use ur zf6, its a good trans!!! adaptor plate is bought 800bucks, good common rail id guess atleast 3k, id say u would have atleast 6k into it when ur done in stock form
i am pretty sure you will use your ford clutch with a custom cut fly wheel give destroked a call or GOS performanceSo how does the trans hooke to the engine I no I wold need an adapter plate to bolt them togeather but wold I use the clutch I have with the 6.0 and zf or wold I need a different clutch the reson I ask is that I already have a sout bend dd clutch
Im pretty sure all you need is the crank spacer and bushing to make the SBDD to work. JP will know fo sho.thanks but the south bend double disck clutch has a special flywheel
P.S. I got the raidio and every thing work but the cd player but oh well I dont listen to cd much any way and all I wanted was to be able to get the subs working again so thanks again
