Ok so she was running fine before I worked on it...... early 1999 f350 7.3 power stroke. new turbo rebuild, glow plugs, valve cover gaskets and wires, oil crossover line, ebpv, oil bypass, ohm test after gaskets installed(passed). After I put her back together she wouldn’t start. It would fire up and then die, now she will fire up sputters and every so often puffs a white cloud while also lightly smoking. (All white smoke, more like very often) ive replaced all the sensors prior to this. I’ve let it idle for over an hour and it still runs like ****. In drive it won’t go over idk 20-30 mph. And it takes a long distance to get to that point. Zero throttle response like there is no turbo functionality but the turbo is spoiling and connected properly. I’m stumped! It bucks when it goes to shift. From 1-2 now. Do t think it ever shifted into 3rd due to literally zero power!
