Any info?? If my Box is on 5 (Edge Comp) It almost sounds like a rev limiter or fuel cut??? Any Idea?
how much rpm u turning? mine old truck would do it with the a drag comp and smarty level 8 but i was sled pulling. 3600-3700 rpm is when it start doing it. best advice is get the valve spring upgrade it helps a bunch. comp is setup to start defueling at 2700rpm. drag comp isnt until u hit the redline.
Discussion Starter · #3 ·
Whatever factory is?? I am going to take the box off I think.
I can run my Edge Comp all the way up to 3K RPM's without a issue.
Pulls strong and no unusual noises...:shrug:
not saying that u cant run a regular comp past 2700 rpm. it is design to start defueling at that. look at a dyno sheet the hp starts dropping faster where as a drag comp carries a more of a level peak
i had an edge juice/hotunlock and it would pop u might want to look into a fass or some other kind of larger fuel pump my new box dosent pop.:93C_peelo
Ah... I see... I when back asee what you talking about now... Even looking at my own Dyno sheet...:damnit
