Pioneer 12" shallow-mount subwoofer.
Was installed in truck in 5/2012. Used very little and at low volume when used. I listen to country music.
I custom built the sealed box, which has right at 1.0cuft of volume. Box was built from 3/4" MDF, glued, screwed, and caulked.
The carpet job isn't the best, but it didn't bother me, since it is behind the rear seat and no one sees it.
**Will fit 05-07 models with no issues. Must remove the molded carpet hump off back wall of cab behind driver's side rear seat. Knock out the cab vent, and seal off hole with Dynamat or your choice of material. May fit other models of Superdutys as well.
Size 12"
Max. Music Power (Nominal) 1,500 W (400 W)
Frequency Response 20 Hz to 230 Hz
Sensitivity (1 W/1 m) 93 dB
Impedance 4 Ω
Mounting Depth 3-1/4"
Cut-Out Dimensions 11"
Recommended Enclosure 0.5 to 1.0 cu. ft.
Box Dimensions:
34.25" L
15.25" H
6.25" D2
4.25" D1
All dimensions taken from outside of carpet for max overall size.
Asking $150 for sub/box. Shipping was quoted at $50, due to the weight and size. May be cheaper depending on how close you are to me. Call/text 859-519-6919
