copied from another site>>.
1.) Unhook batteries
2.) Take out driverside battery and battery tray
3.) I took off the whole intake up to the turbo... at this point im pretty sure you can see the pump....
4.) Take off the belt.
4.5) Sit back and have a beer
5.) Next is the tube that runs from the intercooler to the top of engine.... just for easier access.
6.) I unbolted the PSP first then unhooked the lines.... it was held on by three bolts....
7.) Once you have the lines off, just squueze it out the top and there you go.
7.5) At this point your defenitely gonna want a couple more beers
8.) Get yourself a power steering pump pulley and installation tool.
9.) transfer the pulley to the new one... make sure you put grease on the shaft or else youll be killing yourself to get that bad boy on...(Its said not to use the same pulley more than twice...so if it has one mark on it paint another one... if it has two buy another for $30 ... i believe.)
10.Now just throw everything back in.
