you have to adjust the box for your TPS. Ryan
cool as december
cool looks good, im sure every tune is different on the peddle, but you really only need it for one tune....
BLING BLING
Replacing the stock converter with a suncoast or PI this weekend and then its game on.
Powered By Ford
when you gonna race ROBTS? haha
Thanks for the pics! I am still really interested in getting one of these put on so Im gonna wait for your write up.
As for removing the drivers side IC pipe, Ive been having the same problem. I need to replace that whole pipe because where it connects to the IC is now oval so the boot keeps blowing off. UGH....Im gonna turn it over to the dealer tommorow bc I think as you mentioned theres alot to remove to get it out.
Thanks again
Diesel Kid
thats the price we pay for having a bigger motor....stuffed engine bay. :gaah
R.I.P. DAD
Looks cool.
Heres how I get the intercooler pipes out. Take out the two 10mm top radiator mounting bolts on the passenger side. Take out the three 13mm radiator support bolts on the passenger side and loosen the three on the drivers side. Loosen the clamps for the boots and remove. Slightly pry the radiator support forward on the passenger side while pushing the radiator back slightly. The tube will come out from the back in one piece after some swear words.
1 - 17 of 17 Posts
